Question about Minolta magicolor 2300W Laser Printer
Printing faintly Giving faint copies. Colour tonors not empty. New drum - that was working well. Pictures are ghostly, mostly in black and white and resolution is low.
  • Minolta Master
  • 6,161 Answers
Has the transfer belt been replaced?
Posted on Feb 01, 2015
3 Suggested Answers
LaptopExpert
  • 458 Answers
SOURCE: black line on right side of prints
Replace the Drum
Posted on Jun 09, 2008
  • 29 Answers
SOURCE: Faint white line observed on print
nope, the TONER OR INK CARTRIGE is running out in tat area, so you have to check it so that there is a new one. hope this helps. :)
Posted on Jun 19, 2008
Ricoh FW 780 is printing ghost images and faint black bands of stripes onto copies
Possible cleaning problem. The cleaning unit has a blade made of a rubber type materiel that cleans the drum. It may need to be replaced. It could also be coming from the fuser unit. Either way, you will likely need a trained technician to fix or replace these parts. Disassembling one of these machines is not an easy task.
Mar 02, 2011 | Ricoh FW 780 Black and White Copier
My Brother MFC 7840W prints but has a faint copy of the previous paragraph about 3 inches below. I have cleaned the corona wire very thoroughly but still the 'ghost' printing on my documents. How do I fix...
Yes. The drum is most likely your problem. It is possible that it is a one time problem, which can occur if you print a very dark black page or image followed by a light gray page or image. If it has only happened once or twice try printing a different document to check it. If it is happening repeatedly, then you should replace the drum and instantly see it fixed. You can get a drum anywhere that supplies toner.
I hope this helps! Good luck!
Feb 28, 2011 | Brother MFC 7840W Printer
DELL 5110CN PRINTS PRINTS LIGHT GRAY NOT BLACK!
try to print test page and determinate which or colour is fainting. if it is one colour then you need to replace this colour image drum. If all of colors is fainting then its transfer roller.
Dec 29, 2009 | Dell 5110cn Laser Printer
It si not printing -very faint colour and np black
Here are the steps.
1.Print Demo Page.
a.Press the Menu button of the printer.
b.Use the down arrow key and select Print Demo Sheet.
c.Press Ok button.
If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
Thanks.
Regards,
Neerak21
Sep 24, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
When printing the sheet of paper has 3 dots on the
Yes this could be the drum.
You could remove the drum and carefully look for the pattern of dots etc that you are getting on the page but on the drum surface.
I would suggest replacing the drum 1st and retrying.
If the black lines are just down one edge then the fuser could be to blame for the black marks but without being able to see the page i cant tell. The drum is certainly my 1st suspect and is easy for you to try.
If you are in Berkshire try www.repairmyprinter.co.uk for additional help
Aug 24, 2009 | HP LaserJet 2840 All-In-One Printer
Ghost printing
Hi Phillip,
If you have changed the drum and toner, then check the fuser unit. The teflon coating on fuser film could be worn.
S88
Dec 16, 2008 | Brother MFC-8460N All-In-One Printer
Printing is faded and too light
more important than all that nonsense is:
is it faint when you do an internal report or make a copy?
if only on copies it is the film on the underside of the glass.
if on prints and copies it is the drum.
Oct 23, 2008 | Dell 1600n All-In-One Laser Printer
Printing faint lines with fine corresponding creases on drum
You probably can not repair it. I will say this though, be careful to get the right labels for it.
Mar 02, 2008 | Ricoh Aficio CL1000N Printer
Faint print or colour missing V V URGENT
I'm not an expert on these but I'd guess either the high voltage unit or LED laser PSU are suffering from an intermittent problem. If you're lucky it's just a loose connector - but I'll bet you've already tried re-seating every connector you can find :)
Sep 24, 2007 | OKI C5400 Laser Printer
Minolta magicolor 2300W Laser Printer Logo
48 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
