Question about Dryers
TH6110D Thermostat defect won't shut off heat
I set the thermostat at 67 and it wouldn't shut the heat down
  • 92 Answers
SOURCE: Dryer no Heat. New Thermostat Burnt Out.
sounds like you are replacing the hi limit thermostat try replacing it with the cycling thermostat as well
Posted on Jan 20, 2008
hotuna
  • 288 Answers
SOURCE: thermostat does not stop heat pump unit
Most of these problems are the program settings on these way overcomplicated thermostats. You will need to re-read the instructions on setting the programs. Or bite the bullet and buy a cheaper and simpler one. If you installed it yourself, make sure the settings on the inside are correct, like gas/electric heat, and 24 volts, stuff like that.
Posted on Mar 14, 2008
  • 306 Answers
SOURCE: Furnace doesn't reach desired temperature
One of two things you can try. Do you own a volt ohm meter? Anytime your unit cycles short like it is doing the control circuit which on this one is 24 volts that engages relays and controls the gas valve to open and close. I am thinking the heat exchanger is getting so hot it is tripping the upper limit which for the most part is around 180 degrees. So next time it turns off take your ohm meter and with the power to the whole unit off. Either turn the breaker off or there is a light switch that is real close to unit turn it off. Undo the two wires to the gas valve and ohm them out. You should have continuity if you get nothing check each limit switch should have a couple. Undo wires to them and check. If you find one that is open more then likely the upper one. They are a safety device that keeps the unit from getting too hot.
There might be another option increase the speed of your fan motor to get the heat out of furnace quicker. Look at the circuit board notice the fan wiring going to it. The Red wire from fan is low speed look to see if it is on HEAT on the board. You should have 4 speeds to pick from you could take the black off of COOL and swap wires and test the unit by doing that. I'm going to put a solution on this so I can come back to it quicker. Even though we a just testing it for now. ken
Posted on Dec 21, 2008
  • 15 Answers
SOURCE: Replace three wire thermostat with four wire thermostat
From the two red and two black wires (and the specs in the pdf), your new thermostat sounds like it's designed to directly control the line voltage (120 or 240) to the heater. That's the usual way baseboard heaters are controlled.
Could your wires be red, black, and (old, yellowed) white, the standard colors in a 3-wire power cable? Just the red and black should be enough to control a 120-volt heater so I don't understand what the white would have been used for. If it were my heater I'd take off the cover(s) -- with the power off, of course -- and find out what those wires actually connect to.
Posted on Jan 26, 2009
  • 686 Answers
SOURCE: HEATING ELEMENT HEATS UP ,BUT SHUTS DOWN BEFORE TEMP.
Are you trying to burn your house down? :) the thermostats prevent over-heating. They cycle your heat on and off re-connect them the way they should be.
Posted on Mar 01, 2009
My thermostat is set on 68 degrees and it shows room temperature is 68, but the furnace still kickson, Honeywell said it has a 1 degree difference. so what's the problem then?
Yes there is a one degree tolerance, in fact my heater just kicked on and it is set to 67 and the inside temperature reads 67. It is also a Honeywell.
Dec 28, 2016 | Heating & Cooling
The compressor won't stop running
Sounds like the contacs on thermostat, has welded togher. Compressor will run till it starts pumping liquid frezon, then over heats ,then shuts down till it cools off , and starts all over again
replace thermostat..
Jan 13, 2013 | Refrigerators
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
Whirlpool dryer overheats element high heat all heat settings
First check the heating element for short to frame. If it is not shorted remove the filter chute and clear it out. The control thermostat has 4 wires. 2 small wires come from the timer and power up a small heater inside the control thermostat making it shut down faster for perm press and knit cycles. Over time this bimetal inside the control stat won't shut down fast enough or not at all. If it won't shut down then the element will gl;ow reed and the base 250 stat on the heater chamber will shut down. If it fails to do so then the smaller one up top will trip at 300f. If it fails to trip or the filter chute is clogged the fuse skinny white plastic thing next to the control tstat will met and shut down operation.
Here is my HOME MOVIE ROPER DRYER NO HEAT
It shows the various components and how to check.
Jul 31, 2012 | Dryers
Furnace burner will not ignite
It could be the fan motor capacitor
Jul 15, 2017 | Heating & Cooling
Whirlpool Cabrio dryer temperature won't get hot? What causes this problem?
Runs but will not heat
1.loose wiring----check terminals & wiring
2.defective centrifugal switch in motor---replace switch ( check linkage to motor)
3.defective timer---replace
4.open heat element---replace heat element
5..defective operating thermostat---test thermostat, replace if defective
6.fan or it's pulley loose on shaft---tighten set screw
7.incorrect heat or timer settings---reset timer
8.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
9.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 25, 2011 | Dryers
Electric Dryer starts and runs but won't heat.
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag Neptune MDE4000 Electric Dryer
I'm having a problem with my thermostat reading much higher than set temperature. The apartment manager is blaming the heat outside, but I've been here 3 years and this is the first time I've...
Hello my name is Heath it will be my pleasure to assist you. The thermostat is bad and will need to be replaced the heat anticipator in the thermostat has gone bad. I would replace the thermostat.
Aug 08, 2011 | Heating & Cooling
I have a Maytag PYE2200AYW electric dryer. we had problems a few weeks ago and discovered that the blower wheel was cracked, so we replaced it (part # 31001317). Then a couple days later it just stops and...
Check the thermal fuse and thermostats again to eliminate them as suspects. Both should be zero ohms at room temperature. If you eyed the entire duct system from lint filter to outside of the house for lint, then these are probably OK.
One thing that will shut down a dryer: a defective door switch. If you turn the timer on with the door shut and can hear or see it progressing (running) then the door switch is OK.
If your door switch is operating marginally, the heat can expand the body of the switch and open the circuit (and shut the dryer off until it cools). Check the switch with an ohmmeter with the dryer disconnected from power.
A loose spade terminal on this switch (or anywhere else) can do this too.
Also, a misaligned door or defective door clasp might do this after heating up.
Keep thinking 'heat expands' and you might find it.
The only other thing left is a defective timer.
Good luck from Detroit, MI.
Jun 11, 2011 | Maytag PYE2200 Dryer
I have to play with thermostat to get my heating system on
You did not make it clear if the thermostat is a programmable unit or not. I am wondering if the thermostat is not set on the correct heat anticipation setting. A heat anticipater is a small heater that helps the thermostat turn off before it over shoots the desired temperature setting. If the thermostat is set for a 5 degree setting, it will turn off at 63 degrees if set at 68. If the anticipater was set at 1 or 2 degrees, it will shut off the heater at 66 or 67. Newer thermostats will only allow the thermostat to cycle 6 times per hour so if you never reach the desired temp, you have to wait 10 minutes before it will allow a call for heat. Check the installation instructions to see if there is a setting where you can get the anticipator temperature closer to your set temp. Good luck.
Dec 11, 2009 | Goodman Heating & Cooling
Dryers Logo
16 people viewed this question
Top Dryers Experts
