Question about Apple iPod touch
Does not turn om
Ipod touch does not turn on - fully charged
  • 1 more comment
  • Anonymous Mar 15, 2009
    no matter what i do---it wont turn on. i have held all of the buttons---powered it all the way up, watched every video in youtube...nothing happens.
  • jose colima May 11, 2010
    did you jailbreak your ipod touch yes or no i have to know to help you
    its ur ipod touch jailbroke?
    President:
  • Apple Master
  • 688 Answers
It's possible that you have a bad power switch circuit .
have you plugged an a/c charger into the ipod yet?
it should boot with an a/c charger.
also,
plug it into the computer and see if itune recognizes it, if so then your LCD is probably bad and you just don;t know it's on.
and if you have put the ipod into dfu mode it will come up on itunes as being in recovery mode.
go ahead and restore it, if you worried about a jailbreak, dont, you can jail break it easy after it's restored. but i would make sure you have a copy of your current firmware prior so you can restore to the some firmware or something close.
here is a link to a firmware for the 2g: ipod touch firmware
here are the steps to put the ipod in dfu mode:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Plug the usb cable into the Ipod and NOT into the computer.
Hold the Home Button down for 5 second (do not release it)
Then Press and hold the Power Button for approx 10 secs (count them out)
Your iPod will reboot.
Release the power button and continue holding the Home button for an additional 27secs.
You may see the screen go blank or not.
Plug the USB end into the computer with itunes open.
Your ipod will mount in recovery mode.
When you go to press restore press the SHIFT key when you hit restore and choose the firmware you have downloaded.
Posted on May 17, 2009
My ipod touch was fully charged and turn its self off and now i can not turn it on i just have a black scren if i try and charge it it still dose not respond??
Unplug it! Then-...Press & Hold the Power and Home button at the same time until the apple logo appears, it may take 30-40 seconds
Sep 27, 2011 | Apple iPod touch
Tip
How do I charge my iPod touch for the First Time
<p>Apple iPod touch is a personal audio player with the ability to store and play MP3 files, digital video and downloadable games and applications. The unit is powered by a rechargeable battery. When charging the battery for the first time, ensure that the battery is fully charged. From there you can turn it on or removing the device from the charger, if desired, regardless of battery level. <br /> <p><br /> <p>1. Enter the main connection for the iPod cable to the socket at the bottom of the iPod touch. <br /> <p><br /> <p>2. Insert the small plug into a USB port on your computer. Turn on the computer. Alternatively, an iPod charger, sold separately, you can recharge your iPod touch with a socket. Connect the wall charger into an AC outlet. Insert the plug on the door of the small wall charger. The battery icon located in the upper right corner of the screen, the battery is charging. <br /> <p><br /> <p>3. Let the battery fully charged. When the battery icon to indicate the device is fully charged, remove the iPod from the cable. <br />
on Aug 09, 2011 | Apple iPod touch
Tip
How to get my iPod touch battery Strong
<p>Keep your iPod touch battery health is important to ensure the long life of your device. There are two factors to consider when learning how to get the battery in an iPod touch sharply: the life of the battery and a battery. Battery refers to the time that the battery remains charged. Battery life refers to the amount of time you can use the battery before it requires replacement. If you are concerned about the overall performance of your iPod battery, you should focus on increasing the battery life. <br /> <p><br /> <p>1. Keep your iPod at room temperature. Although an iPod touch can be stored anywhere from -4 degrees F to 113 degrees F, it is better to keep it at room temperature, which is 73 degrees Celsius <br /> <p><br /> <p>2. Keep updating your iPod software using iTunes. Not only new software updates for the iPod touch, they also include updates to the firmware of the device that the battery life of the device can improve. <br /> <p><br /> <p>3. Pass a minimum of one charge cycle per month. You have a full charge cycle by fully charging the battery, use the device until the battery is empty and then fully charge the device. Charges are important because the electrons in an iPod-based lithium battery to go to achieve its peak capacity. <br />
on Aug 05, 2011 | Computers & Internet
White screen when turn on
Try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
If this doesn't work, try restoring the iPod from within itunes.
Sep 17, 2010 | Apple iPod touch
My Ipod Screen Went White And Now It Wont Turn On, How Do I Fix It?
Dec 05, 2009 | Apple iPod touch 1st Generation (8 GB) MP3...
I was just using my ipod, and the screen went white... I tried the menu/center button but nothing happened.
Turn the touch off and turn it on again.
If the iPod will not turn off, try to reset it. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until either the Apple logo or battery symbol appears. If the battery symbol appears, continue to charge iPod touch until it is fully charged.
Nov 25, 2009 | Apple iPod nano
My ipod is all white when i turn it on
Turn iPod touch off and turn it on again.
Nov 21, 2009 | Apple iPod touch
Screen frozen on slide to power off
Nov 18, 2009 | Apple iPod touch
My ipod touch wont work only has a white screen and thats it
Nov 15, 2009 | Apple iPod touch
My Ipod touch turns off and restarts when charging? Please Help!
Have you tried doing a full reset? Or upgrading the software through Itunes?
Nov 06, 2009 | Apple iPod touch
Apple iPod touch Logo
182 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
