Error p1 in kelvinator split system - Heating & Cooling
  • 121 Answers
SOURCE: kelvinator split system a/cond
An air handler comes with a low, medium, and high speed wire taps and can only be set through these taps.
Posted on Oct 16, 2008
  • 81 Answers
SOURCE: hi, i have kelvinator split system in my house.but...
Sounds like a clogged drain pan. You will need to have the unit professionally cleaned.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
hvac1960
  • 2133 Answers
SOURCE: First time I've tried using the cooling on my
E-1 error means coil sensor (cooling) defective. Replace it.
Posted on Dec 06, 2010
Testimonial: "Thanks heaps. I'll get back to the retailer for parts under warranty. Too far out of town for labour warranty but knowing the problem helps. thanks"
  • 960 Answers
SOURCE: kelvinator split system when set
Check your filters... if they are dirty or blocked the set point temperature will be all over the place. If the filters are clean, there may be a problem with the air sensor which is attached to the evaporator on the front of the indoor unit behind the filters. Check and make sure this isnt covered with dust etc. The air sensor usually appears as a black wire mounted on a plastic mount, stuck on the coil ( Aluminium tube part) of the indoor unit behind the filters.
Posted on Jul 14, 2011
  • 14 Answers
SOURCE: I have lost the operating
http://www.kelvinator.com.au/KSE70HRB_UserManual_2009.pdf check out the site and the problem may be helpful to you.
Posted on Sep 12, 2011
Kelvinator split system heater off every 5 minutes for about 4 minutes then it comes back on and does this constantly .
Here is the free help link.
Air Conditioner Repair Help
Here is the PDF. It does not list the problem you identify but lists the contact information for Kelvinator. Bear in mind your problem could be a blockage, a bad sensor, or oddly enough, the filter needing changing. This calls for a service technician.
https://theelectricdiscounter.blob.core.windows.net/images/air-conditioner/air-conditioner/kelvinator/pictures/e_series_inverter.pdf
Jun 05, 2017 | Heating & Cooling
What does error P1 means in pioneer heat pump
It means the power is off or went off to unit . Check for power then power cycle unit to try and restart .
Nov 14, 2014 | Pioneer Ductless Mini Split INVERTER Air...
Hi I just got a kelvinator kse70hrb 7kw reverse cycle spit system installed yesterday it goes for about 3 mins then stops with e9 error it is a brand new system can u help please. Lucinda
Split = Outdoor unit fan problem. Check Outdoor fan motor is plugged in, Electrically & Mechanically sound, if not replace motor, otherwise replace PCB.
Jan 15, 2011 | Heating & Cooling
Hi, i have kelvinator split system in my house.but...
May 19, 2010 | GE Zoneline AZ38H12DAD Split System Air...
Remot control not working for this unit
change batterys if not working contact tech support from kelvinator
Feb 26, 2009 | GE Zoneline AZ38H12DAD Split System Air...
Kelvinator split system a/cond
Oct 16, 2008 | Heating & Cooling
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
