Question about Manitowoc SY0854A Self Contained 870 lb Ice Machine
What causes the manitowoc ice machine to cut off during the freeze cycle
It just is cut out when it in the freeze cycle when building ice and cuts off for a few minutes and cuts back on
    Director Badge:
    Uploaded 100 video answers.
  • Manitowoc Master
  • 488 Answers
Most of the problems on ice machines is a restriction in water circulation due to no maintenance. Might need some cleaning to be done.
Posted on Jan 16, 2016
    New Friend:
  • 107 Answers
Usually that is just your power switch. They are easy to replace.
Posted on May 11, 2013
3 Suggested Answers
  • 112 Answers
SOURCE: Manitowoc Ice machine only makes 2/3 bin of Ice
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Posted on Jan 04, 2011
  • 22 Answers
SOURCE: My Manitowoc Ice machine is making ice slowly and
You're bridge thickness is set to high, lower the bridge on the sensor located when you open the front door behind the water curtain on the top. If the sensor is scaled badly replace it.
Posted on Feb 14, 2011
I HAVE A MANITOWOC QM30A ICE MACHINE. WILL THE LIQUID LINE THERMISTOR CAUSE IT TO RUN BUT NOT MAKE ICE?
Liquid line sensor on ice machines in general is used in conjunction with the control boards to determine defrost and harvest cycles. You could measure the line temp and chech the resistance of the sensor to check it.
Betabass
Sep 07, 2016 | Manitowoc QM30A Self Contained 65Lb...
My undercounder KUIS18NNJB5 icemaker freezes successfully but the ice does not exit the freeze plate completely during the harvest cycle. When the next ice cycle starts, the ice refreezes to the plat
In the manual the fix is to clean the ice maker with cleaner. Your ice slab is not releasing during harvest. The plate (evaporator) has minerals on it and needs to be cleaned to remove the build up. On the door of the unit has cleaning instruction, do not short cut the cleaning process, this does take about an hour and follow the instruction to the letter.
This is not a major issue, just cleaning is needed.
Dec 07, 2013 | KitchenAid KUIS18NNT 18" Automatic Ice...
Ice machince is going max freeze cycle shut down
1. Possible cause. Water leak. Check purge valve, water curtain, sump, sump hose.
2. Air filters clogged. Clean air filters.
3. Dirty condenser. Clean condenser.
4. Restricted location, intake air to hot. Have machine moved.
5. Ice thickness sensor dirty or disconnected. Check ice thickness sensor probe.
6. Water distributor dirty. Remove and clean water distributor.
7. Inlet water valve leaks through during freeze cycle. Check water inlet valve.
8. Connected to hot water. Check for bleed through from missing check valve in building water supply.
9. Incomplete harvest. Check harvest system.
10.High pressure cut out opened. Check fan motor pressure control, check fan motor, check controller using test mode.
11. Fan motor pressure control open. Check fan pressure control.
12. Fan motor not turning. Check fan motor, check fan blade,check controller using test mode.
13.Water pump not pumping. Check pump motor,check controller using test mode.
14. Pump hose disconnected. Check hose.
15. Compressor not operating. check compressor contactor, check controller using test mode.
Check compressor start components, check PTCR resistance and temperature, check compressor voltage, check compressor windings.
16. Low refrigerant charge. Add some refrigerant and restart unit. If cycle time imporves, look for a leak.
17. Hot gas valve leaks through during freeze. Check hot gas valve for hot outlet during freeze.
18. Thermostatic expansion valve bulb loose. Check bulb.
19. Thermostatic expansion valve producing very low or high superheat. Check evaporator superheat, Change TXV if incorrect.
20. Compressor inefficent. Check compressor amp draw, if low and all else is correcy, change compressor.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
It will not stay in harvest cycle long enough to make ice before it goes into defrost
First it has to go through freeze cycle then harvest cycle to drop ice then back to freeze cycle. If you have never worked on ice machines before you should call a service company.
Aug 16, 2013 | Manitowoc QY-0214A Self Contained Ice...
Ice maker Manitowoc QD-0212A
This light is a harvest limit light. This light's primary function is to be on as water contacts the ice thickness probe during the freeze cycle, and remain on throughout the entire harvest cycle. The light will flicker as water splashes on the probe. The lights secondary function is to continuously flash when the ice machine is shut off on a safety limit, and to indicate which safety limit shut off the ice machine. Start up of machine after turned off. !. Before the ice machine starts, The water pump and water dump solenoid are energized for 45 seconds to purge old water from the water trough. This ensures that the ice making cycle starts with fresh water. The water fill valve energizes after 45 second water purge, and remains on until the water level probe is satisfied. 2. to pre-chill the evaporator, there is no water for the first 30 seconds of the freeze cycle. 3. The water pump starts after 30 seconds pre-chill. An even flow of water is directed across the evaporator and into each cube cell.
Jul 13, 2013 | Kitchen Appliances - Others
My manitowoc series 420 has a code telling me the compressor discharge temperature
Which code is that? I don't see that in the service manual. There is an E09 that indicates that during the first six minutes of freeze the discharge temperature was below the average of the last 6 cycles. I have searched from E01 to E31 and don't see the code you indicate but I would say you either have a low refrigerant charge, a flooding TXV that is allowing too much refrigerant flow into the evaporator and not allowing enough flow to be diverted into harvest, or a weak compressor. Reset the unit and check the temperatures on the display while its running and time a freeze cycle. Should take about 15 minutes to make ice.
Jun 28, 2013 | Manitowoc ID-0452A 420 Lb Full Size Cube...
I cant get this ice machine to enter freeze cycle
Erik I just returned from surgery and sorry I missed your request. Anyway here is the Manitowoc Series Q 210 User and Service Manual The last three pages are a checklist of things we need to go over. I can help if you still have questions, Thanks Sea Breeze
http://get.adobe.com/reader/
Aug 17, 2011 | Manitowoc Series Q 210 Self Contained...
I have a Manitowc ice mach, mod QDO452A. The customer complaint, the machine stopped making ice. The mach failed 3 times. the 1st time the mach was unplugged when I arrived. I cleaned the machine ( annual...
Based on your finding on your second trip, the machine shut of on one of the safety timeouts that limit the harvest and freeze cycles. Its possible that the evaporator has lost some nickel plating and the ice is hanging, but first the heat build up in the storeroom is a problem if you get running again come back a few hours later and check the ambient temp in the room,its probably above the machine design temp. Can a vent be cut in the ceiling? an exhaust fan to **** that heat away would be good.
Jul 01, 2011 | Manitowoc MAN-CVD2075 Condenser Unit...
I HAVE AN MANITOWOC Q SERIES CVD 2075 UNIT RUNS FOR 30 MINUTES AND ONE OF THE DUAL FANS CUTS OUT CAUSING INSULATION TO BURN OF HOT GAS LINE PLZ HELP
Sounds like a bad headmaster valve, bad fan motor, or bad pressure cycling switch for the fan motor. Will need to know operating pressures to troubleshoot. Not really a DIY job unless you have some experience.
Sep 29, 2010 | Manitowoc MAN-CVD2075 Condenser Unit...
Ice machine starts on harvest mode and will not go on to production
you will have to find the main board unplug the connector for about a mintue plug back in. This should reset unit
Aug 05, 2009 | Manitowoc MAN-CVD2075 Condenser Unit...
Manitowoc SY0854A Self Contained 870 lb Ice Machine Logo
740 people viewed this question
Top Manitowoc Kitchen Appliances - Others Experts
John Tripp
John Tripp
mike cooper
Dan Webster
Dan Webster
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
