Question about Binatone Icarus 2020 Single
Change answer message - Binatone Icarus 2020 Single
How can I change the answer message
You didn't specify a model, but here is a Uniden DECT 1580 Manual that should be close enough to help you change the message.
Feb 24, 2015 | Uniden DECT 6.0 Cordless Phone
Tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
on Feb 14, 2009 | Olympia OL5870 Digital Answering Machine
How do i change or program to get messages and to get out of the answere only mode
If it's displaying the "A" then you're in the announce mode where it play an outgoing message and does not record incoming messages. To change to the answer mode follow the instructions on page 33 of the manual.
Apr 17, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
I want to change the message on my answering machine. Manual lost
I changed the message, but now the phone rings and rings and does not pick up message, and displays "minus sign" not zero. Pls help.
Sep 16, 2009 | GE 29875GE Digital Answering Machine
How do i change the incoming message on my phone?
The 27831 isn't an answering machine.
Please refer to the documentation for whatever answering machine you have on your phone line. If you require further assistance, please add a comment to this question and specify the make and model of your answering machine.
Apr 13, 2009 | GE 27831 2.4 GHz Twin Cordless Phone
Panasonic kx-tg2740 cordless phone - how to change message?
  • Step 1Begin the recording process by first locating the "Change" button on your answering machine. This button initializes the answering machine for adjustments to the settings of the various features.
  • Step 2:Locate the microphone on your answering machine and lean towards it until you are about nine inches away.
  • Step 3:Locate the "Annc" button. Press and hold the "Annc" button until it beeps. Begin recording your message.
  • Step 4:Watch the message window while you are recording your message. It keeps track of how much time has elapsed since you began recording. You can record a message that is up to three minutes long.
  • Step 5:Locate the "Stop" button and press it when you have finished recording your message. The answering machine will play your message back at this point. If you are not satisfied with your message, repeat the steps to record it again.
  • Step 6:Press "Annc" if you want to listen to your message again.
i found this i hope it helps
Jan 10, 2009 | Panasonic KX-TG2740 Cordless Phone
Binatone Icarus 2020 Single Logo
18 people viewed this question
Top Binatone Lands Phones Experts
Unlockingcom
ray gallant
Are you a Binatone Lands Phone Expert? Answer questions, earn points and help others
