Question about Aiwa TV-S2011 20"
Power malfunction - Aiwa TV-S2011 20"
  • 57 Answers
Power cable damaget, get new one
Posted on Apr 20, 2013
Scanner read code p1792 in mahindra maximo
Definition of check engine code P1792:
Acura:
TRANS EEPROM Checksum Error
Chrysler/Dodge/Jeep:
Battery power was disconnected since last power down
Citroen/Peugeot:
Barometer Pressure Circuit Malfunction
Ford:
GM:
Transmission Control Module Reprogrammable Memory
Honda:
Problem in Engine Coolant Temperature (ECT) Sensor Circuit
Isuzu:
Trans EEPROM Checksum Error
Jaguar:
Ignition Supply Malfunction
Kia:
Mercedes:
Opel:
CAN data bus,ECMITCM communication - malfunction detected
Volkswagen/Audi:
Transmission Range Display Circ. Short to B +
Volvo:
Sep 07, 2017 | Mahindra Cars & Trucks
Engine malfunction warning
Did you try different reader?May code came later.
Oct 13, 2016 | Cars & Trucks
I'm looking for a code identifier
Acura
Chrysler/Dodge/Jeep
Citroen/Peugeot
Ford
GM
Honda
Isuzu
Jaguar
Kia
Mercedes
Opel
Volkswagen/Audi
Volvo
Dec 13, 2015 | Cars & Trucks
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
98 suzuki sidekick 1.6L several malfunction codes 0141 H02S circuit malfunction, 0335 CKP sensor malfunction, 0510 CTP Switch malfunction, and 1408 MDP sensor malfunction. Issues are bad fuel mileage
that is a 12vdc power problem.
the sensors are failing , many do to lost power. (12vdc electrical distribution power)
so use a voltemeter, i bet even at he cig lighter port the voltage drops
below 13.3v running, way below. infact.
are your battery terminals clean,
is the rested voltage at the battery terms 12.6v (keys in pocket)
no? then the battery is being discharged,
Feb 26, 2013 | Suzuki Cars & Trucks
Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
Aug 14, 2012 | Office Equipment & Supplies
Want to locate censor p0705 on a 2006 suzuki forenza
DTC P0705 - Transmission Range (TR) switch circuit malfunction (short to power supply)
DETECTION CONDITION
• Two or more range signals are input from the TR switch for 12 s or more.
Diagnostic support note:
• This is a continuous monitor (CCM).
• MIL illuminates if TCM detects the above malfunction condition in two consecutive drive cycles.
• PENDING CODE is available.
• FREEZE FRAME DATA is available.
• AT warning light illuminates.
• DTC is stored in TCM memory.
POSSIBLE CAUSE
• TCM malfunction
• Short to power supply in wiring harness between TR switch terminal A and TCM terminal 1D
• Short to power supply in wiring harness between TR switch terminal E and TCM terminal 2C
• Short to power supply in wiring harness between TR switch terminal D and TCM terminal 2B
• Short to power supply in wiring harness between TR switch terminal G and TCM terminal 2E
• Damaged connector between TR switch and TCM
• TR switch malfunction
Inspect swtich harnesses and test with OBD scanner reader tool.
Sep 30, 2011 | 2006 Suzuki Forenza
KDL-40XBR4 bought 1/08. Turns on for 30 seconds with screen staying dark. Then it goes off automatically with the stand-by light blinking 5 times repeatedly. Took it to the shop and he said the LCD panel...
KDL- Bravia blink codes (Australian):
2 times-Main power supply voltage error (12V, etc)
3 times-Malfunction of 3.3V line
4 times-Malfunction of 5V line
(Voltage Supply to FE, etc)
5 times-Malfunction of power supply for screen
6 times-Malfunction of inverter or overcurrent, etc
7 times-Abnormal temperature inside unit
8 times-Audio circuit error (amplifier, etc.)
9 times-Fan malfunction
10 times- Digital FE circuit error
11 times-Malfunction of Trident IC or around IC
12 times-BH board error
13 times -Malfunction of balancer
If this is correct the 5 blinks is the power supply having problems, I would much rather change the PS than replace the screen. Also if screen is determine bad, look for class action lawsuit on Sony for defective screen, i am told they know all about this.
Mar 06, 2011 | Sony Televison & Video
How can fix code P0703 on mazda 6i v6 2005
The conditions that set this code are as follows:
The PCM monitors changes in input voltage on Brake Switch No. 1. If the PCM does not sense voltage changes at PCM terminal 82 when alternately accelerated and decelerated 8 times, the PCM determines that brake switch No. 1 has a malfunction
Possible Causes are:
  • Brake Switch malfunction
  • connector or terminal malfunction
  • Short to power circuit between Brake Switch terminal D and PCM terminal 82
  • Open circuit between Brake Switch terminal D and PCM terminal 82
  • Malfunctioning PCM
Nov 11, 2009 | 2005 Mazda 6
Minolta dialta Di200 on screen :malfunction detected code:COO4E
C004E: Power Unit Cooling Fan Motor malfunction
Check the power supply fan for proper operation.
Nov 11, 2008 | Konica Minolta DiALTA Di200 Copier
Aiwa TV-S2011 20" Logo
18 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
