Question about Samsung ES90 Digital Camera - Silver"
Es90 wont charge
It wont charge, the red light stops 5mins after plugging it
My camera ES90 will not charge, when i plug it in it seems dead
There can be more than one reason:
The battery can't be charged anymore, because it is defect.
The cable you use is defect
The charger you use is defect
One or more contacts are dirty or oxidised
Carefully check all contacts on the battery, in the camera the battery compartment but also the USB slot, where the charge cable goes in. The contacts should be clean and shiny. No contact should be bent. Cleaning with a dry cloth or cotton swab.
If the cable to charge is defect it is more difficult to detect. Only when you have another apparatus that can be connecter with the same cable, you could check if your cable is still in working order.
The charging source can be defect.
If it is a charger, you plug in a wall socket, check if you can use it to charge something else. If you put it in a PC, also check if that USB port can deliver 5 volt with enough current.
I do have a little gadget, from the beginning of USB and LED lights. An USB plug with a small cord and a LED light on the end of it.
You could use it as a reading light on a laptop. But it showed very helpful to show if a charger or a USB plug on a computer still is delivering 5 Volts.
I hope you find the culprit.
Success
May 26, 2014 | Samsung ES90 Digital Camera
Zoomerpup stopped working
Try removing the battery ONLY for about 5mins. Then reinsert the battery and see if it powers on.
If that fails, remove the battery AND Media Card for 5mins. Reinsert battery first...power on. Then SD card.
If neither of those work, check charger to see if it is working. If there is an LED light on the actual charger, this should light up. If there isn't, then the charger should at least be warm after say, 30mins of charging. If it is still cold, you may need to replace the charger.
Nov 25, 2013 | Toys
MY LG TONE HBS-730 WILL NOT CHARGE
It is charged when the red light goes out. Press and hold the VOLUME DOWN button for one second and an audible will give you the battery charge level - high - medium - low.
Apr 20, 2013 | LG Tone HBS-730 Bluetooth Stereo Headset -...
Samsung ES90 Digital camera will only take 8 photos then says memory full even when fully charged
The Samsung ES90 only has about 37MB of built-in memory. The state of the battery has no effect on this. If you want to take more photos then you can either make them smaller, or better yet, add a memory card.
Mar 06, 2013 | Samsung ES90 Digital Camera - Silver"
How much time should a iQ sound mp3 player charge
MY IQ SOUND MP3 ONLY STAYS CHARGED FOR 5MINS,I PLUG IT IN TO CHARGE AND INSTANTLY IT SAY BATTERY FULL BUT ONLY LAST AGAIN 5MINS,ANY IDEAS.
Dec 05, 2010 | Bell Technology IQ Sound SC-2528 MP3...
Zen wont turn on
when you put it to charge,the blue light beside the power button must blink...if thats happening,let it charge till it powers on...maybe an hour or so...
Sep 02, 2009 | Creative Labs Zen Digital Media Player
Xbox 360 turns it self off after 5mins
dont do that plug the ipod into something that is another USB port
Apr 11, 2009 | Microsoft Xbox 360 Arcade
Schwinn s180 wont charge
hi, just plugg it in turn it on. there should be a red and green light on your charger.
Apr 08, 2009 | Transport Schwinn Rechargeable Portable ...
Samsung ES90 Digital Camera - Silver" Logo
26 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
