Question about Water Heaters
Kitchen Aid display blank, door locked after self clean cycle
Kitchen Aid Model KRGK806PSS00. We ran the self clean cycle. Before it was done, the display went blank. The oven door remains locked. Circuit breaker (house) not tripped and stovetop igniters still work. Serial XS0209984
  • 1 more comment
  • pdvitalis Mar 15, 2009
    I tried unplugging for over an hour to reset it to no avail.
    Thanks, I suspected as much. Is it possible that there's a fuse or reset on the controller board or is total replacement the only option?
    I got stuck in disassembly. I got the visible screws removed from the front cover but the valve shafts seem to get in the way when I swing the panel out and up. Any thoughts?
    Sergeant:
    Champion:
  • 234 Answers
I would say you have have switch bad on the lock door.
Posted on Mar 15, 2009
  • Earnest Bowes Mar 17, 2009
    You can take the side off the unit and unlock the door manual.But don't break the switch.The back and top come off this unit.But make sure you have it unplug from power first.
    I misunderstood you on this .This is oven in the wall.But you can still take the back off and get door unlocked.I know because I've done that before.Thanks
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your description of 'no display' and 'door locked' are both significant. It indicates that the electronic controller board has failed. This board is responsible for the logical processing of user commands, internal sensors, activating/deactivating components and displaying status. The board comes as an assembly and replacing it would require familiarity with electrical wiring, electronic components and circuitry and dis-assembly of some of the panels/covers. In most versions, the electronic controller board is right behind the display panel.
Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Mar 15, 2009
    Appreciate the FixYa rating and your postback.
    To my knowledge, there are no fuses nor any breakers/reset specifically for the electronic controller board. Am afraid assembly replacement is required.
    Brigadier General:
  • Water Heaters Master
  • 3,614 Answers
unplug the unit for an hour, or better turn off the main circuit breaker, then start again the unit
I have a whirpool energy star washer and the door is stuck in lock position. The lights that are on are spin and door lock
If you remove the bottom panel under the door, you can see a lever or tab that will allow you to open the door. Before you do that though, there is a drain plug that is visible. Remove the plug and get ready for WATER to come out. Have towels or wet vacuum cleaner ready. There will be a filter trap that is in the drain. Clean it out too.
Nov 28, 2014 | Whirlpool Whirpool Energy Star Dishwasher...
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
I have a honeywell rth110b thermo and the other day I noticed that the display was fading and it looked like the battery icon was showing so I changed the batteries and now the display is completely blank...
The manual does not have troubleshooting steps.
Check the battery polarity, and clean points of connection.
Otherwise honeywell.com has customer care number
Oct 07, 2017 | Water Heaters
I have a whirlpool cabrio washer for a while now here and there i was pulling out soaking wet clothes.and ofcourse my warranty ran out yesterday and now it will not start any cycle all its does is sense...
This particular washer has a test that we can run to see any errors. This can be confusing on this model.
I am including a document below that will describe how to view the old error codes. Use the section that starts with Activating the service diagnostic modes. You can start with the cycle selector knob at any position.
  1. Be sure the washer is in standby mode (plugged in with all indicators off).
  2. Perform the following sequence of movement using the cycle selector knob. NOTE: After reset, sequence "a" through "e" must be completed within 6 seconds. When it tells you to rotate the cycle selector knob, it means 1 click, not a full turn. Once you have completed the cycle knob turns reset and "a" through "e", turn the cycle selector 1 click clockwise from the position it is already in. This is the fault code display mode. Then press the start button. Each time you turn the cycle selector knob 1 click clockwise after pressing start will show you an error code. Note: this washer stores 4 codes if any. The error codes on this washer are displayed in this format: F5 E3, F7 E1, etc. There is an error code chart in the image below.
If there are no error codes stored, I recommend that you start from the beginning (step 1 above) and then run the Automatic test mode. If this unit detects a problem, it will display the error at the end of this test.
Here is a list for the errors.
Post back your results.
Sep 14, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Whirlpool 6th sense stops at 1 min and doesn't finish wash cycle
We had same problem, and the only thing that we could do is call the repair man. He put in a new door lock and the problem was solved.
May 21, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
We have a reliance 501 propane water heater model # 5 40 porto manufactured in 1991 We have had build up of rust in the pipes from the tank to our dishwasher and sink. Our dishwasher is not cleaning...
After 18 years there will be a build up . you could flush the tank and see what comes out, replace the line to the sink and dishwasher , then you can decide if you want to replace the tank .Which sounds like it will need to be done .
May 13, 2017 | Water Heaters
Sometimes water doesn't get hot.
Clean the air filter even if it looks clean. The air filter is located in the front panel(unscrew knob to open door)...filter looked ok to me but cleaned it under water and that fixed the problem. Note: I cleaned the water filter first and that did not solve the problem. A simple test to see if the air filter is the problem...take the panel door off, press the filter door button and test hot water usage.
Apr 20, 2010 | Rheem Tankless Hot Water Heater...
Water pressure past my paloma water heater is not as good as the cold side.
this could be a flow issue, how long has it been installed? Calcium builds up in any brand very quick and it might need de-scaled. We sell a do it your self kit and solvent called flow aid, safe and easy to use available at heaterup.com
Jul 14, 2009 | Rheem Paloma PTG-74PVN / RTG-74PVN...
Water Heaters Logo
56 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
