Question about Delta & Single Handle Shower Faucet
Delta handle won't turn more than half way
We have a brand new single handle shower faucet from delta at our cabin. It worked for a while but now the handle will only turn half way, therefore the waters is only lukewarm coming out of shower head. Any ideas?
    Problem Solver:
  • 13 Answers
Take the handle off and adjust the hot temperature stop. Its just a plastic piece that needs to be adjusted up more. It just fits in grooves like a gear. Its easy to do.
Posted on Apr 21, 2013
  • 54 Answers
SOURCE: a single handle delta shower control lets water
Make sure the drip is continuous because the shower head will drip for a few minutes until it empties out. Replace the cartridge or washer kit if it keeps dripping.
Posted on Sep 26, 2009
manhandy
  • 146 Answers
SOURCE: Delta 134900 handle Water coming out faucet and shower both
well the Diverter is not working it dose not matter the distance. when applied it should shoot the water to shower or tub if not working will come both.
Posted on Jun 26, 2009
  • 35 Answers
SOURCE: Water is not very hot.
First try adjusting the pressure balancing gear located right behind the handle. If you still do not have hot water I suggest to replace the cartridge.
Posted on Feb 23, 2010
  • 102 Answers
SOURCE: Water leaks from the shower head. I have a delta
You may want to replace the ball or cartridge whichever the case may be. Also be sure to use Genuine Delta parts as they will hold up much better than the aftermarket parts. I hope this helps.
Posted on May 27, 2010
  • 65 Answers
SOURCE: when delta shower faucet turned on the water comes
Sounds like the delta people forgot to install the diverter piece inside of valve body,small white plastic piece screwed into valve. If you take out valve you should see it up inside body
Posted on Jan 28, 2011
How to fix delta shower single knob faucet
Take handle off (either set-screw from side or bottom of handle, or phillips screw under cap on end of handle), pull off sleeve that's behind handle, unscrew nut that holds cartridge (strap wrench works great) and pull cartridge out.
Apr 29, 2015 | Delta & Single Handle Shower Faucet
Why no water thru delta single lever kitchen faucet
can be a number of issues: clogged aerator, water supply is turned off, or supply lines are kinked, debris behind cartridge blocking flow, rubber seats out of place.... What has changed to cause problems?
Mar 25, 2013 | Delta & Single Handle Shower Faucet
Can't regulate a delta shower.
If you have the type that you turn the handle like a clock, you have to find that perfect spot. It can be 3/4 of the way around. If you have the ball type, single lever, the rubber seats and springs under the ball should be replaced. Cost...less than $10 for the kit to do yourself.
Dec 04, 2012 | Delta & Single Handle Shower Faucet
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
MY SINGLE HANDLE SHOWER FAUCET DRIPS RAPIDLY. THE ONLY BRAND NAME MARKING IS "MASTER PLUMBER". iS THERE A REPAIR KIT FOR THIS FAUCET?
Those faucets are made by different companies and they put their name on them. Delta Price Pfister most likely. Sorry but you will need to pull it apart and see which it is. That is a hardware brand faucet and may be made by any of the major brands.
Feb 08, 2011 | Delta & Single Handle Shower Faucet
Delta single lever faucet leakingafter bing shut off.
Will need to get delta faucet rebuild kit. Available at home depot, lowes or hardware store. It consists of valve stem seals & springs. The larger kit will contain ball assembly. Turn off water to faucet. Unscrew handle via set screw under plastic cap. Unthread cap over ball assembly. Pry out valve seals & springs. Reverse procedure to install.
Jun 26, 2010 | Delta & Single Handle Shower Faucet
I WANT TO REPLACE TUB FAUCET. IT IS SINGLE HANDLE-OLDER DELTA
It should be compable with a new delta if you replace it with one or you can get washers to rebuild it yourself. Delta are a real good faucet.
May 04, 2010 | Delta & Single Handle Shower Faucet
Delta bathtub faucet
you need to stick large screw driver up in the faucet and turn it counter clockwise. this might sound ridiculous but it works.
Mar 26, 2010 | Delta & Single Handle Shower Faucet
How do you switch out the single lever dial on a delta shower fau
Hidden under the lever is a little hex screw. Use an appropriate hex a.k.a. "Allen" wrench to remove the handle. You might want to shut down the water service first to save your shower until later.
Mar 16, 2010 | Delta & Single Handle Shower Faucet
Delta & Single Handle Shower Faucet  Logo
287 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
