Question about Eddie Bauer Analog/Digital Dual Time Watch, Black
Eddie bauer watch with 2 batteries - Eddie Bauer Analog/Digital Dual Time Watch, Black
The hand on the 1-31 days fell off and is lose in the face of the watch
mcdevito75 here, Look for a small watch repair shop in your area for repair.
Jul 09, 2010 | Eddie Bauer Watches
Cannot get the back cover on my eddie bauer watch after replacing battery
Watch makers/technicians use a special press to replace the back. You can get these presses but the cost can be more than it is worth.
Since the watch is most likely water resistant and you will have to go to a watch maker/technician to replace the back anyway I recommend having the rear seal inspected and replaced if needed and having the watch pressure tested to be sure that it is sealed to factory specifications.
Sep 24, 2009 | Watches
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 | Watches
Eddie bauer ibeam watch
If your watch is the same as mine, push the mode button 4 times, which will put you in the alarm menu (AL 1). Then, push the ST/STOP button until "chime" disappears.
Jan 25, 2009 | Bulova Watch
Get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jan 16, 2009 | Timex Expedition 84601 Wristwatch
Can't turn off alarm
press mode four times until you get to the alarm screen (on mine it is four), then press start/stop to cycle through turn the alarm on, chime on, alarm off, chime off
Dec 26, 2008 | Watches
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Pry off back of eddie bauer watch
s this watch have little notches around the edges of the back? If not look around the edge for a LITTLE notch. Take a knife such as a swiss army, or one that has a little meat to it, and put it in the knotch and pry up. If you still have problems PLEASE tell me , and I will be glad to assist you.
Aug 13, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
Eddie Bauer Analog/Digital Dual Time Watch, Black Logo
Top Eddie Bauer Watches Experts
Jimmy Accardi
Are you an Eddie Bauer Watch Expert? Answer questions, earn points and help others
