Question about LG Flatron 775FT 17" CRT Monitor
LG monitor hellow sir , i have problem with my LG monitor (15"studio works) , i will explain the problem here,first there was no picture and there was tickling sound also. after that i changed the LOT then picture has come . now problem is focusing the screen , in the montor menu H- position is working but H- size is not working. Kindly give suggessions to guide me to solve the problem.
  • anil_kr Jun 28, 2008
    hellow sir ,
Sir i had purchased 20 "led LG monitor B4 15 says.Now there is white , blue vertical lines in the led monitor. What is the problem
The monitor is defective and it needs to be repaired or replaced. Contact the place of purchase or the manufacture.
Feb 28, 2011 | LG L1915S 19" LCD Monitor
Hello sir, i hav LG CRT 15" monitor. After turning on, its LED continuous blinks and power button does not work and displays nothing. so plz suggest me what should be deffect?
Any 15-inch CRT-style monitor should be replaced by a 15-inch or 17-inch LCD-style monitor. You can find "previously-owned" monitors for $30 to $50, which is less than taking your CRT monitor to a TV/video repair-shop for an *attempt* to get it repaired.
Oct 04, 2010 | Computers & Internet
Lg 500g monitor blinking in bi-color, no display when powered up
Sir,
there could be two possibilties for that
1 That your serial cable is not working or have broken pin .
2 Another is that you monitors picture tube has got damaged or burnt.
Usually it is second reason it can be repaired but is more expencive so i would prefer buying new one.
Nov 08, 2009 | LG Studioworks 563N 15" CRT Monitor
Strange Display Issue
Although it could be a monitor problem, try deleting it from the Device Manager list under Monitor.
Then reboot your PC and if you are lucky, Windows will find it and reinstall the necessary driver.
Considering that it is an LCD, there aren't many ways it can cause that kind of display.
Aug 26, 2008 | LG Studioworks 570LS 15.1" LCD Monitor
Whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Aug 22, 2008 | LG Studioworks 45 14" CRT Monitor
My monitor changing green display .
1.First U can check any dry points in video section (Neck board).
2. check VGA cable
Aug 11, 2008 | LG Studioworks 563N 15" CRT Monitor
Horizontal size is not working
1.In horiztal section R778 - 1Ohmsor 2Ohms one watt,R749 - 2.2k,R753 - 2.2kcheck it.
2.check Q716 - C3198,Q714- C3198 Problem Replace all thease componants.
3.and also check Damper diode DMV32 (or)DMV1500, it's related componants
4. dry points in horizontal section
Dec 29, 2007 | LG Studioworks 563N 15" CRT Monitor
Problem in monitor
Hey vinay i guess its hardware problem ... coz software doesn recognise u hitting it ,,, ; )
Nov 28, 2007 | LG L1520B 15" LCD Monitor
Problem with Studioworks 563 monitor
LG Studioworks 563N Monitor horizontal width is exceeding out of screen and not able to adjust it along with pincushion through menu. IRF S630A Transistor replaced, no effect. Pl. help.
Nov 18, 2007 | LG Studioworks 563N 15" CRT Monitor
Flyback Tester
http://www.repairfaq.org/sam/tvfaq.htm
open it you will get more than enough what you want for
FLYBACK TESTER"
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
LG Flatron 775FT 17" CRT Monitor Logo
89 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
