I have samsung SCX3200 series printer while giving print a document in landscape mode it will print the document in portrait kindly give a solution for this
While giving the print in landscape mode the printer the will print the document in portrait mode kindly give a solution for this
  • 883 Answers
SOURCE: Won't print in landscape mode
at the adobe print preview screen, does the preview agree with your desired print? if yes, then is "choose paper source by pdf page size" checked on? and is "Auto-rotate and center" checked on?
Posted on May 31, 2007
  • 86 Answers
SOURCE: Printing Problem
Try changing the paper setup of the printer driver, from the Start menu - Printer and Faxes.
Select portrait and click apply.
Joseph
Posted on Sep 21, 2008
SOURCE: HP Color laserjet 4700 is printing in landscape
check paper settings in paper handling to set
at plain paper/ letter. or reset factory defaults.
check paper size on tray if app, set to standard or
letter ,not custom
do cold reset . must reinstall network info afterwards.
Posted on Jan 20, 2009
SOURCE: HP C7180 printer prints 1 p. LANDSCAPE, next p. PORTRAIT, etc.
I had the same problem. I uninstalled the printer on the offending computer, rebooted, reinstalled and it ironed itself out.
Posted on Mar 20, 2009
  • 144 Answers
SOURCE: My HP PSC 1200 printer has started printing all
hi
goto the control panel-->printers and faxes and do a right click on the printer icon.now goto printing preferences and change the settings as per your need
there is also a check box for showing the preview before printing,check that ,now everytime you want to print something it will show you a preview in advance for how the print out's gonna look like
you can change the settings as portrait or landscape by going to printing preferences.
hope this helps
Posted on Jul 14, 2009
Want to know how to change the appearance from portrait to landscape
when you hit print on your laptop, pc,tablet, etc, the screen that comes up that gives you choices of number of copies, etc, also give a choice of portrait or landscape. search around if it is not obvious. good luck
Sep 16, 2015 | Office Equipment & Supplies
Why is my printer printing in landscape mode when it is set to portrait mode?
Click File, Print, Then open the printer properties and make sure it is set to portrait. Also if you are working in MS office make sure to check the orientation tab. The document orientation tab overides the printer settings
Jul 18, 2014 | Canon Pixma MG5220 InkJet Printer
How so I do Landscape orientation on Canon Pixma MP500?
When you want to print a document Click on File (at top left hand corner of screen) - click on Print then click on Properties box - Layout tab then select Landscape.
The printer normally defaults to Portrait but sometimes you want to print Landscape. Use this method when you need to print in landscape mode.
Sep 07, 2012 | Canon Pixma MP500 All-In-One InkJet...
Printer almost always refuses to print Landscape from Excel. It prints Landscape or Portrait from other software, but balks with Excel in Landscape. It prints a portion (the information at the left) in...
Try printing to a different printer if possible. This may shed some light on whether the problem is with the printer or with Excel. You could also open the file on a completely different PC and printer to see if something is corrupt in the file. Also try creating a completely new document to see if it will print in landscape. Can you print in landscape orientation from MS Word or another program?
Jul 18, 2011 | Office Equipment & Supplies
Printing both landscape & portrait in one document
Yes, set the doc feeder for Auto Paper Selection APS
May 07, 2010 | Canon iR 2016i Black and White Copier
A word document that is showing portrait orientation in print preview is printing in landscape orientation
You need to change the orientation in the printers screen.
Start>Control Panel>Printers
Select your printer
Properties>General>Printer Preferences>Page Setup
Click on Portrait>OK
Your printout should now be in Portrait mode.
Nov 24, 2009 | Canon PIXMA MP810 All-In-One InkJet...
My suddenly prints every other page in landscape. What is the problem? Tom
It prints in portrait then landscape, portrait then landscape and so on. I use a laptop and desktop with this printer and both are doing it. 2 sided print has not been selected.
Aug 11, 2009 | HP Photosmart C5180 All-In-One InkJet...
I need to flip my text to print on a transfer for a t-shirt
You want to flip the text? Do you mean you want the text to display 90 degrees from normal portrait mode into landscape?
If so, when you select a document to print a window should pop up with options to select number of copies, etc. Take note of a pull down menu with portrait, and landscape options.
Use landscape to print your job with the text in this mode.
If you want this set as the default option you can set this in your print settings in the computer.
Open your printer settings in control panel, (assuming you use windows) select the printer with right click, and choose properties. There should be an item labelled document preferences. In this you can select a between Portrait and landscape. Hope this helps.
Feb 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Lexmark X7170 - Landscape orientation doc prints on bottom of a portrait page, not landscape
Go to print setup and go to properties then adjust the settings to the full page . right click on the default printer icon to go to properties.
Nov 06, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
May 30, 2007 | Printronix LaserLine L1524 Printer
74 people viewed this question
k24674
jasbo
jasbo
