Question about Kitchen Appliances - Others
Manual to Walgreens ''Signature Classic Deep Fryer''
Manual to Walgreens Signature Classic Deep Fryer 3.2 Quart size
  • 3 more comments
  • Anonymous Mar 18, 2009
    Won't heat up-light doesn't come on
  • Anonymous Mar 20, 2009
    Ther is no instruction Manual with the Signature Classic Deep fryer i bought yesterday at Walgreen's/
  • twinsy Mar 20, 2009
    No instruction book came with product. Most recipes say set the temp as suggested by manufacturer.
    No instruction for cooking came with the product.
  • Anonymous Mar 30, 2009
    No icooking instruction booklet.
  • Anonymous Apr 28, 2009
    I have the same problem...no instructions on what temperature to cook food. I contacted the customer service and they said someone will call back??? Has anyone made chicken wings in the fryer and if so, what temperature did you put it on?
burzerko
  • 254 Answers
SOURCE: using peanut oil in GE deep fat fryer
Peanut oil contains oxcylic acid and could cause premature wear on your fryer.
Posted on Jul 01, 2008
IrishDruid
  • 2712 Answers
SOURCE: Deep fryer power cord
You can contact Rival HERE.
Mailing Address:
Rival
c/o JCS/THG, LLC
13120 Jurupa Avenue
Fontana, CA 92337
Telephone: 1-800-323-9519
If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 17, 2008
SOURCE: cool touch t-fal deep fryer
Try this it is for another model.
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010517.pdf
It a 12 page manual.
Posted on Jul 27, 2008
SOURCE: magnetic breakaway power cord for rival deep fryer
I have a Rival CF-250 cool touch deep fryer. Where do I get the magnetic breakaway power cord, filters, and filter cover.
Please let me know.
Thanks.
Ken Cooley
Posted on Oct 08, 2008
sclarke7
  • 222 Answers
SOURCE: i need a users manual for durabrand jfr26 deep
try www.servicemanuals.net
Posted on Sep 04, 2009
I have lost the instruction booklet for Cooks Essential 12 qt. air fryer. Do you have it available online?
QVC lists the K43782 Cook's Essentials 12 qt air fryer here: http://www.qvc.com/CooksEssentials-12-qt-Air-Fryer-w-Rotisserie-%26-Accessories.product.K43782.html . There is a link to the User's Manual below the Description header. The direct link to the manual is http://www.qvc.com/footers/cd/pdf/K43782-OwnerManual.pdf .
I hope this helps.
Aug 08, 2016 | Nesco 12-quart Professional Stainless...
Can I tell just by looking at a deep fryer if it's nat gas or propane
It should be listed on the label unless it was changed at some point. The only way to tell is to use numbered drill bits to see what size hole is in each brass orfice of the burners, usually 3 to 5. The manual will list the orfice size for LP or NAT by the fryer BTU output. Most manuals can be found online, if you don't have a copy. This will require removing part of at least one burner to check the hole size. New orfices are normally about $20 each, most are marked on the side of the brass orfice. Note: some people drill out the holes to convert LP to NAT gas. Don't trust what is marked on the orfice, be sure to check with a drill bit. Small numbered bits can be hard to locate in most hardware stores. Found mine at Harbor Freight Tools.
Sep 23, 2014 | Imperial IFS-40 - Gas Deep Fryer - 40 Lb -...
I have a older 40,000 BTU 3 burner natural gas deep fryer. I would like to convert to propane gas. The orifice number is size 32. Do I need to get different orifices to convert? The serial number is...
Hi there.
Burner orifice size for propane gas is number 55. You have to replace all burner orifice with this size if you want to use the fryer with propane gas. Pilot burner orifice should be replaced with propane pilot orifice.The gas valve spring should also be replaced with propane spring kit. The difference between the two spring is the natural gas spring is lighter or thinner compare with the propane gas valve spring.
Regards.
Jul 13, 2011 | American Range AF40 Deep Fryer
How long do I Fry a 11lb Turkey using a 22 Quart Electric Masterbuilt Frier
3 minutes per lb then add 5 minutes to total cook time, so approx 38 minutes.
Nov 25, 2010 | Masterbuilt 20010306 Deep Fryer
Need a break away power cord for the 3.5 Quart Deep Fryer model # RHDF260A. Where can this cord be purchased?
Jul 19, 2010 | Russell Hobbs RHDF260A Cool Zone Deep...
Missing instruction manual for Charmglow Electric Turkey Fryer
Fry turkey 3 minutes per pound, then add 5 minutes to total cooking time
Nov 26, 2009 | Kitchen Appliances - Others
Need instruction manual for a Oster Deep Fryer ODF510
This is the only manual available on factory website for Oster Deep Fryer.
The model is different , check if controls are the same.
A manual for your model can be obtained following the instructions here: Oster ODF510 Manuals, Support and Troubleshooting
Aug 09, 2009 | Oster ODF510 3-Pound Deep Fryer
Imperial deep fryer model: IFS-40
Sounds like the pilot is dirty,if you have propane gas this is your issue,replace the pilot either way.
Aug 22, 2008 | Imperial Kitchen Appliances - Others
Kitchen Appliances - Others Logo
2,609 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
