LG notebook battery problem?
I have an LG notebook ( LGR38 ) and i am suffering from a battery problem .. last year my laptop was hit on the right side .. since then the battery is bad .. it only shows a red X .. i can put it for two days on charging but after it is removed .. the laptop shutts off after max of half an hour .. any suggesstions would be really appreciated
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 69 Answers
Sorry, a dead battery is a dead battery... perhaps a cell was destroyed when the impact occurred, there's really no home remedy to fixing a battery cell.. sorry mate!
Posted on Apr 19, 2013
  • 101 Answers
SOURCE: M670 notebook not charging when plugged in
Charge the Battery fully before first use . The red flashing indicator shows that the battery has been deeply or fully discharged . Please Connect your laptop to AC power source and let it remain for well over 10 hours atleast.If the battery pack is alive it might recover and start working normally.
Posted on May 02, 2008
benjc
  • 15 Answers
SOURCE: My LG LW60 notebook computer
I would recommend just buying a new battery. Sometimes when the battery gets to old, it stops charging completely. It's not a got idea to take apart your system because you most likely won't be able to put it back together. A new laptop battery typically runs about $125.00. It would be a lot cheaper to just buy it rather then buying a new power supply, which is what you will need to do if you take apart your computer. I know because it's happened to me before.
Posted on Jun 18, 2008
  • 629 Answers
SOURCE: Battery Charge light flashing 4 red one green Dell Inspiron 9200
usually, its an indication that the battery is nearing the end of its useful life. you can try to use another battery to isolate it further. If the same thing happens with another battery, chances are, the mobo is failing. Flashing the BIOS can usually help with battery issues. If another battery works fine and your computer is within its first year since you bought it, you can request a replacement battery from Dell
Posted on Mar 16, 2009
SOURCE: New battery needed!
The Everex SA2052T uses the same battery as a Averatec 2260 (2200 series) laptop. I purchase one from provantage.com this week. The battery is made by BTI and the model number is AV2200. It works perfectly.
Posted on Aug 04, 2009
Holygrass
  • 443 Answers
SOURCE: my laptop shows red cross
If the message says consider replacing the battery, I guess the battery life is about to end.
Its good to replace the battery if you have used to laptop for more that 3 years now. Normally that is the max battery life.
However, if the laptop is new and still under warranty, you need to contact your vendor for possible free replacement, since it is abnormal for the battery to wear in such a short time.
Also make sure the replacement battery is perfectly compatible to your laptop. Your vendor can guide you more.
I have replaced batteries in the past. Remove it from the laptop and get the number off of it. Then you can go and Google the number to find a reasonably priced replacement.
Hope this helps you.
Posted on Dec 26, 2010
Tip
How long will my battery last?
Your laptop batteries will deteriorate over time whether you use it or not. Although the Li-Ion industry does not publicize this fact, your laptop battery’s clock began ticking the moment it was assembled. The elements inside your laptop batteries slowly react with each other, eventually rendering the battery unable to supply the required power to your notebook. In addition, your laptop batteries are rated to last between 300 and 800 charge/recharge cycles. It will gradually lose charge capacity rather than abruptly fail to power your notebook.
The general consensus is that laptop batteries last one to three years. While you can slow the laptop battery’s aging and loss of capacity, you cannot stop either decline. The temperature of the battery, combined with the amount and nature of its usage contribute significantly to your battery’s lifespan. You can ease the aging process with some care and maintenance.
Temperature Lower temperatures slow down the self-discharge (loss of charge while disconnected) and aging process of the elements within your laptop batteries. Therefore it follows that higher temperatures shorten the life of your laptop batteries. Leaving your battery connected while on AC power causes the internal temperature of the battery to rise. Removing your laptop batteries and storing it in a cool, dry place will help to slow the aging process. Keeping your notebook in a hot environment is also detrimental to your battery.
Amount of Usage The Lithium-Ion batteries used in notebooks are rated to handle between 300 and 800 charge/discharge cycles. Some of these cycles are used when you leave your laptop batteries connected to your notebook while on AC power. On AC power, the notebook will routinely “top-off” the battery when its charge reaches predetermined levels (i.e. 95%). Removing your laptop batteries and storing it in a cool, dry place will help to preserve some of these cycles.
