Question about Sony BRAVIA KDL32V5500 32 in. TV
Sony Bravis Kdl 32v 5500 Standby light is on but no picture or sound
  • 86 Answers
SOURCE: Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Posted on Mar 25, 2009
rustym62
  • 201 Answers
SOURCE: Sony Bravia KDL-40V3000 standby light blinking
I just worked on this last week 13 blinks means there is a problem with the backlights.So it can be 1 of 2 things bad inverter board( which costs less than $200) or the panel in which case you can thow the TV away as it will probably cost as much for a new TV.Unfortunately the set I worked on ended up being panel. If you try the inverter board just take your time removing it its plugged in rather tight I gently tapped it out with a screwdriver to get it started.
Rustym62
The TV Dude
Posted on Apr 27, 2009
tlm931
  • 273 Answers
SOURCE: kdl-40xbr standby light blinks 13 times no picture
you either have a power supply problem or a inverter bd problem
id suspect the inverter board
its the panel that supply the power to the cold lamps that back light your lcd screen
Posted on Oct 25, 2009
tvhelp-Dave
  • 178 Answers
SOURCE: Bravia KDL-46VL130 TV: Our Sony KDL-46VL130 picture is streaking and some...
That symptom may cause by the main board or t-con board, I suggest you do software up grade first.
Posted on May 07, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
Posted on Aug 05, 2010
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Sony KDL-40S20L1 Flashing Standby Led, No pic, No Sound
try some of the solutions on this link hope one will work for you. http://www.docs.sony.com/release/KDL32S20L1.pdf look under troubleshooting for no picture good luck
Aug 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
No picture, no sound display though back light lamps are ON.
Contact the authorized service center for Sony. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 16, 2015 | Sony Bravia V-Series KDL-52V4100 LCD TV
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
Apr 01, 2010 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
No picture.. standby light on sony bravia lcd
try to replace the regulator or the horizontal out of the t.v. and when nothing happen maybe the jungle i.c.
Sep 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
14 blinking red lights (standby) sony lcd
14 times means the LCD panel is defective. I just had one of those tvs in my shop. Sony will take care of the panel replacement in warranty.
Mar 01, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I would take that puppy back to store and get exchanged out. According to lemon law. Let me know what happens. Thank you Jay.
Jan 31, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL32V5500 32 in. TV Logo
52 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
