Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Symtoms of a bad oil sending unit 1995 silverado
    Scholar:
  • 117 Answers
If it is leaking oil then it is bad. If you suspect it is not reading correctly, note your oil readings a idle and 2000 rpm. Take the switch off and install a oil pressure gauge to see what type of pressure you have, then compare to the readings you took.
Posted on Nov 02, 2013
Will a 1995 Buick Skylark leak oil if the Oil Sending Unit is burnt or bad?
Yes the sending unit will leak oil if it's bad. It will leak where the electrical plug clicks into the unit. If you disconnect the plug and remove the unit, you can see on the plug end where the oil leaks thru.
Jul 28, 2012 | 1995 Buick Skylark
2005 Chevy silverado oil pressure guage is on zero , oil level is fine, changed sending unit with no result,
check the filter,, if its bad enough your oil won't pass through it, making it look like your oil is full, but its not moving, Chevy's have whats known as a stepper motor also on the oil gauge,, whats bad about that is if thats gone bad, you have to replace the whole gauge cluster which last time I checked is 250.00
Jul 19, 2011 | 2005 Chevrolet Silverado
Oil pressure gauge is reading 80 psi. I had the
The oil sending unit is located on the engine block behind the drivers cylinder head area.You have to climb up on the motor to see it cause it is hard to see behind the wiring harness.You may also want to purchase a new sending unit because it is very long and you might need to buy the sending unit socket to replace it.Hope this helps.Good luck.
Jul 20, 2010 | 2003 Chevrolet Silverado 1500
Hi i have a 95 silverado an about a week ago i was driving and oil pressure kept dropping and check gauge light but when take off from light everything goes back normal culd this be the sending unit going...
Yes this very well could be,but if you want to be sure then have the oil pressure checked.If it turns out good then replace the oil sending unit.Hope this helps.Good luck.
Mar 16, 2010 | 1999 Chevrolet Silverado 1500
Oil pressure on a 2005 chevy 2500 8.1
your oil sending unit in the block is bad
Sep 18, 2009 | 2004 Chevrolet Silverado 2500HD
Oil guage quite working
Hi, this is a pretty common problem on these Silverado instrument clusters. We can repair it for you or provide you with the parts to do it yourself. Click here to learn more about these silverado instrument cluster problems:
Dr Speedometer Instrument Cluster Repair Speedometer Repair Guage...
Sep 06, 2009 | 2004 Chevrolet Silverado
Where is the oil sending unit on a 93 chevy silverado 350 engine
the oil sending unit is located at the back of the motor right below the rotor cap it is about 3 inches long and has a 3 wire plug hooked t it
Feb 21, 2009 | 1999 Chevrolet Silverado 1500
Drop in oil pressure
The oil sending unit could be bad, or the pressure relief valve in the oil pump is malfunctioning.
Jan 28, 2009 | 2003 Chevrolet Silverado 1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
