Question about Saeco Magic Comfort Plus Espresso Machine
The display says ventilate and doesn't change.
I've tried changing the watertank, removing the dredgedrawer, unplugging it, shutting it off and nothing seems to work.
  • mamanon Apr 10, 2009
    the display says VENTILATE and nothing I do solves the problem.
    President:
  • 1,618 Answers
Try running the hot water valve.
Posted on Mar 11, 2009
Hi I split milk tea on my vaio, when i was cleaning it the system close all program the shut down. when i try to run again the power led keep flashing but the system does not come up. Currently I put my...
Send it for servicing. The liquid may have seeped into the motherboard and spoilt something.
If you still want to try, but it near a warm, not hot heat source. It may speed up the evaporating of the persisting liquid in the laptop.
Jun 21, 2011 | Computers & Internet
Our Comfort machine won't brew and constantly displays, "Fill Watertank" even with the tank full. In order to brew, one has to remove the water tank then gently lower it only partially down in place. As...
Hi
The magnet in the water tanks is either upside down or has sunk to the bottom of the tank. It should float to the top of the cage it is in and it should have a flat top not rounded. If its rounded side up the magnet is upside down. This is what would cause your problem.
Sep 22, 2010 | Saeco Magic Comfort Plus Espresso Machine
The S9 has been unused for three months and I cannot get it to get water to the brewer. It keeps telling me to fill the water and press the steam button. No such luck. Is there a way to prime this machine?
Hello
This is a common problem and there`s usually only 1 thing you can try to do yourself. Use luke warm water in the watertank and repeat the fill system procedure 4-5 times. If this doesn`t help, try to shut down the machine and try the same after 30 minutes. If nothing happens after you tried this a few times, then theres a problem with the solenoid valve for steam, and this need to be changed. That`s something you need help from a technician for.
Jun 13, 2010 | Jura Capresso Impressa S9 Coffee...
I've got a problem with my Saeco Vienna Digital. It says that I've got to fill the watertank and ventilate. But the watertank is filled, that little 'thing' in the corner of the watertank is still going up...
Check the end of the steam wand it might be blocked, if it is not, then remove the steam wand and check the top there is a small teflon insert (this part is in some models) remove insert and toss. If that does not solve problem then machine needs to be descaled.
Jan 12, 2010 | Saeco Vienna Digital Coffee Maker,...
The machine says fill watertank. ventilate. the
Open the hot water valve, and run about a cup of water, this will engage the pump and fill the circuit.
Jun 04, 2009 | Saeco Vienna Digital Coffee Maker,...
Dregdrawer Full
There is no 'sensor' for this, an internal counter resets when you remove the drawer with the machine switched on and the "Dreg drawer Full" message displayed.
Make sure the machine displays this message "DREG DRAWER FULL" Do NOT turn off the machine, Pull out the drawer that the used grinds are dumped in(you have to remove the drip tray 1st) Check display - it should read "DREG DRAWER MISSING" If the display message is correct, wait 10 seconds then replace the drewer.
Message should be cleared.
If the "dreg drawer missing" does not display, you do have a bad sensor and machine needs to be serviced.
Nov 19, 2008 | Saeco Royal Digital Plus Coffee...
Fill Water tank - Ventilate
Hi Mike,
Make sure the magnet flow up, if it flow up and you still get fill water tank then you have to replace the magnet.
If you get ventilate all time, try to remove the filter and try again.
/Mirran
Aug 23, 2008 | Saeco Incanto Classic Espresso Machine
Display says system will be filled with water but nothing happens
I solved the problem. The hot water escape was blockt by a piece of lime. So the pressure was to strong to let water in the system. You have to dick with a little needle in the small hole of the escape. That´s it.
Feb 17, 2008 | Krups Orchestro Dialog FNF2 Espresso...
Saeco Magic Comfort Plus Espresso Machine Logo
107 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
