Question about Misc - MFG SKR-2233 Keyboard P/N: SKR-2233
Connect via USB
Is there a MINI to USB connector to connect AVID keyboard SKR-2233 to a mac USB port or do you need a driver ??
I bought an old Mac Mini Intel Core 2 Duo, 2 GB Hard Drive, OS X Yosemite, with serial # C07CS2TPDD6H. What adapter cord could I use to connect it to an iBox C1752, TFT LCD Monitor?
That Mac has a hdmi port and a mini display port. The monitor has a saga port. So ether a hdmi-svga. Or miniDisplay port-svga.
Any usb keyboard will work. So any Mac keyboard newer than 12 years should be good, and newer pic keyboards will work. Beware of older keyboards that have round plugs. On macs these were ADB ports. On PC's, they used PS2 (ADB, ps2, usb are all different, you want the flat rectangle USB)
U.S. pc keyboards also have two modifier keys wired different than the U.S. Mac keyboards, but this can be adjusted in the system preferences. Can't say for non U.S. KBs. They are the windows/alt keys. Vs Opt/Command keys. That is, if you are soused to using a Mac, the key that is closest to the spacebar (command key) is applied by the second key over rather than the first. Again, this can be modified in the Sys Prefs.
Jun 06, 2015 | Apple Mac Mini Desktop
My mac book and epson projector doesn't show the signal
To my knowledge there are no video drivers to output video on a Mac USB port in the Mac OS system. There are however, devices that connect to the USB port that will give video out on Conventional (VGA, DVI, HDMI, etc) connectors.e.g. http://www.newertech.com/products/viddu2dvia.phpMost projectors connect via VGA - what Projector are you using?
Jan 19, 2012 | Apple MacBook Pro Notebook
How link my electronic keyboard MK 939 to compurer? what drivers are necesary?
I see the MK 939 has a midi out port. This can be connected to a midi in port on your computer via a usb to midi connector ( as shown in picture)davemello_1.jpg
Usb connectors have built in drivers so all you do is plug in, select the usb-midi device in music software.
A reasonably cheap one can be found here
http://www.amazon.com/Cable-Converter-Music-Keyboard-Window/dp/B0017H4EBG
OR
Connect keyboard via a soundcard eg soundblaster fatality with built in midi portsdavemello_0.jpg
Details of soundblaster products can be found here
http://en.store.creative.com/sound-blaster.aspx
A free version of music software is available for download here
http://www.multitrackstudio.com/download.php
Thanks for using fixya.
Jul 11, 2011 | Computers & Internet
Where can you bay usb cable for panasonc ds 55 camcorder to connect to pc.
This camera downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is usually used only for stills. This camera doesn't have a USB connection at all.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. However, while most PCs have a USB port, they seldom have a Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Jan 24, 2011 | Panasonic NV-DS55B Mini DV Digital...
I have a Panasonic NV-GS22 Camera and I don't know what wire I need to connect it into the computer. I think it is a fire wire but I don't know what port I need to put it into on my computer.
This type of camera usually downloads video over a Firewire (DV, IEEE1394) connection. Some mini-DV cameras have a USB connection but it is used only for stills.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My Samsung mini-DV camera came with the correct lead. I did not need a driver, just some sort of video editing software that can accept input. Even Windows Movie Maker that ships with Windows will work.
Jan 22, 2011 | Panasonic NV-GS22 Mini DV Digital...
Usb invalid on the DCR-HC26 when i plug it in to a mac or pc
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 18, 2011 | Sony DCR-HC19E Mini DV Digital Camcorder
I have a Panasonic PV-GS59 mini-dv camcorder- I shot some video and plugged the usb into my macbook pro. I tried every setting to on the camera to get the computer to read the video. Nothing works. The...
Jan 13, 2011 | Panasonic PV-GS59 Mini DV Digital...
How do I import video from my sony handy cam DCR HC32 via USB to my computer
You don't. According to Sony, your camera will not stream video via the USB port. You can only do this using the i.Link connection (what everyone but Sony calls Firewire). The list of camera models that will stream via USB, and the method to do it, is on THIS LINK Your camera is not in the list.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. Or maybe you have a Mac. You haven't said.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select your operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Jan 03, 2011 | Sony Handycam DCR-HC32 Mini DV Digital...
I am trying to connect my Sony DCR-TRV10E to my home computer via ilink-USB cable, but my computer does not recognize the Camcorder.... I guess this is due to missing drivers for Windows 7. Can anyone help...
USB and i.Link cables are not the same thing. What Sony call i.Link everyone else calls Firewire, DV or IEEE1394, and it is a different standard from USB with different connectors.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. If you are trying to use a USB cable for video download, then it won't work for this camera. The driver is not the problem, this model is not on the Sony list of cameras that will download video over USB.
There is a Sony tutorial page for downloading at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many Mini-DV cameras.
Jan 02, 2011 | Sony Handycam DCR-TRV10 Mini DV Digital...
Want to downlaod to computer via usb, but computer doesn't see device
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Nov 11, 2010 | Sony Handycam DCR-TRV27 Mini DV Digital...
Misc - MFG SKR-2233 Keyboard P/N: SKR-2233 Logo
22 people viewed this question
Top Misc - MFG Computers & Internet Experts
David Payne
David Payne
Are you a Misc - MFG Computer and Internet Expert? Answer questions, earn points and help others
