Question about Aiwa NSX-DS55 CD Shelf System
Problems with CD player, keeps on skipping while listening to mus
It is an Aiwa product, 3disc-player, nothing wrong with the disc (new) but when i press play it starts of okay, but then it seems to skip some of the music.
  • 247 Answers
Make sure it is clean first of all. Use a cotton swap and clean the optical eye. If that doesn't work and you are somewhat handy try the following.
To start with, make sure that your CD player is suffering from the problem that this method is designed to fix. This method is designed to fix a misaligned CD read head. The common symptoms of this problem are:
1. You place a CD in the player, and it spins for a bit but never finds the list of tracks on the CD and returns some kind of error. This problem may occur regularly or intermittently.
2. CDs tend to skip frequently, even if they are clean and in good condition.
So if this sounds like your problem, then this method is for you. You should however bear the following in mind: only attempt to fix the CD player if the fault occurs frequently and is really annoying; i.e. if you are thinking of throwing the CD player away. To carry out the repair you will have to open the case. This will certainly render void any warranty the device might have, so if your player is still under warranty, don't open it. Simply return it to the retailer. Finally, for your safety and that of your equipment be sure to disconnect your CD player and remove any batteries at least a half hour before you start work. Finally, although I have had consistent success with this method, everything you do is at your own risk and is your own responsibility. I provide no guarantee of any nature regarding this method.
Your first job is to open up the case of your CD player. This will be more or less difficult depending on the type of device. If you are lucky and have a Hi-Fi separate type device then it will be pretty simple; if you have a mini or midi-system with a built in CD player this could be trickier. Fixing portable CD players (e.g. a Discman) is probably only for the uber-patient as it is likely to be very fiddly. The main thing required here is patience and a methodical approach. As you remove screws put them somewhere safe; line them up in the order in which you removed them, or make notes of what goes where. You may reach a point where you think you have taken all the screws out but you still can't get into the case. Here, patience is still the key. Check under stickers for hidden screws or clips. Try and work out where the case is held together. Use the minimum force possible at all times.
Now, assuming you have managed to get into the case successfully, and have got access to the CD player we can continue. By now you will probably be able to see the CD tray (the bit that holds the disk) and also some kind of arm which hovers over the disk when the tray is closed. There will usually be a small motor for moving the lens over the disk, and attached to this or nearby there is typically a small circuit board.
On this board, or in any case rather close to the read head there can usually be found a small potentiometer (sometimes referred to as a pot). This will usually be a small square component with a plastic disk on top, and this disk will have a slot which is designed to take a small flat head screwdriver. This is what we will be adjusting.
However, before doing this it is advisable to use an indelible marker pen (magic marker) to mark the current position of the Potentiometer, so that it can be returned to its original position if necessary. With this done then we are ready to start fixing your CD player.
This is essentially a trial and error process. You make a small adjustment to the position of the potentiometer, then try the CD player and see if it is improved. In my experience generally only small adjustments (less than plus/minus 30 degrees of rotation) are usually necessary.
Depending on how comfortable you are working with electrical devices there are different ways of going through this trial and error process. If you are unsure of yourself or particularly safety conscious then will probably want to put the case back on the CD player each time you test it because you will probably have to plug it in to do this. However, as you have probably guessed it is not necessary to put all the screws back in.
Kurt
Posted on Mar 17, 2009
  • KMusselmann
    KMusselmann Mar 17, 2009
    clean the optical eye first. If that doesn't work try the following if you are handy.
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
Why does my cd player say cd error & make cd skip
cd magazine/ player is going bad. most likely its the springs that keep it balanced while it spins the discs
May 14, 2014 | 1999 BMW 323i
Cd player skips
CD disk bad. (audio disc bad or scratched)
or CD dont really support disk media format , is this a CDDA or MP3
some early MP3 disc drives do MP3 very poorly
or skips when you hit bumps in the road.
only that disc skips.?
Dec 23, 2013 | 2005 Toyota Sienna LE
I have an Aiwa z650 3disc cd player,the disc spins a couple of times and then stops I'm told the potentiometer may need adjusting,I've taken the case of but can't find this thing
Not sure bout that ,,usally when it spins a few times and thats it,,motor wore out,,,put a disc in try as it stops spinning or right wen its fixon to start spinning given it a help spin,,i had that fix or getem goin,,,,also try tapping it ,,and hitting the side od the machine,,good luck,,
Dec 23, 2011 | Aiwa Audio Players & Recorders
Aiwa Dual CD Burner, cd's skip and sound scratchy
memorex and kyphermedia WON'T work in this recorder FYI Don't know what brand will
Jan 19, 2011 | Aiwa XC-RW700 2-Disc CD Recorder
CD is skipping
Probably need to clean the lens inside the player. If you have compressed air you can GENTLY spray inside the tray to remove dust, otherwise go to Walmart and buy a CD cleaning kit to clean your lens. If it still skips then you might have a bad disc or player
Hope this helps
TankMurdock
Apr 27, 2009 | Aiwa NSX-D30 CD Shelf System
Car cd player skips on bumps
This can happen for several different reasons.
1. The dampers (oil filled shock absorbers) are leaking and need to be replaced. You can check this by taking the unit out and opening it up and then remove the CD deck. In each corner of the CD deck you will see a small rubber looking device that the internal mech floats on when a disc is engaged. It is attached to the internal mech by only a small metal peg. Check each corner for these. Make sure they are not leaking anything. It is usually a white looking substance that feels like grease. Ant time even one of them go bad or get popped out of place, it will skip on every bump.
2. Try cleaning the lens. Sometimes a dirty lens will make the CD player skip much easier than it is supposed skip. You can buy a cleaning disc at most retail outlets that sell CD and DVD players. Run it as directed in the instructions.
3. one or more springs are streched out a little. These mechs have many springs in them and if one is a little streched it will cause skipping. If you find a loose spring, it will need to be replaced.
4. Weak laser output. A weak laser will also cause a unit to skip. If this is the case the laser pick up will need to be replaced. There is no fix for a weak laser other than replacing it.
5. Spindle motor problems. A spindle motor with even a tiny bit of oxidation in the windings can cause skipping when you hit a bump.
There are also a few other things that can cause this same issue. It is not an easy thing to fix without some training on this type of equipment.
Is this an "Aiwa"  or is this a factory unit that cmae with the car when it was brand new. I don't think that Aiwa is an OEM radio, but I could be wrong. I fix aftermarket radios only.  So I am not real familiar with all the OEM models.
If this is an aftermarket Aiwa radio, you should take it to a service center to get an estimate. If it is an OEM radio, it is most likely going to be very expensive to fix and a good aftermarket radio would really serve you better.
I am sorry if this is not the answer you were hoping to get, but it is the truth so I hope you will not punish the messanger for bringing bad news.
Anything less than a "helpful" rating is a very bad rating meaning that you got no help or that the help was not related to the problem. I spent a lot of time putting this information out here for you for free, so I only ask that I get a decent rating for my trouble.
If you require any more help feel free to post another comment on this thread with any questions you may have. I will be happy to answer them for you.
Dave
Jan 22, 2009 | Aiwa CDC-X227 CD Player
Car cd player kipping
Is it anti-skip resistance? If not some players have hard problems playing when heavy bumps. Also is it installed correctly? Was all shipping plugs taken out?
Sep 10, 2007 | Aiwa CDC-X227 CD Player
Aiwa NSX-DS55 CD Shelf System Logo
201 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
