Question about Sunheat SH-1500 Electronic Infrared Zone Heater Golden Oak Casters, 13x19.5x17.5", 1000SqFt,1500W, 12.5A, 7-10 Min. Free Heat,140CFM,3 Ply Filter
How do i install a sunheat switch?
I ordered a replacement switch fro my sunheat heater, how do I install the new one?
What does a E2 mode mean how do I reset?
The '2' in E2 seems to refer to list of conditions under 'Troubleshooting' in the user manual for this product. The version of the manual that I have found claims that in this condition the problem is: "The amount of heated air exiting the front of the portable heater is reduced."
The solution is to: "Check the electrostatic filter to make sure it is free of dust and dirt. Also check the front grill and rear air intake to make sure it is not being blocked by any kind of debris."by BillBell
below is a few links and the last one is sun heat where you can contact them. press the helpful button,
http://www.qcsupply.com/media/pdf/20451_IOM.pdf
Sunheat SH1500 Space Heater Parts
Welcome to SUNHEAT INTERNATIONAL Family Owned and Operated Since 1954
Feb 02, 2016 | Sunheat SH-1500 Electronic Infrared Zone...
Just bought and plugged in E1 error!! Can't get it to work!!
then return it to place of purchase for replacement or refund .
Oct 11, 2015 | Sunheat TW-1500 Thermal Wave Infrared...
Before we replaced our furnace, I had to replace the transformer almost every year. When the new furnace was installed last year, the transformer disappeared. Now with winter coming on, the 550 hasn't
Hello, seems like there is no way to turn on the humidifier. There would either need to be a new transformer installed, a current sensing relay, or a sail switch to activate the humidifier when the blower motor kicks on.
Nov 22, 2011 | Aprilaire 550 Humidifier
Water flow ok to side valve. no waer flow to top of 1042-l unit. valve extremely hot. is there an expert service maitenance available in montreal
Replacing this solinoid valve is not hard to do. This is something the homeowner can accomplished with small hand tools. Turn power off at the furnace and the inlet water off at the saddle valve.Remove the water line at the valve and the connector exiting the valve. Remove the two screws and the valve is off the unit. Armed with the make and model number of the unit goggle the manufacture with the model number and order your replacement valve on-line. Install the new valve opposite of which the old valve was removed or per manufactures instructions that may come with the new valve you orderd.
Jan 23, 2011 | General Filters 1042-LH Humidifier
There is no water reaching my AprilAire humidifier, indeed no water is flowing through the saddle valve attached to the hot water pipe of the hot water heater. Considering what would be involved in...
Yes a new valve seems in order. and yes having the valve on the cold side would create less build up in the filter pad so long as your water dose not come in at 37 degrees. but, I think you have it right.
Dec 22, 2010 | Aprilaire 550 Humidifier
I have a Honeywell House humidifier HE 225A-1006.
In order of probability:
1) (incorrect wiring) Make sure that humidistat is in SERIES wired with the furnace.
2) (shorted wires) Check that two wires to humidistat are not touching...use your glasses if you need them!
3) (bad humidistat) disconnect the humidistat and put an ohmmeter accoss the two terminals when it is turned on you should read 0 ohms, and when off it should read infinate ohms, if not pass both these tests, you need new humidistat.
That is it, there are no other possibilites!
Oct 12, 2009 | Honeywell HE220A1019 Whole House...
Broken tank
Telephone: 800-477-0457 (M-F 7:30AM-7:00PM EST) with Visa, Mastercard or Discover (All of US and Canada). Our winter "order department" cannot take this order, so please do not push the "to place a new order" option. Please push option 4 from the first menu and then press option 7, which will direct you right to a Consumer Relations Representative who will be able to take the order. If you choose the "to place a new order" option from the main menu they will tell you they cannot take this order.
Aug 20, 2008 | Vicks Cool Mist V3800 1.7 Gallon...
Refill light is on, but the water tank is full
In the manual it says that you should clean the heating element. Unplug the machine, lift off the water tank, pull the lever under the tank and lift off the power unit side. If there is too much build up on the element from mineral deposits, the refill light may remain on.
Unfortunately, I have cleaned mine, soaked it in vinegar, made it look nice and new...and it still doesn't work. I am really annoyed as I have not had this humidifier long and have taken really good care of it. I do not want to throw it out. I am going to call customer support and find out if there are any other solutions. (I got a new one for Christmas and do not want to open it until I am sure that it is not fixable!)
Dec 06, 2006 | Honeywell Warm Mist HWM-2030 Humidifier
Sunheat SH-1500 Electronic Infrared Zone Heater Golden Oak Casters, 13x19.5x17.5", 1000SqFt,1500W, 12.5A, 7-10 Min. Free Heat,140CFM,3 Ply Filter Logo
179 people viewed this question
Top Sunheat Humidifiers Experts
Paul Carew
Dennis
Are you a Sunheat Humidifier Expert? Answer questions, earn points and help others
