Question about HP Pavilion zd8000 Notebook
HP zd8000 vertical lines on lcd
My zd8000 is in the process of developing it's 10th vertical line. I have removed the battery and elevated the laptop to allow better air circulation and allow for better heat disapation, all to no avail. HP is not in the business of satisfying customers, no longer produces quality products, it's printers are no better than the computers. I will no longer recommend an HP product to anyone who asks which product they should purchase. If everyone who has purchased an HP product and is experiencing the same results where to do the same, it might get someone's attention at HP.
I wonder if anyone experiencing problems with HP products ever gets a satisfactory resolution. I won't hold my breath waiting for HP to step forward.
  • 1 more comment
  • Anonymous Mar 21, 2009
    I went upand down the line with HP and the best answer I got was "s--t happens" buy a new laptop. I shall but you can be certain it will not be made by HP
  • Anonymous Mar 30, 2009
    HP zd8000 gives to much trouble. Dead battery, verticle lines on screen, a very noise fan.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there.
    The problem you are describing covers all laptops regardless of make or model.
    Can you describe in detail what you are experiencing with the screen, are there any erratic colours or lines, do the lines stay in the same place, does moving the laptop lid change how it acts and does the screen go white from time to time or even black with the ghost image? Also is the machine still under warranty?
  • 26 Answers
If the lines flicker when you move the lid, then it is probably the LCD cable. If they don't flicker, though, you need a new LCD.
Posted on Apr 16, 2009
  • 538 Answers
LCD needs to be replaced.
Common problem in any brand called "Tab separation".
Posted on Mar 20, 2009
Vertical lines in hp zd8000
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical line. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Sep 26, 2010 | HP Pavilion zd8000 Notebook
I have virtical lines on lap top
Once you start to get vertical lines on your LCD screen, it's usually time for a new screen. I would check first by running an external monitor just to be sure it's not the video card.
May 19, 2010 | HP Pavilion zd8000 Notebook
HI, Thick white vertical line on screen
your lcd screen damaged.u need to replace it with new.
Dec 08, 2009 | HP Pavilion zd8000 Notebook
Same problem with my zd8000 HP Pavilion laptop
what has happened with your notebook is a simple wear factor. on the LCD screen there are ribbon cables witch join the main PCB controller head to the LCD laminated portion (what you see) have begun to wear. i have just recently replaced a screen because of the same issue. try gently flexing the the screen and see if the lines dissappear. next open the screen up, and check the cable running to the back of the screen take care as to not damage anything.
Aug 12, 2009 | HP Pavilion zd8000 Notebook
Hp pavillion zd8000 monitor has 37 vertical lines
Interesting that you counted them!
If you haven't tried to reinstall the video drivers, do that.
If that doesn't work, hook up an external monitor to see if the display is OK on that.
If it is, then your LCD screen has a problem and will need to be replaced.
Jun 29, 2009 | HP Pavilion zd8000 Notebook
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
HP Pavilion ZD8000 vertical lines issue
In answer to your question. It may be a screen problem. as the screen has a Matrix of vertical and horizontal line configuration.
I,d suggest trying the laptop/computer on an external monitor or screen. if it works fine on an external. then it could be assumed that the TFT Panel or invertor has a fault.
if the picture/display still has vertical lines on an external monitor, then the fault may lie, with the Mainboard.
Process of elimination, before spending any Money :)
Mike @ compurepair.
Jun 09, 2008 | HP Pavilion zd8000 Notebook
Vertical thin linings on lcd monitor
It is due to immense use of your laptop. So dont worry, off it for some time and on it again. It will not come. It is the same problem i m facing with my laptop. All the best.
Oct 05, 2007 | HP Pavilion zd8000 Notebook
HP Pavilion zd8000 Notebook Logo
485 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
