Question about Toshiba QOSMIO F15-AV201 Notebook
WHEN TRYING TO LOAD NEW OS ON THE BLACK SCREEN WITH WHITE CURSOR I GET VERTICAL DOTTED LINES. THE OS WILL NOT START TO LOAD.
  • ls517 Mar 21, 2009
    I have the same problem.
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
The screen is blue with vertical dotted white moving lines ... menu options are psycodelic in color
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
I hope this will help in solving the problem, and do take care in handling the problem....
Jul 06, 2011 | Sylvania 6626LCT 26 in. LCD Television
We have a Sony Bravia KDL-40V3000 flat screen television. About 6 months ago, the screen started displaying white, green and black vertical lines and dots. This continued for a few weeks and then the...
It's a connection inside the TV that's faulty. It could be as simple as reseating the ribbon cables that connect the control board to the glass display. Or it could be that the fault is on the board and needs to be replaced. The fact that the problem comes and goes should tell you it's fixable.
Apr 28, 2017 | Sony BRAVIA KDL-40V3000 Television
On start-up, the first screen with the Microsoft flag logo has a matrix of blue square dots (about 1/8" square in size) superimposed over the entire screen. Then, when the desktop appears, about half of...
go into your bios and make sure that video memory shadowing is dissabled, Sounds like a faulty video card or damaged signal cable. I would lean more to the faulty card though, try installing a new one as I would say thats your issue if your getting artifacts on the screen before the OS has fully loaded.
OFC you could try new drivers both for your chipset of *********** board and the graphics card in the interim.
Jun 22, 2010 | Dell Dimension 4600 PC Desktop
PB Minos GP2W screen has coloured lines fades white then black
Most likely it's graphic card problem, but also may be monitor itself. First, check the signal by connecting to TV (if yours has a PC input), then replace card if that shows the same.
Aug 29, 2017 | Computers & Internet
Xbox360 elite
check your game for deep scratches on the cd if there is none, then your best bet is shipping it back to microsoft or there is actually a company that fixes your 360 for a cheaper price. just google xbox 360 recall and if you look through the pages of signatures you will find an advertisement for 360 recalls go to that and call the #, i hope it works out for ya.
Apr 24, 2009 | Microsoft Xbox 360 Elite Console - Black
White dotted vertical lines appear on screen whilst playing on my xbox 360 elite. This only happens when playing Halo3 and Fear2.With the rest of the games i have there is no problem.Could you please help...
Hi i on u r screen white dotted vertical lines comming & if the no. is more than 6 the if the laptop is under warrenty then company will replace the LCD & if not under warrenty then to fix this issue u have to replace the LCD.
IBM G41, Can't load fresh Windows XP OS
You will get a better response if you pay for the expertise we have to offer!
May 08, 2008 | IBM ThinkPad G41 Notebook
Open Questions:
Toshiba QOSMIO F15-AV201 Notebook Logo
97 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
