Question about Furniture
Acme Infrico bottle cooler will not drop below 2.2
Temperature will not go below 2.2 need instruction on how to regulate as i have no instruction manual
RescueTech
  • 145 Answers
SOURCE: lost instruction manual
Here ya go!
http://www.u-line.com/specs/index.cfm?a=2#a2
If this helps, please rate me!
Posted on Dec 12, 2008
SOURCE: I have lost my instruction
Problem solved just by holding both Red and White buttons together for a few seconds.
Posted on Dec 13, 2008
  • 14 Answers
SOURCE: Vinotemp VT-16TEDS has light on but doesn't cool
You may need to change the cooling system on the unit if the unit is free of dust and still does not cool.
Posted on Sep 21, 2009
bobicehouse
  • 1524 Answers
SOURCE: the cooler will not turn off and keeps chilling
Change the thermostat.
Posted on Nov 03, 2010
SOURCE: I have a Haier 42
Replace the thermostat and/or bad control board. If you don't have electronic repair skills then it would be cheaper to go buy a new one then hire someone to repair it.
Posted on Nov 17, 2010
Manage my life com sears
It depends on if there is anything in it! Those types of coolers are only designed to drop temps of wine bottles to below room temp a few degrees. They don't cool like refrigerator in your kitchen.
Jul 22, 2014 | Vissani MCWC50DST Wine Cooler
Instruction manual for dihl wine cooler 32 bottles
i have a dihl 21 bottle dual control wine cooler. the temperature display keeps flashing and won't set, this is now happening with both top and bottom ... how do i fix it
May 18, 2012 | Refrigerators
I have a GE Monogram ZDB24A under-counter drink refrigerator. Recently, it started freezing all the drinks we keep in it. Even on lowest setting (1), the compressor will continue running and cool the...
Hi Rich
Sounds like it needs a new thermostat.
If you are competent with electrics its a fairly easy repair, only 2 wires and the ground.
See your local fridge wholesaler and ask for a thermostat for a bottle cooler. They should be able tpo supply one.
Switch off and unplug before starting work
Knob generally pulls off or may have a small screw under the knob cap, then find how the casing is fixed, remove the casing the thermostat is fixed either with 2 screws or 1 center knut, be careful when removing the capilliary (looks like a thick silver wire) don't damage it you really will not like the smell.
Replace exactly as removed, takes lots of care and patience, use your cellphone to take images for reference if your not certain.
Hope this helps
Gordon
Apr 20, 2011 | GE ZDB24A Wine Cooler
I have a Char-Broil Grill. My regulator started frosing over or turning white like a freon can would and so I changed the regulator and the new one is doing the same thing. I just replace the bottle...
This is normal under certain temperature and humidity conditions. The gas is expanding as it goes through the regulator and this causes cooling - that much is always the case. If you have had cool weather for a while, then the propane will be cold to start with. The expanding gas will cool the regulator to a temperature significantly cooler than the temperature of the gas in the tank. If it's humid outside, then condensation is going to form and if the regulator is below 32 F, you will get frost. Nothing to worry about, it has no impact on the performance of the regulator. This effect will diminish when the temperature of the propane goes up (after a warm day) and as the level of propane in the tank is reduced (so the pressure drop across the regulator will be less.)
Aug 17, 2010 | Garden
The Marvel 68AR Serial 06090-5018 does not regulate the temputure. When it is turned on it gets as cold as it can and freezes everything.
It sounds as if the thermsitor (temperature dependent resistor used to detect temperature) has failed. You can order a replacement direct from the factory 800-223-3900. PN 42244531 - It used to come with instructions. If you need further assistance, drop me a line. - Subdriver
PS There is one other cause that can lead to similar symptoms: if the unit has a freon leak is is low on charge, it will develope heavy frost on the left wing of the evaporator plate and none on the right and will run almost continously when turned on. This is due to the control senses the plate temperature and not the air temperature. If the frost pattern covers all (or most) of the evaporator plate when running, then my original diagnosis stands.
Mar 16, 2010 | Marvel 6BAR-BD Beverage Cooler
I have an Oster 12-bottle wine celler model OWO912H6H that was a Christmas gift in 2007. I just noticed the temperature is 98 degrees and I cannot get it to come down with the down button. I am very...
Hi, could be faulty thermostat, can you check compressor, is compressor running (working), listen to compressor for clicking sound, unplug it(switched off) for about 20 minutes, replug and let it run (work) for another 20 mins. see if temp. drops, what about temp. inside bottle (wine) cooler, is it 98 or colder, more info. could be valuable. check thermostat, check to see if compressor operates, if cooler temp. 98. remove you products, to another cooler, call mechanic.
Aug 12, 2009 | Oster 12-Bottle Wine Cellar - Black
Wine Cooler Temperture Regulation
Replace the circuit board . Please Rate This !!!! Thank You!!
Jun 08, 2008 | Haier HVF042 Wine Cooler
Keg cooler dropping below freezing (DKC644BLS)
New thermostat needed I would say. As for installing, thats a little more dificult & without writing a novel, but when you get your new part, examine it the try to work out how the manufacturer got it in!!!
Jul 23, 2007 | Danby DKC645BLS Compact Beverage Cooler
Temperature on Keg Cooler (DKC644BLS) is dropping below freezing
Mine did this as well. last night the diplay read "LE" and the temp controls and the C/F buttons were unresponsive. I called Danby. Although I was on hold for 30 minutes, when they did answer they were very helpful. As mentioned elsewhere here, the touchpad has gone bad. You can order it right over the phone. The price of the touchpad is only $2 and shipping is $7. I ordered 2 of the touchpads (why not, right?) and the shipping was still $7 for the both. # for Danby is1-800-263-2629. Make sure your phone is charged.
Furniture Logo
108 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Furniture Expert? Answer questions, earn points and help others
