Lines at the back of the copy on dp205 duplo
Master lentgh on trail edge short need to set master length on drum
jaylex
  • 417 Answers
SOURCE: hp LaserJet 3015 Printer.
is it wavy? if so then it is either the toner cartridge or the fuser unit (heat section) I would go for the fuser unit as the hot roller that makes the toner stick to the paper is only a plastic film. Have you noticed any gray pieces of plastic coming out?
Hope this help you and you can get these machines repaired also please rate me
Cheers J
Posted on Dec 31, 2007
  • 8 Answers
SOURCE: Media curls on lead and trailing edges
Any of the following:-
Ensure the correct paper weight settings are in use. Excesive heat will cause paper curl.
Feed paper short edge first.
This is normal with high ink coverage on light paper. Use a heavier weight paper.
Your fuser may need replacing.
Posted on Jul 05, 2008
  • 34 Answers
SOURCE: When running 11 x 17
check and clean the pressure roller.see if that helps.
Posted on Jul 30, 2008
  • 990 Answers
SOURCE: Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Posted on Jan 24, 2009
SOURCE: ''my duplo dp43s have an error display as seen in the drum connot
Ich brauche Softwere fuer meinen Flat bed Scaner CRIST/ Koennen Sie mir helfen?
Danke.
Gerd Rosien
Posted on Apr 03, 2009
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
Duplo dp21 s2 master set miss
Behind the cutter unit is A black sponge roller, turn it manually by hand, you will find A small piece of master/stencil there. Remove it and reload the master/stencil roll.
Aug 15, 2011 | Duplo DP22L Black and White Copier
We have a Duplo 43S copier. Everything seems to
The problem was that a regular sheet of paper had somehow become stuck to the drum and become overlaid with ink so that we did not see it until we got more light on the subject.
Aug 19, 2009 | Office Equipment & Supplies
''my duplo dp43s have an error display as seen in the drum connot copy''
Danke.
Gerd Rosien
Apr 03, 2009 | Duplo DP460H Copier
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
2 streaks down middle of page
Do the black lines go from the lead edge to the trail edge? Also, were the lines there before you replaced the drum? If so the problem lies in the fixing unit.... You most likely need a upper fixing roller.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
MY Duplo copy machine is DP-24SII.my problem is the ink con`t run out from the drum surface or the ink con`t transfer to my clothes
We AEBO is professional manufacturer of compatible duplicator ink and master for Riso ,Ricoh,Gestetner,Duplo.
For Risograph : RZ/GR/RA/KS/CR/RN/RP/RZ/TR/FR /GRHD/RPHD
For Ricoh: VT/JP-6/JP-12/JP-500/JP-10
For Gestetner: CPI2/CPI7/Stencil ink 217 /CP15/18
For Duplo: 504/51F4/544/744/ND 24
With high quality at economical price . We have been awarded USA SGS certificate and China Excellent Brand.
AEBO packing ,neutral and your customized packagings are all available.
Sincerely hope a pleasant cooperation with you .
meachell@chinaaebo.com
Mar 19, 2009 | Duplo DP21L Copier
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Jun 02, 2008 | Xerox Phaser 7750DN Laser Printer
Lexmark 4039 10r
I'm pretty sure this is a printer not a copier.
Take out the cartridge and turn it upside down, you will see a (Usually) green cylinder, does it have a ring of toner, or does it appear to have been scrathed ?
Take the copy and put it next to the drum, does the lines match? Then replace cartridge.
If not open back and take out fuser ( two screws for cover and two screws for fuser, are the rollers o.k? replace fuser.
Oct 02, 2007 | Riso RZ310 Duplicator
16 people viewed this question
k24674
jasbo
jasbo
