Question about Samsung SCX-4100 All-In-One Laser Printer
Print but now text or image?
I send a print job to the printer, and all I get is a blank page. Any idea what maybe wrong?
  • Samsung Master
  • 1,297 Answers
Verify if the copier function is working.If is working your problem is in the PC or the data cable.
Posted on Apr 20, 2013
4 Suggested Answers
MerlinTech
  • 197 Answers
SOURCE: My printer is "printing" blank pages
sure..would you run a test page, please?
Posted on Jun 16, 2008
  • 4 Answers
SOURCE: My Samsung CLX-2160N will not print black and
See answer posted by Loki
Posted on Jul 07, 2009
SOURCE: Scanner produces blank image, copier produces blank page
NO solution... same identical problem. What did you do to fix it?
Posted on Sep 12, 2009
I send a print but pages aqre blank
Does this happen when copying? Can you print internal copier form meter count etc.?
Mar 14, 2014 | Konica Minolta bizhub C250 All-In-One...
I have an HP 4345 MFP that's printing nothing but blank pages when copying, sending a print job to the printer. Im not even able to print the config page. All comes out blank. Does anyone have any idea...
if you are tec guy?
do half test page test find any image created on catridge drum, if no image found then
Check laser scanner assembly shutter fully operating or not while catride access unit closed, if unable to check, remove the shutter from laser scanner assm
Increase toner density
set factory settings,
If image on drum no print on paper, check transfer roller, contacts, if dirty replace T.roller, no result replace Power supply board..
Sep 09, 2011 | HP LaserJet 4345mfp Printer
MY HP LaserJet 2840 has a brand new Toner cartridge. Now it won't print at all and we are getting a "OPC at end of life" prompt. What does this mean?
Imaging drum reach 20,000 (black only) or 5,000 (color), replace the image drum.
Supplies life
The life of the imaging drum depends on the number of black-only or color pages that print jobs
require. Imaging-drum life is also affected each time the device calibrates because calibrating causes the imaging drum to rotate. Imaging-drum life is measured in terms of number of rotations rather than number of pages printed.
The type and length of print jobs also affects drum life. A series of short print jobs uses more drum
life than an equivalent number of pages printed in a single large job. To extend drum life, print
multiple copies of a print job at one time rather than sending the same job to the device multiple times.
The life of a print cartridge depends on the amount of toner that print jobs require. When printing text at 5% coverage, black print cartridges last an average of 5,000 pages and cyan, magenta, and
yellow print cartridges last an average of 2,000 pages. High-capacity cyan, magenta, and yellow print cartridges last an average of 4,000 pages. (A typical business letter has 5% coverage.)
Aug 18, 2011 | HP LaserJet 2840 Printer
If I am not printing continuously, the printer does not print the first 5-6 printing jobs. When print job sent to the printer I get a blank page (printing job can be more than one page). After the blank...
It seems that " Print on both sides (Manually)" is selected in printing options., when you want to print any document Go to file Print > select printer and click properties and disable the Manual printing option in device settings.
You should be able to get printing without errors,
if the option is not checked then check for the default paper tray,
save the settings and reboot your laptop/desktop and restart printer as well so that settings should work properly and any given command gets clear from memory, If these all settings are ok, Uninstall the printer driver and download the latest version drivers from HP website and install see links below
hp LaserJet 1150/1300 printing system hp LaserJet 1150/1300 PCL5e driver
If you require more assistance feel free to reply to this post
Regards, BA
Jan 14, 2011 | HP LaserJet 1150 Printer
Hp 4255, if i send five pages, it shut first five blank pages
check your settings in Start->Settings->Printers->HP4255 rightclick ->properties-> preferences.....
Oct 29, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Double image is printed on one page, overlapped on Brother 7225
It sounds like a piece of paper is wrapped around the fuser roller. Look in the rear of the machine with a flashlight.
Jan 22, 2009 | Brother MFC-7225N All-In-One Laser Printer
HP Officejet 5610 All-In-One print text but no image?
I found what might be the solution to this while searching for a problem for another printer series on HP's site. Go to the Printed Page Is Different Than What Appeared on Screen page and scroll down to "Missing graphics or text, or blank pages"
Sep 11, 2008 | HP Officejet 5610 All-In-One InkJet...
HP1200 prints blank page
Try ressetting the printer:
Turn the printer off. Press and hold the Go button for 20 seconds while powering on the printer
Jun 28, 2008 | HP LaserJet 1200 Printer
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Adjusting printheads - won't stop and keeps printing blank pages
Hi Did you have any print jobs sent to the printer before replacing the printhead. It seems that the printer is trying to print a job and since the usb cable has been disconnected and reconnected the printer is printing blank pages or misc text.
Dec 03, 2007 | HP Officejet 9110 All-In-One InkJet...
Samsung SCX-4100 All-In-One Laser Printer Logo
41 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
