Question about Whirlpool Ovens
Fxtp6 whirlpool
P1 error
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
Whirlpool error code 177c
This fault is not listed, please contact your local dealer repair service.
Mar 01, 2017 | Whirlpool Ovens
Error AM71 UI44 EEWET107 when I replug the oven broil does not work
Whirlpool RBD305PDS Electric Double Oven Repair ... - Fixya
www.fixya.com > Forum > Ovens > Whirlpool
Whirlpool Oven has an F1E1 error code. Whirlpool Ovens ' Answered on Nov 04 ...Whirlpool error code am71 ui44 eewet107 ยท Whirlpool Ovens ' Posted on Nov ...
Sep 12, 2015 | Ovens
Oven Whirlpool AKZ 223/IX/1 error code - F 03
Looks like a problem with oven temperature sensor. Some of these models have a thermal fuse which may need to be checked and reset if possible or replaced.
The sensor is not cheap. see site
WHIRLPOOL OVEN SENSOR TEMPER for AKZ223 IX 858522304000
Aug 06, 2014 | Whirlpool Ovens
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
I am trying to replace a simmerstat in an old hotpoint cooker and have been supplied with an EGO 50 52076 070 as a universal replacement. The old simmerstat has terminals 'live' 'neutral' and 'load' - how...
I bought some of these simmerstats to refurb an industrial machine and faced the same issues - which terminals do what?
The parts came with a confusing wiring diagram, the terminal numbers didn't match.
The good news is that you can easily get inside this unit to see how it works without damaging it.
Release the metal front plate by gently lifting the tangs with a screwdriver then undrneath is a plastic shield which isn't glued in or anything, it just pulls out.
Here's what I found:
The bi-metal heater is connected between 2 and 4.
The bi-metal switch is between P1 and 2.
There is an auxiliary switch between 4 and P2 (P2 is the same metal strip as PILOT).
The auxiliary switch is closed when the control is 'not off'.
I also noted the short metal stub near 'TOP', in line with 2.
It is in fact the same metal strip as 2 so should be treated with respect i.e. it has mains voltage on it.
For my application, I wired:
Live in to P1
Neutral in to 4
Load powered from 2, returning to Neutral
Pilot Light from P1 to P2 (observe that the pilot wiring is a bit scary because it has a switched neutral).
Dec 22, 2010 | Ovens
I have received an EGO 50.52076.070 energy regulator as a replacement for an old Diamond H 31ER1HT, included was a wiring diagram showing the following connections for the replacement, P1 : Line. ...
Unfortunately the EGO 50.52076.070 is not the correct replacement for a Diamond H 31ER1HT as it does not have a live pilot connection.
Regards Murv...
Dec 16, 2010 | Ovens
F1E1 error on my whirlpool oven. What does this
F1-E1 Defective ERC Replace ERC
ERC= electronic oven control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool oven model RBS245PRB00. broiler stays on in bake mode. electronic control has continuity between P1-1 and P1-2 at all times. is the board bad?
This is a frequent problem that we repair on these boards. It can be repaired at a significant cost savings over a new board.
Regards,
Bruce
www.fixyourboard.com
Mar 03, 2010 | Whirlpool RBS245PDS Electric Single Oven
Whirlpool gold accubake
I have the same problem, Whirlpool is not a good, quality appliance that you could get.
For the error code, refer to link below - not all are accounted for.
http://www.repairclinic.com/0078.asp#Whirlpool1
For a end users horrible experience with this appliance manufacturer...it's worth reading.
http://www.consumeraffairs.com/homeowners/whirlpool_ranges.html
Aug 05, 2008 | Ovens
Ovens Logo
53 people viewed this question
Top Whirlpool Ovens Experts
ashburton
Sal De
Oloyede Monsuru
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