Nature of Usage Li-Ion batteries do not suffer from the memory-effect (requiring complete discharge before recharging to avoid loss of capacity) like older rechargeable batteries. Regular full discharge/recharge cycles result in an increased loss of capacity per cycle. A series of partial discharge cycles are better for Li-Ion batteries than a single full discharge. You should, however, calibrate your laptop batteries routinely. Tell No One You Can Save up to 35% 3323.jpg
Dell TC030 Laptop Battery
Today's Price:AU $94.55 3711.jpg
Dell 312-0460 Battery
Today's Price:AU $106.31 3770.jpg
Dell GK479 Laptop Battery
Today's Price:AU $92.93 4214.jpg
HP HSTNN-OB81 Laptop Battery
Today's Price:AU $65.72 inspiron8600.jpg
Dell 01X284 Laptop Battery
Today's Price:AU $82.01 1797.jpg
Dell Inspiron 9100 Laptop Battery
Today's Price:AU $115 75uyf.jpg
Dell 1691P Laptop Battery
Today's Price:AU $79.38 4834t.jpg
Dell 2834T Laptop Battery
Today's Price:AU $74.08 bat-30il.jpg
Dell 2941E Laptop Battery
Today's Price:AU $61.34
on Jun 01, 2010 | Computers & Internet
Tip
Something about Replacement For HP Pavilion dv6000 Laptop Battery
Replacement For HP Pavilion dv6000 Laptop Battery - Extended capacity laptop battery for hp pavilion dv6000 series.The
lithium-ion replacement pavilion dv6000 series battery sold on http://www.discount-battery.eu.com/laptop-batteries/hp-
pavilion-dv6000.htm works with your notebook to reduce power consumption, letting you work longer than with other types of hp
pavilion dv6000 series batteries.This replacement battery pack is rechargeable, removable, Lithium Ion battery.The Hi-Quality
battery meets or exceeds original manufacturer specifications for your battery in quality, durability, and performance. Li-
ion batteries do not suffer from the memory effect. They generally last between 300-500 charge/discharge cycles. All
batteries are tested for 100% quality control assurance. This battery includes a one year warranty. We offer a 30 day money
back guarantee and fast shipping on all of our products.
on Apr 01, 2010 | Computers & Internet
My LG VX8300 says use genuine battery. Its a new battery! Help!
This thing haunted me for year. Even though I moved on to 3 or 4 new phones since I had my VX8300. I still have it because a spare phone comes in handy, especially when you have a TEEN!!! lol. It is the easiest fix EVER. Ok, first access the phones hidden menu:Dial ##program8300 and hit send, Now, hit 6 or HARDWARE TEST, next hit 5 or BYPASS BOOTING and last, hit 2 or BATTERY FAKE MODE and set that to ON. The phone may reboot itself, i forget or you may have to do it yourself. Upon reboot, you'll be GOLDEN!!! Take care and good luck.
Dec 03, 2010 | LG VX8300 Cellular Phone
I plug in the power supply the notebook doesnt power up but the green light on the supplier goes off?
Unplug the notebook, take out the battery.
Hold down the power button for 10 seconds
Now replug in your notebook
If it powers on, then the unit suffered a minor surge and you should from this point use a surge protector from now on.
If it does not power on, then the unit suffered a severe power surge and now the motherboard is blown and needs replacing or buy a new notebook.
Mar 16, 2010 | Dell Latitude D600 Notebook
My acer travelmate 6292 wont boot into windows. It goes into a blue screen after I hit last known good any version. It freezes up when I try to boot in any version of safe mode.
Hi
Unfortunatley your Laptop is suffering from the blue screen f death, if you cannot get into safe mode then unfortunatley you will have to reformat the laptop
If this has been useful please leave positive feedback/vote
Feb 11, 2010 | Acer TravelMate 2300 Notebook
Solo 9100 battery
Well, 8 years is an excellent life for any laptop battery. Being that old it will either be a nicad or nimh battery, both of which suffer from battery memory. There is very little you can do. Sometimes, charging the battery as much as possible, REMOVE IT FROM THE LAPTOP, put it into a plastic bag, seal it against moisture, and then put it into a freezer for 12 hours. Replace it into the laptop, charge it again, repeat twice more. If the battery has a bit of life in it you may be able to reclain SOME of it's capacity back. This is a last ditch effort, and should be carried out as a last option. That leaves either buying a new battery, this eBay link will take you to one
http://cgi.ebay.co.uk/NEW-Laptop-Battery-for-Gateway-Solo-2300-2500-9100-9150_W0QQitemZ230370600615QQcmdZViewItemQQptZLaptop_Batteries?hash=item35a32866a7
It's probably time to replace the whole laptop though.
Hope this helps
Jan 03, 2010 | Gateway Solo 9100/9150 Series Laptop...
Battery won;t charge - light stays a solid orange and computer won'tturn on without adapter - less than a year old
it is very obvious that the battery cell of your laptop is totally dead. That's why it would not charge and power your laptop.
Therefore the fault is from your laptop battery.
The solution is that you try to buy another battery and your laptop would be perfect once again.
I am facing the same problem presently. I have tested it with another battery and found out that, my battery is dead. I have not bought another battery yet, because I don't have the cash right now, so I am using my laptop with my adapter till I get another battery.
We both suffer the same problem, so go get another battery.
Dec 31, 2009 | Acer Aspire One PC Notebook
How long is the battery on a HP Pavilion dv9000 supposed to last?
Laptop batteries will usually last from 1.5 to 5 hours, depending upon the demand, the battery and the use. Sound burns up a lot of juice as does the DVD player so if you're watching movies or playing games an hour is about right. You can purchase a better HP PAVILION DV9000 Battery with 12 cell , it will work longger.
detail: http://www.battery-center.net/hp-pavilion-dv9000-battery.html
Dec 04, 2009 | HP Computers & Internet
New battery needed!
Nov 17, 2008 | Everex StepNote SA2050T Notebook
Computers & Internet Logo
114 people viewed this question
David Payne
David Payne
