Question about Telex Airman ANR 850 Headset
Crj eicas chimes are too loud in my telex anr 850
Cannot decrease volume ofchimes
Sound became muffled(only lower frequencies) in both ears
An equalizer circuit or filter? No idea where this would as you only give the result not total environment.
Apr 01, 2014 | Telex Airman 850 Aviation Pilot Anr...
Does not work with telex 850
Don't know if you are using the PA-97 adapter, it should work without any problems. I would check the potentiometer "gain" adjust on the microphone assembly. Hope this helps ;)
Jan 30, 2014 | Pilot USA Fixed Wing Headset to Airbus...
Volume decreases drasticly after playing loud 15-20minutes
Shes overheating and thus goes into emergency mode and shuts down the volume to help cool down the built in amp . Dont know if it has a built in fan (likely not) but its overheating which can be a number of reasons why...from a failed heatsink componet, inadequet venting, shorted circuit. Can you take it out and inspect it?
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
Chimes whenever the drivers door is open, even if the key is out. It is also really loud, want to turn the chime down also
My van chimes also with the key out. I think it is a reminder to lock the car as you leave. I don't see any way to reduce the volume.
Sep 07, 2012 | 2002 Buick Rendezvous
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
2007 Saturn Aura XE, the audible alarms can hardly be heard
Good news - they're adjustable. The radio is used to adjust the vehicle's chime level. To change the volume level of the chime, press and hold push-button 6 with the ignition on and the radio power off. The volume level will change from the normal level to loud, and LOUD will appear on the radio display. To change back to the default or normal setting, press and hold push-button 6 again. The volume level will change from the loud level to normal, and NORMAL will appear on the radio display.
Note: Each time the chime volume is changed, three chimes will sound to indicate the new volume selected.
Sep 07, 2010 | 2007 Saturn Aura XR Sedan
Hi, I am Kush Agarwal and I have been using the telex airman 850 for a while now. Just a couple of days back I noticed that the right side speaker of my headset is not working properly. The sound and the...
Old question, but may be somebody else is experiencing the same issue. The earcup without the boom has a noise cancelling board, so it could be one of the wires that goes from one board to the other one. Gently take the earcup off and look at the 4 wires that are soldered on top (red, black, shield and white). If one of these is cut, the speaker/anr won't work. You will need a very small soldering iron to repair it (no more than 15 - 20 watts). Good luck, hope this helps ;)
Aug 02, 2010 | Telex Radio Communications
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
How do I adjust the Chime Level on an ADB340MP?
pull off the front cover of chime unit and turn down the volum control knob
Dec 16, 2008 | Clarion ABD340MP AM/FM CD/MP3/cassette...
Loud popping and decrease in volume
I'm guessing power supply problems fluctuating, or main control board.
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Telex Airman ANR 850 Headset Logo
35 people viewed this question
Top Telex Radio Communications Experts
Andrew Taylor
Andrew Taylor
richie46
Are you a Telex Radio Communication Expert? Answer questions, earn points and help others
