Question about Casio Beside BEM501L7AVDF WW Watch for Men
Casio beside watch second hand misalignment
The second hand does not align with the markings on the watch
3 Suggested Answers
escapement
  • 2334 Answers
SOURCE: The analog portion of my Casio watch has a
You will need to remove the crystal, but without proper watchmaking tools and skills you will not be able to do the job. If you do not want to damage your watch, you have to find your nearest watch repair shop and ask to fix it.
Posted on Aug 10, 2009
escapement
  • 2334 Answers
SOURCE: stop watch hand is resetting wrong
Click on my name (escapement), then click on TIPS AND TRICKS. Browse through all and you will find the link to all CASIO watch manuals. Rate me, please.
Posted on Jun 24, 2010
Sir..my casio watch second hand isnt moving suddendly and the minute hand is moving freely.
Hi Sanen
What model is your Casio watch?
For what you describe it would appear as if there is a problem with the cockwheels assembly on your Casio watch. Most likely as a result of a severe impact. hard enough to dislodge the retaining plates or break of the bottom of the minute hand spindle.
Hope this helps
Dec 19, 2016 | Casio Watches
I bought a casio watch (model AMW-320R, I think that is the model number) with both a tradiotnal hour, minute, second hand and digital readout. The digital readout is fine but the second hand on the...
Normally this is the battery... Try the battery before considering to send the watch to Casio for service. Or, if you send it they will fix it and send it back. They are not very expensive for their service.
Jan 26, 2018 | Casio Watches
Hi, in my seamaster 2221.80 quartz most of the clicks of the seconds hand does not align with the second markers.is this normal & can it be re-calibrated. its a little out of character from an...
A competent watch repair technician can remove and reset the second hand on your watch so that it more precisely aligns with the seconds markers on your dial. However, it may not be possible to get the hand to perfectly align with all 60 markers around the dial. It is not uncommon in cheaper watches for this misalignment to occur, either because the dial has shifted slightly from its original placement on the movement (for glued-on dials) or because the second hand was not carefully aligned when it was initially installed. This problem is less common in watches where the watch dial is more precisely attached and aligned with the movement via screws.
To perform this service, the movement is typically removed from the watch, so this is not a 10-second job. Sometimes, the watch crystal is removed instead, but this may take more time and reduce the water resistant properties of the watch. Either way, if your Omega is still under warranty, this may be a valid claim for service.
Once the second hand is properly aligned, this problem should not re-occur.
May 06, 2011 | Watches
Dear Sir/madam, i bought the watch yesterday (model no BEM-501L-7AV). the day hand is stuck at sunday. i didnot get any manual along with the kit, so i am unable to adjust the same. kindly help.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Feb 07, 2011 | Casio Beside BEM501L7AVDF WW Watch for Men
Showing 6ae on my Tissot T touch. Also cannot synch properly
Press the center button marked "T". The watch should beep once;- Touch the center of the touch-sensitive face until 24H Cm appears in the digital LCD display;
- Press and hold the center button marked "T" for approx. 5 seconds. The watch will beep once and then again a second time, after 5 seconds have passed. The digital LCD display should now read SYNCHRO;
- Press the upper button marked "+" to move the minute hand until it is positioned exactly at 12:00;
- Press the lower button marked "-" to move the hour hand until it is also positioned exactly at 12:00;
- When both hands are aligned together and pointing directly at 12:00, press the center button marked "T" to save your settings.
- Your watch is now synchronized, so no expensive repair work is required!
Jan 24, 2011 | Tissot T-Touch T33759851
Stop watch hand is resetting wrong
Jun 24, 2010 | Casio AMW330-7AV Wrist Watch for Men
Casio aw-s90, analogue and digital time are not in sync. The analogue is about 2hr 25mins behind
If you haven't got instructions on how to align the hands with the digital display , you can get instructions from the Casio web site.
watches;
Accept terms
Jun 08, 2010 | Casio AWS90-9AV Wrist Watch
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Beside BEM501L7AVDF WW Watch for Men Logo
85 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
