Question about Garden
2003 Bolens riding mower, (13an683g163). Having overheating problems after a good 20 min of cutting grass. Has fresh oil. Any ideas?
  • 52 Answers
SOURCE: craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: what oil grade do I use in my 20hp huskavarna riding mower
use a good grade of automotive engine oil which is called 10w30 weight.
measure the amount of oil that you drain out so you will know approximately how much new oil to put in. then check your dip stick and adjust to get the exact amount of oil.
Posted on May 21, 2009
  • 125 Answers
SOURCE: A row of uncut grass left between blaces when mowing
Mowing too fast for the blade speed. Use higher engine speed or lower gear.
One or both blades too short?
Posted on Jun 16, 2009
cpt_cavman
  • 69 Answers
SOURCE: Blades won't spin on Craftsman II riding mower
get some one to sit on it and holding the brake try engaging the clutch...now with out getting to close laying down you can see if the linkage is working right....might just be a missed belt wheel.
Posted on Jun 24, 2009
  • 138 Answers
SOURCE: 2003 DLT3000 Craftsman riding mower. Air in tires
when you put the new blades on did you notice if they were even with each other? the 42" decks have a tendency to "warp" inward on the left side. this causes the left blade to ride at an angle to the right blade - there is a tool to correct this, but not all shops have it - sometimes you can remove the deck, flip it over and wallop the inside edge of the left mandrel until the blades are even - a 2 lb. sledge works well for this
Posted on Aug 26, 2009
John Deere LA105 lost power
Hi Hank:
Did you hit something with the mower, or did it happen gradually?
Probabaly a good idea to start with a basic service:
- Clean air filter
- Clean fuel filter
- Flush carbuerettor
- Fresh gas?
- Change spark plugs
- Change oil and filter
- Underside of mower deck clean and free of all built up grass?
Hope this helps.
May 09, 2015 | John Deere Garden
My mower keeps overheating
Make sure the engine has no garbage around it such as grass and leaves. All air passages need to be clear. Clean grease and oil off the unit also will help it run cool Make sure the oil is up where it should be. Do you change the oil? Do you over work the mower for it's size
Trying to cut in a hurry will over work the unit in long grass
Sep 23, 2014 | Garden
Bolens 11a 074e065
Empting the gas tank and filling with fresh gas may take care of the problem.
Sep 28, 2013 | Mg International MasterCut 20" 123cc Push...
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
I have a Simplicity Zero-Turn 20 hp 50" cut. Just recently when mowing I have "clumps" of grass all over the yard. Any idea what would cause this? Also, the mower is supposed to stipe the lawn - I have...
Hi, well you have the cutter too close to the ground, try raising it up a couple of notches.
Now as for the "clumps" on the lawn. Well IF you mean GROWING clumps, that's because the mower is dumping the cut grass in a pile, somewhat, and that's adding nutrients to that particular Patch, and it simply grows faster because it's got more "Food".
If you mean, CUT grass patches, then again your Cutter is Too Close to the ground, and it's dragging the cut grass, and then when it gets too much, it is "packeting" the cut grass, every now an again when it builds up and is left in "piles" instead of being evenly distributed, and driven into the ground, behind the mower.
Aug 25, 2010 | Garden
My Bolens riding lawn mower wouldn't start.
I will attempt to help you figure this out. On a sidenote; the shop I work at offers pick up and delivery services, Im sure a shop near you would too.
First make sure you have good fuel in the tank and that any fuel valves are open, check your oil and make sure it is full. If your oil is overfull and very thin and runny that could be an indication of your problem. REmove the airbox cover and air filter.
Once we've covered that lets get on with diagnosing it. Will the motor turn over but it just wont start? Does the motor make a half crank then stop? Will it not do anything at all?
Answers to those questions and any other pertinent information will help me guide you in a direction to figuring out the problem. Figuring these things out is simple if you take it step by step.
Dec 29, 2009 | Garden
Husqvarna YTH20K46
Is this the first time cutting grass with a lawn tractor?
How tall of grass?
Use the grass cutting heigth adjustments on the tractor to a higher setting when cutting tall grass. Cut again to a lower height setting on the second pass. Grass higher than your tractor is not good for your tractor. Follow the manual instructions for best results.
Jun 27, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
BOLEN RIDING LAWN MOWER 13AN683G163 TRANSMATIC DRIVE. REPLACED BELTS AND THE MOWER RUN IN 7TH SPEED AND SLIP WEHN I TRIED TO PLACE IN LOWER SPEED
Either the belt routing is incorrect or there is a tensioner which needs adjusting. Recheck your belt installation. Oh, it could be the wrong belt, too.
May 01, 2009 | Garden
Blades are engaged,but won't cut the grass
Check the blades to make sure that they are not upside down
Apr 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
