Question about Sony DVP-NS575P DVD Player
I have sony DVP-NS757. It comes black and white only most times on my grundig and seleko tv. Can you solve this for me please. My email is borggeorge@hotmail.com Thanks in advance
  • 119 Answers
SOURCE: Picture in Black & White
if you are using composite cables (yellow,red & white), make sure your yellow (video cable) is into the yellow output. if you plugged the wire into the green on the back of the dvd it will give you a black & white picute. But if it is in the yellow then you most likely have a problem with the dvd player that will need to be taken to a service center.
Posted on Nov 03, 2006
MikeNJ1964
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
SOURCE: I cant view DivX Film Subtitle in Sony DVP-NS67P home DVD player
Hi Ramink..
Try the program Sub2Divx (I have the same DVD sony dvp-ns67p worked properly). It takes just 2 minutes to put the subtitle in divx and is not fixed, only appears when tight subtitle on the remote control. I have a link to a tutorial but it is in Portuguese. (http://www.forumpcs.com.br/viewtopic.php?t=195697)
[ ]'s
Ricardo Liu
Posted on Jan 17, 2008
SOURCE: Only black and white
If you are playing different region dvds, they can be of different color formats also
(US = NTSC, Europe = PAL). If your television is not multi-format then non-compatible
DVDs will play black and white. The solution is to purchase a mutli-format TV (accepts
both PAL and NTSC formats)
Posted on Jan 29, 2009
Shuttle83
  • 1139 Answers
SOURCE: I just purchased a Sony DVD player...DVP-SR200P.
Hello cherylsacket,
Check your cables to your TV. If possible check the various cables to your set. I would suggest using the HDMI cable if your TV has an HDMI input. Remember to power off all devices before connecting your cables. If I may ask which cable are you using to connect between your Tv and the DVD player?
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on May 10, 2009
I am only getting black and white pictures when using the sony dvd -DVP-SR200D when hooked-up to tha TV
Change your tv colour System in to Auto mode.It will adjust in menu.Mostly DVD recorded on NTSC 3.58 colour system.After adjust on auto mode Colour will come.
Oct 30, 2010 | Sony DVP-SR200P DVD Player
Why is it that some dvds only play in black n white?Is there any way to fix this?
Your solution may be to connect your cables to the front of your tv, instead of the back as found here:
http://www.velocityreviews.com/forums/t699272-problem-solved-for-dvds-showing-in-black-and-white.html
Sony also supports this solution, as found here:
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&externalId=C89600&fes=true
Sony also advises it may be due to a faulty cable or if the signal is being transmitted via a vcr.
As per this site:
http://www.gaiaonline.com/forum/computers-technology/sony-dvd-player-only-plays-in-black-and-white/t.41173519/
if your s-video cable going to your tv is loose or is faulty, then only 2 of the 4 pins are communicating with the tv, thus resulting in a black and white picture.
Jun 28, 2010 | Sony DVP-NS51P DVD Player
When connected to my TV there is no color but there is color on the Player?
If you are saying that when your DVP player is connected to the TV, it is showing black and white, then you might need to press the NTSC/PAL button on your DVD's remote control. Press that button until color comes back.
Oct 05, 2009 | Sony DVP-FX930 Portable DVD Player
I have a black screen on my sony dvp fx 720,sound is ok and the connection to the tv works fine.
pls.post me the solution for my dvd player on which the screen is black sound is ok and the connection to the tv works fine.my email address . pp2240@yahoo.com
Sep 07, 2009 | Sony DVP-FX720 Portable DVD Player
Just comes up in Black and White
CHECK COLOUR SYSTEM- SHOULD BE SWITCHED TO PAL
Aug 01, 2009 | Sony DVP-NS305 DVD Player
Aug 31, 2008 | Sony DVP-NS50P DVD Player
Only black and white movies
your tv is posibley on svhs instead of av1 or av2
have a look at the logo that comes on when you chose the channel
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Sony dvp ns50p dvd player
Sep 01, 2007 | Sony DVP-NS50P DVD Player
Can some one help on this? Sony NS50P
U must be using an old tv with only PAL color system. DVDs are in different color coding. Try using a PAL converter it will solve ur problem
Dec 17, 2006 | Sony DVP-NS50P DVD Player
Sony DVP-NS575P DVD Player Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
