Whirlpool front loader 4.0 duet. It will start but it will not drain. It does not have a not show display codes. We clean the trap thinking this maybe the problem. But still doing the the same thing.
Whirlpool front loader 4.0 duet. It will start but it will not drain. It does not have a not show display codes. We clean the trap thinking this maybe the problem. But still doing the the same thing. Help.
    President:
  • Washing Mach... Master
  • 662 Answers
Http://www.youtube.com/watch?v=2abTptUYXH8
See first if your washer plug is tightly screwed, wires. Click if helped.....
Posted on Apr 23, 2013
aborcass
  • 2651 Answers
SOURCE: Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
Posted on Mar 23, 2008
jsrock516
  • 5911 Answers
SOURCE: Whirlpool Duet front loader - won't spin
Does the wash tub spin freely by hand? If the tub does NOT spin by hand, the rear tub bearings may have seized up or something could be bound around the spin basket shaft (I've seen this one before). Let's hope it's not this problem.
If the tub DOES spin...have you checked to see if the drive belt was still on (sorry...I have to ask that question. I'm not trying to insult your intelligence here, but I have seen this one too).
Do you have the tech sheet that came with the washer? It's located behind the lower panel under the door, or taped to one of the interior cabinet walls. This tech sheet will explain to how to troubleshoot the symptoms you are describing. I suspect you may have a bad motor control unit (MCU) or bad motor. There are several voltage and resistance readings that you will need to perform in order to isolate the problem. It's odd, however, that diagnostics does not pick up any error codes. Normally, an error code will be generated if there was a no spin problem. It just doesn't make sense...Please post back and let me know.
Posted on May 19, 2008
  • 1122 Answers
SOURCE: Error code F 02 whirlpool duet GHW9100LW?
unplug for 5 minutes then plug back in see if it resets itself,also check the door switch on inside of the door on washer make sure that has a clicking sound,sometimes on some models if the door switch goes bad it will not spin or drain,let me know,thanks-mike
Posted on Jul 26, 2008
  • 1294 Answers
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Posted on Apr 08, 2009
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
My Duet front loader.. once it starts washing it stops and an error f2 code comes up and it will not complete the washer the clothes are left wet. if i move to spin only it still wont same code comes up
Hello & Welcome to FixYa
F2 is a drain error in your washer, if the unit is unable to drain then after 4 minutes it will display suds and then F2. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet HT front loading automatic washer, it's not draining & last time it did this a repair man came and showed me how to get underneath and drain it, but I don't remember how
The following link explains how to access the drain pump on a Whirlpool Duet front loader to clean out the trap:
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If you are experiencing drainage issues and cleaning the pump does not work, you may have to replace the drain pump. You will usually experience an "F2", "SUD" or "F21" error code (depending on model number) for a drain blockage problem. Since this error code occurs when the drain cycle exceeds 8 minutes, if the pump motor or impeller becomes damaged, the pump will not pump at the required volume and the error code will continue to occur. Replacement pumps can be purchased on line at:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop all of them for the best deal.
NOTE: Make sure you also check the drain hose and the inlet hose that runs from the bottom of the wash tub to the drain pump. Small articles of clothing can commonly get lodged in this area.
If you have any questions, please let me know. I hope this helps you.
Nov 01, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
MY WHIRLPOOL DUET FRONTLOAD WASHER BEEPS AND CUTS OFF 2 MINUTES BEFORE CYCLE ENDS DISPLAYING F 02 CODE?
The F 02 error code is a long drain problem. It could be that there is something clogging the drain line or a kink in the line, the drain pump trap is clogged, something lodged in the drain pump or the drain pump not working properly.
Here is some info I found on this site to help me clean out the drain pump trap and to replace the drain pump if cleaning it out doesn't work for you.
http://www.fixya.com/support/r401845-replacing_drain_pump_whirlpool_duet
Aug 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I recieve a 02 F code on my Duet front loader
02 means = Long Drain
Solution -
  • If the above does not correct the problem, replace the pump.
Jul 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I keep getting the f 02 error on my whirlpool duet front loader. The hose is clear and I can here the pump running. I need to clean out the pump filter but don't know where it is.
Potential Causes
Jun 22, 2009 | Whirlpool AWM5125/1 Front Load Washer
Error F21 with humming sound, then goes to Error 5d
Yes, your F21 is a clogged drain.
Remove the front panel. Unscrew the drain cap and clean it.
Apr 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Front loader
actually the code is probably fh which indicates no water in tub ..possible causes would be water siphoning out due to low drain or tight fit in stand pipe ..if these are ok suspect flow meter ..the small round object on left with 2 small hoses attached 1 from fill valve other to dispenser...also possible pressure swith on right side ..suspect flowmeter 1st if it has one
Nov 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT Has F error & won't drain & spin
I agree a F code of 21 or 2 I would clean the pump and check the bellow behind as well the pump entry from the trap for debris or a broken impeller.
Sep 08, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washing Machines Logo
1,094 people viewed this question
Top Washing Machines Experts
