Question about Canon PIXMA iP1500 InkJet Photo Printer
Clear paper on test print - Canon PIXMA iP1500 InkJet Photo Printer
  • Canon Master
  • 1,294 Answers
Check the ink cartridges,enter in the mantenace mode and select cleaning options and after select autocalibration.
Posted on Apr 20, 2013
Carriage jam message...........comes on no matter what.........reset several times
Solution one: Turn the All-in-One off and on again Turning the product off and then on again might resolve the issue. Step one: Turn the All-in-One off and on again
  1. Press the Power button (c01602202.gif ) to turn off the product.
  2. Wait 60 seconds.
  3. Press the Power button (c01602202.gif ) to turn on the product
Step two: Print a self-test report
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01461502.gif ). The Setup menu opens.
  3. Press the arrow button to select Tools , and then press OK .
  4. Press the arrow button to select Self-Test Report , and then press OK . The self-test report prints.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting.
  • If the issue persists , continue with the next solution.
  • If the self-test report does not print , continue with the next solution.
Solution two: Clear any jammed paper Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the rear of the All-in-One Use the following steps to check for and remove jammed paper from the rear of the HP product.
  2. Disconnect the USB cable from the rear of the product.
  3. Disconnect the power cord from the rear of the product.
  4. Squeeze the tab on the rear access door to release it, and then pull the door outward to remove it from the product Figure 1: Open the rear access door
  5. Gently remove any jammed paper from the rollers inside the product. CAUTION: If the paper tears while removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. Reattach the rear access door. Gently push the door forward until it snaps into place.
Jun 21, 2011 | HP Photosmart C5280 Printer
HP 6940 print head jammed.resume light flashing
Welcome to FixYa!
Usually print head/carriage jam is caused by paper jams or previously cleared out paper jams that left a small torn paper inside the printer.
Turn off the printer by pressing and releasing the power button.
After the printer turns off, press the power button to turn the printer on again.
The printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolved. (See instructions at the end of this article on how to print a self-test page.)
If the printer does not turn off, clear any paper jam. Press the resume button on the printer front panel. If the paper jam does not clear, continue with this procedure.
Leave the printer turned on, disconnect the power cable from the printer, and then disconnect the USB cable from the back of the printer.
Push the two latch handles on the rear access door of the printer toward each other, and then remove the door. Please refer to the image below.
Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
If the paper jam cannot be removed from the back of the printer, raise the printer cover, remove the paper jam from the front of the printer, and then lower the cover.
Remove the paper carefully. It is possible to damage the printer when removing paper from the front of the printer.
Reconnect only the power cable. If the printer does not automatically turn on, turn it on by pressing the power button.
Again, the printer might go through a warm-up period of up to 2 minutes. Lights might flash and the print carriage might move. Wait until this warm-up period is complete. Then try to print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
If the Power light is blinking and the print carriage is still in a stalled position, continue with this procedure.
With the printer turned on, open the printer cover. The print carriage might move into the access area automatically. Allow it to move to that position.
If the print carriage does not move automatically into the access area, turn off the printer by pressing the power button.
Disconnect the power cord from the back of the printer.
Looking in through either the ink cartridge access door or the output paper tray, make sure that no obstructions under or around the print carriage are blocking it from moving.
Make sure that the print carriage can move freely across the width of the printer by gently pushing the print carriage to the left and then to the right. Clear any obstructions.
Remove and reinstall the print cartridges. Make sure that it is properly installed back.
Close the printer cover and connect back the power cord.
Print a self-test page. If it is able to print, the issue is resolve. (See instructions at the end of this article on how to print a self-test page.)
To print a self-test page, make sure the printer is turned on. The USB cable of the printer to the computer must be disconnected to make sure that we are isolating the printer problem.
Press and hold the Print and Cancel button at the same time. Make sure that the printer is loaded with paper. The self-test page will like the image below.
Keep me posted of your developments.
Thank you for using FixYa.
Jas247
Mar 03, 2011 | HP Deskjet 6940 InkJet Printer
I have a jam on my printer that says there is a print carriage access jam how do i solve it
I have the same problem.... trying to use lubricants and done some cleaning, but no luck... till i found out that using an extension cord with several devices plugged in will lessen the amount of current that flows to the devices.. that's why the printer's motor can't able to do his job because of no enough power.... Connect the printer's plug directly to the wall...
it works for me....
---ritchie---
Jan 13, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
My printer comes up with a clear paper jam and press checked key. I have cleared all paper from machine and yet the light flashes and will not allow me to print and the same error code comes up. What...
Solution one: Turn the All-in-One off and on again Follow these steps to turn the product on, and then off again, to reset the print mechanism.
  2. Wait 15 seconds.
  3. Press the Power button (c01602202.gif ) to turn the product on again.
    NOTE: The product might go through a warm-up period of up to two minutes. The product lights might flash and the carriage might move. Wait until the warm-up period is complete before proceeding.
  4. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
  • If these steps resolved the issue , and the self-test report prints , there is no need to continue troubleshooting. Reconnect the USB cable, and then try to print again.
