The scroll on my lifebook t5010 wont work. Scrl lck is off. windows 7
Like the title states i cant use the scroll on my laptop and not sure what to do. I have windows 7 and I have tried using scrl lck and it has not worked.
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Press SCRL LCK on your keyboard to re-enable (or a FN combination) if that doesn't work reinstall your MOUSE drivers (not keyboard, very important)
Posted on Apr 19, 2013
  • James Lion Apr 20, 2013
    i did both. just finished reinstalling the mouse driver and the scroll still doesn't work.
  • 62 Answers
SOURCE: Just upgraded to Windows 7 and now my touchpad scroll won't work.
Download driver under device input drivers > Touchpad pointing stick and install.
Cheers,
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&os=WLH&osl=en&catid=&impid=&SystemID=INS_PNT_PM_1720
Posted on Dec 01, 2009
SOURCE: My lenovo laptop's touchpad scrolling is not
In lenovo website you need to download the touchpad driver for windows 7.. its easey.. remeber download for the correctly version w 7.. example ultimate or professional or starter.. ok.. pls click my solution was usedfull.. good luck
Posted on Dec 27, 2009
  • 309 Answers
SOURCE: I have HP Compaq 610. Touchpad scroll was working
You will need to install the WIndows 7 drivers for your touchpad from HP. I have recently been on HP's site and find VERY few Win-7 drivers for any of the older machines.
Posted on Jan 09, 2010
  • 44 Answers
SOURCE: Laptop Not booting up, Scroll Lock indicator blinking
Your user guide might provide a mean to interpret the meaning of the blinking Scroll Lock Indicator...
Posted on May 09, 2010
ask ask ask
  • 211 Answers
SOURCE: i m using fujitsu siemens
download the drivers!
Posted on Aug 17, 2010
I have fujitsu lifebook Ah531 and using windows 7 x86 Ultimate version.i want wifi drivers because i have download wirless drivers but they are not working plz give me sloution
Here you go http://www.odrivers.com/2012/10/fujitsu-lifebook-ah531-drivers-win7-64.html . These are drivers for your lifebook and if you scroll down you'll see "Wi-Fi / Wireless LAN, Intel" and right below it there's a "Download" button.
Aug 03, 2013 | Fujitsu LifeBook AH531
Fujitsu Siemens T5010 penabled upgrading to dual touch
Help, is this how you upgrage a pen only to a multitouch? I need the part numbers to do this..
Nov 28, 2012 | Fujitsu Siemens LifeBook T5010 Tablet PC
My fujitsu t4220 wont open windows how do i restore it with out the softwere cd
Just had this problem myself. Go into your BIOS. make sure AHCI is disabled and Virtualization Technology is enabled. Then restart. This fixed it for me. Hope it does it for you.
Aug 27, 2012 | Fujitsu LifeBook T4220 Tablet PC
Changing keyboard on Fujitsu T5010
Remove the square screw covers above the keyboard on either side of the swiveling screen hinge. Unscrew the 2 screws and use a small flat head screw driver to remove the plastic cover above the keyboard. Do this by inserting the screw driver underneath the plastic cover near to the f keys on the keyboard and gently pop the cover off. Carefully remove the ribbon from the motherboard, use a small screw driver to release the clip that holds the ribbon in place (ribbon located above f3,f4 keys). Slide the keyboard up and it should release if it doesn't then there may be some sticky tape holding the keyboard down, this is located behind the f2,f3,f4,f5 keys, carefully pull the keyboard away but hold the keyboard by the f keys so that you do not damage the keyboard by bending it. Reverse the procedure to fit new keyboard
May 28, 2010 | Fujitsu Siemens LifeBook T5010 Tablet PC
Sony CDX-S2210 CD Player stuck on demo mode , cant adjust volume eq, skip track or anything
make sure the unit is switched off and the clock is displayed then
1 Press and hold (SEL).
The setup display appears.
2 Press (SEL) repeatedly until the
desired item appears.
3 Press the volume +/– button to select
the setting (example “ON” or “OFF”).
4 Press and hold
(SEL).
The setup is complete and the display returns
to normal play/reception mode.
Note
Displayed items will differ, depending on the source
and setting.
With the card remote commander
In step 3, to select the setting, press
< or ,.
The following items can be set (follow the page
reference for details):
“z” indicates the default settings.
*1 When the unit is turned off.
*2 When the audio output is set to “SUB.”
CLOCK-ADJ
(Clock Adjust)
(page 4)
BEEP To set “BEEP-ON” (z) or
“BEEP-OFF.”
SUB/REAR*1 To switch the audio output.
– “SUB” (z): to output to a
subwoofer.
– “REAR”: to output to a
power amplifier.
DIM (Dimmer) To change the brightness of the
display.
– “DIM-ON”: to dim the
display.
– “DIM-OFF” (z): to
deactivate the dimmer.
DEMO*1
(Demonstration)
To set “DEMO-ON” (z) or
“DEMO-OFF” (page 4).
A.SCRL
(Auto Scroll)
To scroll long displayed items
automatically when the group/
track is changed.
– “A.SCRL-ON”: to scroll.
– “A.SCRL-OFF” (z): to not
scroll.
LPF*2 (Low
Pass Filter)
To select the cut-off frequency
“78HZ,” “125HZ” or “OFF
Jan 28, 2010 | Sony CDX-S2210 CD Player
How to unlock fujitsu t5010 laptop . after purchacing to pc , someone entered a code . now i cant get it unlocked to do anything
Use a linux based password reset disc to reset the password on the laptop.
http://www.petri.co.il/forgot_administrator_password.htm
Dec 29, 2009 | Fujitsu Lifebook T5010 Notebook
My scroll lock wont work and i dont know how to make it work
Press and hold the Fn key while pressing the scr lck key. Notice that the Fn key and the alternate keys have a different color (usually blue).
Aug 25, 2009 | Compaq Presario CQ60-220US PC Laptop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
