Question about Troy Bilt 175HP Manual 42" Riding Mower
Troy-bilt riding mower won't move in forward or reverse
I've already changed all the belts - I think it's a broken spring
  • 4 Answers
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Posted on Sep 19, 2014
  • 12 Answers
SOURCE: NEED A DIAGRAM OF HOW TO ROUTE A BELT ON A TROY
type in your model number to your search engine. find your model and the diagrams will be there.
hope this helps.
Posted on Aug 13, 2010
e-Guru
  • 3917 Answers
SOURCE: Deck belt broken, l need
You will find the diagram on the left side of the deck as you sit on tractor by left foot. It will be located under the foot pedal that has the routing diagram specifically for your Troy-Bilt mower model. Note that owner's manuals may not have the most current schematic.
Also you can check this link to download the diagram:-
http://www.seapyramid.net/rt/belt-diagram-troy-bilt-riding-lawnmower/
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 20, 2011
  • 150 Answers
SOURCE: can i get a diagram
without more information i can only give you a link.http://www.troybilt.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10001&catalogId=14102&langId=-1#Error
if this dose not help please contact me back with more info like model, make, year and I will do better.
Posted on Jun 05, 2011
SOURCE: I need to replace the drive belt on a Troy-Bilt 16S riding mower with a 42" blade deck and I do not have a model# or serial# on the mower (label under seat apparently came off at some point before I i
Lowes or Menards sell troybuilt they may be able too hook you right up.
Posted on May 05, 2012
waynepwelker
  • 25 Answers
SOURCE: I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Posted on Jun 27, 2012
Troy-bilt troubleshooting
Sounds like you have an issue with a broken or off pulley belt.
Aug 06, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Replaced drivebelt on troybilt riding mower now the forward pedal moves mower in reverse?
Sounds like you have the belt running in the opposite direction. You need to Change the way the belt is routed around the pulleys
Jun 18, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy-Bilt Horse XP, Model 13bx79kt011 - Won't Move
You need to check the belt to the hydro units is connected properly and is tentioned and not slipping in the pilleys
May 31, 2013 | Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Jun 27, 2012 | Troy Garden
My 50" troy bilt zero
All riding mowers have a seat safety, blade engage safety and a brake clutch safety, some mowers have a reverse mowing safety. Seat under the seat, blade and brake you will have to check the linkages underneath, and if there is a reverse mowing one I have seen them near the shifter handle right under the fender.
Aug 23, 2011 | Garden
I have a Troy-Bilt riding mower. The belt that makes the mower move in forward and reverse is very loose, like it would need to go around another pully. I can't see where it has one for it to go around. It...
You may have lost an idler pulley or it has come off its normal route. The belt may be stretched out and need to be replaced.
You can go to www.precisionope.com and find an Ilustrated parts look up to see how it is on there. This model may be found under Troybilt or MTD.
Sep 28, 2009 | Garden
Troy Bilt 175HP Manual 42" Riding Mower Logo
5,651 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
