Question about Kenmore 57029 Side by Side Refrigerator
Fridg no longer making ice or water
I have a kenmore fridge that has stopped making ice and water no longer comes out. Could this be a problem with the filter or would it only be the line?
  • 183 Answers
Turn off defrost, check inlet valve if this does not resolve the PCB is faulty. Regards Advisor
Posted on Aug 31, 2007
    Novelist:
  • 159 Answers
It could be a frozen filter. If it is a fridgidair made unit they did have that problem with the filter freezing and put a fix kit out to correct it. you also should check he water valves make sure you are getting power to them when you press the water arm. If its electronic it could be a bad dispensor control bord. with kenmore its hard to say because different manufactures make there products.
Posted on Aug 03, 2007
SOURCE:
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
There is no ice and no water coming out of the ice dispenser
You dont say if it quick making ice. First check to see if water is coming to the fridge from under the sink. If so that is a two chamber valve on the back of the fridge one side water for drinking and one fror ice making check the two coils. That probably has to be repaced. If its still making ice but not comming out the a swithc or lever is not activating in the door.
Apr 21, 2010 | KitchenAid KSCS25FKSS Side by Side...
Underneath the freezer drawer builds up with ice (have to chip it off a (makes opening the freezer difficult) and sometimes when I open one of the fridge doors (does not matter which door) water pools...
it seem that you have a clogged freezer drain. you can fix this by first turn off the unit leve all door and let it thaw about 4 to 6 hours or longer. if this doesnt cure the problem then repeat above procedure but this time open the plastic cover on the freezer and clean out the drain make sure all drain are unclogged also while your at it check the operation of the drain heater pan underneath the unit. and lso check the operation of the defrost timer. hope it help you.
Sep 18, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker is leaking water into the ice container making a block of ice . leak seems to be in the front of the mold and heater assembly thanks for your help in advance
make sure your fridge is level. if water just keeps flowing, there may be an obstruction in the solenoid valve that lets the water flow or stops it. it's in the rear of the fridge where the water line attaches. usually blue or white plastic on a brass mount. you'd need to shut the water off, let it depressurize, disconnect the pipe (some water will come out), replace that valve, or take it apart to clean it.
Jul 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore model 46 76249 (22 CU F OVR
Freezer must be 12* F for making ice
May 13, 2009 | Kenmore Refrigerators
Ice maker stopped working, plus fridge not cold, but freezer o.k.
I would check that fan motor in the freezer section is running. it distributes cold air from freezer into refrig section also if this motor is running the top portion of freezer will not get cold enough to allow ice production. the motor is easy to repl and is mod# specific you should be able to buy one online.
Jan 21, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore fridge ice maker not working
only two things this could be, either your water valve is bad or your icemaker is bad. you can get a kit which comes with both for a little over a hundred bucks, and you can change them yourself.
Mar 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