Solution two: Clear any paper jam Jammed paper can cause the carriage to stall. Follow these steps to clear any jammed paper. Step one: Remove any loose paper Remove any loose paper from the input tray and output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear a paper jam from the front of the product can damage the print mechanism. Step two: Clear the paper jam from the back of the All-in-One Use the following steps to check for and remove jammed paper from the back of the product.
  2. Disconnect the USB or Ethernet cable from the back of the product.
  3. Disconnect the power cord from the back of the product.
  4. Remove the rear door. Push the door latches toward each other, and then pull the door away from the product. Figure 1: Remove the rear door c00244379.gif Illustration of removing the rear door
  5. Gently pull the paper out of the rollers. CAUTION: If the paper tears when removing it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more paper jams are likely to occur.
  6. If you are printing labels, see if any are missing from the label sheet. If any labels are missing, find them inside the product, and then remove them carefully.
  7. Reattach the rear door. Gently push the door forward until it snaps into place.
Step three: Clear the paper jam from the front of the product Follow these steps to remove the paper jam from the front of the product.
  1. Open the cartridge access door. Figure 2: Open the cartridge access door c01913998.gif Illustration of opening the cartridge access door
  2. If you find paper jammed in the product that cannot be removed through the rear door, gently remove the paper through the front of the product.
    NOTE: Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism.
  3. Close the cartridge access door. Figure 3: Close the cartridge access door c01913999.gif Illustration of closing the cartridge access door
  4. Reconnect the power cord to the back of the product.
  5. Press the Power button (c01602202.gif ) to turn on the product.
  6. Try to print a self-test report. See the steps on how to print a self-test report at the top of this document.
Keep in this LINK.
Oct 26, 2010 | Dell 948 All-In-One InkJet Printer
Printer states "out of paper" when there is a lot of paper in the carriage. Have pressed "Print" button 5 or 6 times, so.....how do I clear all the print requests, and reset the printer to recognise that...
Please perform the following steps and check if the issue is resolved.
1. Please try to Printer a Self Test-page.
>Please press the Power button to turn the product on.
>Hold the Power button down.
>Continue to hold the Power button, and then open and close the carriage access door four times.
>Release the Power button
>Now, try to print a self test page and check if that works.
If the self test page does not works/print a test page, clear the paper jam.
Also, clear the paper rollers and if this does not work, perform a power reset to resolve the issue.
You can refer the link below to get the complete information to perform all the steps mentioned above.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00861130&cc=us&lc=en&dlc=en&product=3374275
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02125514&cc=us&lc=en&dlc=en&product=3374275
Good Luck!!!!
Jul 02, 2010 | HP D1560 Deskjet Printer InkJet
I have replaced my ink cartridges because the printer said they were empty. They were not. The printer also said it couldn't find the printer head or something...what do we do now to reestablish our...
  1. Run generaltool.exe or the application or executable file.
  2. Select USB port of the printer to be reset.
  3. Click lock release button.
  4. IN Select Destination option, select the printer model.
  5. In Test Print option, select EEPROM clear.
  6. Prepare a paper and then click test pattern 1 under Test Print option.
  7. Turn off the printer and turn on again.
For resetter which do not have Lock Release button
  3. In Select Destination option, select the printer model.
  4. In Test Print option, select EEPROM clear.
  5. Prepare a paper and then click test pattern 1 under Test Print option.
  6. finish it
Oct 21, 2009 | Canon PIXMA MP470 All-in-One Printer
Hp printers continue to jam
Print a self-test report Use the following steps to print a self-test report.
  1. Load plain white paper in the input tray.
  2. Press Setup , and then press 2 . The Print Report menu displays.
  3. Press 1 to select and print a Self-Test Report .
IMPORTANT! Try to print a self-test report after every solution even if the solution resolves the issue. Solution one: Clear the paper jam Follow these steps in the order presented to resolve the paper jam. Step one: Remove loose paper from the tray Remove any loose sheets of paper from the input tray and the output tray. CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism
Sep 08, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do i clear a paper jam
The Lexmark Printer you are having a very sensitive printer.
Normally this tyoe of Printers are very very slow in Printing job.
Comparing with other laserjet used.
If the Laptop / Printer are under warranrty, the Service engineer
can rectifity the printer jamming.
Solutins :
Make the Printer - Monthly service compulsory.
Use only good quality paper in the Lexmark Printer.
Do not pull the paper through hand, when the print out is coming.
Regards
Jul 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP 3915 paper jam error
I had the same problem and just talked with HP technician Neeta and she showed me how to fix it. It's a bit convoluted. In essence you have to clear the print spooler. Here is what she told me.
First you have to be clear that there really ISN'T a paper jam by printing a test message this back door way.
Neeta : The USB cable should be disconnected. Neeta: To print a self-test page, press and hold the Power button. Raise and lower the printer cover four times. Release the Power button, and the self-test page prints
If the sel-test page prints, this means you truly do not have a paper jam. Next, clear the print spooler
Neeta : The USB cable should be disconnected.Neeta : Now click on start->RUN.Neeta : Then type "services.msc".Neeta : Then it will open the services window.Neeta : Now please look for the option "print spooler. Neeta : Okay, now , please right click on the option "print spooler" and click on stop then click on start, 3 times.
Oct 27, 2008 | HP Deskjet 3915 InkJet Printer
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
23 people viewed this question
old marine
old marine
