Question about Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone
How to block my mobile ip address - Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone
How to unblock a normal website getting blocked in fortigate 110C
it might be blocking it on ip address for an offending website and the other normal education website may be on the same ip address. may need to alter the ip address being blocked it may be based only on the network address for the banned web site rather than using a full host address. as an example in laymans terms say banned site was as a made up ip address 103.34.50.1 and say as an example the other web site was 103.34.50.2 and your firewall blocks 103.34.50.?? this means block ip address 103.34.50.0 thru to 103.34.50.254 this is what I meant by a network address usually denoted as 103.34.50.0 the 0 is the network identifier
Sep 17, 2015 | Computers & Internet
Tip
Gprs & MMs settings for england cellphone networks
&gt;T-MOBILE GPRS SETTING <br /> <span> </span>#Account Name - T-MOBILE GPRS <br /> <span> </span>#Username : user <br /> <span> </span>#Password: wap <br /> <span> </span>#Homepage: http://wap.t-mobile.co.uk/ <br /> <span> </span>#GPRS APN address: general.t-mobile.uk <br /> <span> </span>#Gateway (IP) address :149.254.001.010 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Port number: 9201 <br /> <span> </span>#Authentication: Normal <br /> <span> </span>&gt;T-MOBILE MMS SETTING <br /> <span> </span>#AccountName:- T-Mobile <br /> <span> </span>#Data Bearer:- GPRS #User name:- mms <br /> <span> </span>#Password - T-mobile tell you this when you register <br /> <span> </span>#APN:- general.t-mobile.uk <br /> <span> </span>#IP address:- 149.254.211.10 <br /> <span> </span>#MMS Server:- http://mmsc.t-mobile.co.uk/ <br /> <span> </span>&gt;ORANGE GPRS SETTING <br /> <span> </span>#Account Name :- ORANGE GPRS <br /> <span> </span>#Homepage: http://orange.multimedia/ <br /> <span> </span>#APN address: orangewap <br /> <span> </span>#Gateway (IP) address : 192.168.071.035 <br /> <span> </span>#Username : Multimedia <br /> <span> </span>#Password: Orange <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: NormaL <br /> <span> </span>&gt;ORANGE MMS SETTING <br /> <span> </span>#AccountName:- Orange <br /> <span> </span>#Data Bearer:- GPRS <br /> <span> </span>#APN:- orangemms <br /> <span> </span>#User ID:- Orange <br /> <span> </span>#Password:- Multimedia <br /> <span> </span>#IP Address:- 192.168.224.10 <br /> <span> </span>#MMS Message Server:- http://mms.orange.co.uk/ <br /> <span> </span>&gt;VODAFONE GPRS & MMS SETTING <br /> <span> </span>#Account Name - VODAFONE GPRS <br /> <span> </span>#Homepage: http://wap:1999/vodafone.wml <br /> <span> </span>#APN address: wap.vodafone.co.uk <br /> <span> </span>#IP address: 212.183.137.12 <br /> <span> </span>#Session type: Continuous / permanent <br /> <span> </span>#Authentication: Normal <br /> <span> </span>#Security: Off <br />
on Jan 11, 2011 | Cell Phones
What is the ip address of huawei y200
If you want to know the IP address of your mobile then go the site IP-Details.com from your mobile and you can find the IP address of your mobile .And if you want to renew the IP address of your modem then you can simply switch of the phone and remove the battery for a particular period of time and after that switch on the mobile and check your IP address on the same site.
Jun 05, 2013 | Cell Phones
Change ip address
You can change the IP address of your mobile by simple switching of and removing the SIM for few minutes and after that insert the SIM and switch on the mobile .It may change the IP address for sure .And to check the IP address of the mobile you can use the site IP-Details.com .
May 17, 2013 | Cell Phones
How to block lan IP
IP filtering is a method used to block computers on an internal network from accessing the Internet. This is often used on critical machines on the network, such as servers. It blocks users from accessing the Internet to protect these machines from malware. You can filter IP addresses on your router using the administrator console provided by the router's manufacturer. Once the block is set up, each user machine listed in the filter settings will no longer be able to access the Internet.
Open your web browser and type in the IP address for your router. For most default settings, the IP for the router is 192.168.1.1. Enter your admin username and password. If you have not set them up, try leaving the username black and the typing "admin" for the password. Click the "Security" tab at the top of the window. This opens a new console screen. Within this screen, click the "Filter" link. A list of text boxes is shown where you enter the IP addresses you want to filter. Enter a range of IP addresses you want to block. You can enter one IP address or several. Click the "Save Settings" button. Hope this helps.
Dec 07, 2012 | D-Link DSL-2540B ADSL2/2 Modem with 4-Port...
How do i get to change or edit the IP address of my sharp sidekick lx pv300?
The IP address is assigned based on where your connection from. It's the MAC address that'll never change.
So if you have a blocked IP. Try connecting from somewhere else. If your still blocked. Then they blocked your MAC address which means you'll never get back on to where ever with that phone
Aug 23, 2011 | T-Mobile Sidekick II
Facebook blocked
give the ip address of facebook
Jan 04, 2011 | Facebook Social Network
196.11.240.251
IP address: 196.11.240.251 IP country code: ZA IP address country: za.png South Africa IP address state: Gauteng IP address city: Sandton IP address latitude: -26.0500 IP address longitude: 27.9667 ISP of this IP: UNINET Project Organization: Mobile Telephone Network Host of this IP: 196-11-240-251.mtn.co.za Local time in South Africa: 2010-12-29 14:35
Dec 29, 2010 | Cell Phones
Disable internet access
Access your router Setup page
Open internet explorer go to http://192.168.1.1 (default) username: admin (default) password: "leave it blank" (default)
Go to Security go to Filter
if you know that Ipaddress of the computer you want to block for example 192.168.1.10
You can create up to five different IP Address Range filters   Users who have  filtered  IP addresses will not be able  to  access the  Internet at all   If you only want to filter one  IP  address instead of a range of IP addresses, enter the same  value into both fields  For instance, if you wish to filter the  PC with  the  IP  address of 192 168 1 5, enter 5  into both  fields on one line: 192 168 1 5 ~ 192 168 1 5
if you know the MAC address of the computer click the Edit MAC Filter Setting and input the MAC address you want to block.
blocking by MAC address is the most effective solution to block a computer... while blocking by ip address will be easily bypass by changing the ip add of the pc
then saved your settings and reboot..
Jan 30, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Blocking email
The ISP provider changed our IP address when we reset the modem.(even though they swear it was a fixed IP) The mailguard delivery address is fixed so the redirected mail from mailgaurd no longer had a valid address for delivery.
You can fix this by correcting the mailguard delivery IP address (phone them in business hours) or by providing Mailguard with a name address instead of an IP address .
Simple but frustrating until you think of checking to see if the IP addresses of your server and mailguard match
Jun 15, 2008 | Cyberguard SG300 (00852503000366) Firewall
Samsung Galaxy Y Gt-s5360 - Black unlocked Smartphone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
