Question about Sony VAIO VGN-FZ230 FZ Series Notebook
Screen swap out for a sony vaio vgn-fw235j
I just need a step by step to replace my screen
  • Sony Master
  • 2,404 Answers
With the power disconnected. First off there are 4 rubbers on the screen bezel itself. Take those off and then unscrew the 4 screws.
Then take off the screen bezel itself, it will be held in by clips so you may have to use a flathead to pry it off.
Once you expose the screen, there might be one screw on each side holding in each screen hinge, if so that those screws out.
At this point there will be 4 screws holding the screen in on both the left and right side hinge.
Go ahead and take off the 4 screws on each side of the hinge and this will loosen the screen completely.
At this point go ahead and unseat the connector that goes to the inverter toward the bottom of the screen. Also unseat the connector that goes to the back of the lcd.
At this point you will have the old screen removed.
Now go ahead and screw in the screws on the left hinge and right hinge so the new screen will stay in place. Go ahead and hook up the connector to the inverter, hook up the connector to the back of the lcd. At this point go ahead and turn on the laptop and just verify that the screen works and that there is no defects such as lines in the screen or weird colors. If there is then you'll need another screen.
If you have the 2 screws, screw each one on each side of the hinges to keep the hinges in place.
Then go ahead and snap the front bezel in place, then go ahead and put the 4 screws in place and then the rubbers on and you'll have a working laptop with a new screen in place.
Posted on Jul 05, 2009
Install linux drivers ubuntu
I assume your laptop is a Sony VAIO VGN-FW235J? If so : Mobile Intel 4500MHD Total Graphics Memory 1340MB Chipset Mobile Intel GM45 Express Chipset
Take a look here: https://docs.sony.com/release/SPECS/VGNFW235JH_mksp.pdf AND : http://esupport.sony.com/US/p/model-home.pl?mdl=VGNFW235J&template_id=1&region_id=1&tab=manuals#/manualsTab
Nov 28, 2013 | Sony VAIO VGN-FW235J/B PC Notebook
How do i activate system restore on sony vaio vgn-fw235j
Hi
If you go to the start button then into the search bar type in system restore hopefully it will direct you to it
i am on windows 7 and my restore is in the start programmes maintenace tab
Jan 19, 2011 | Sony VAIO VGN-CS215J/W Notebook
I have (well will have back soon) a Sony VAIO VGN-FW235J/H 16.4-Inch Laptop (2.0 GHz Intel Core 2 Duo T5800 Processor, 4 GB RAM, 250 GB Hard Drive, Vista Premium) Gray. I've had the computer for almost...
If the Computer was serviced from Sony then the Hard Disk will be re-imaged and REcovery Partiton will be created in the Computer.
You can create the Recovery Disc for the Computer using the Recovery Partition.
Follow the steps as mentioned the Article to create the Recovery Discs.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C1002214&sliceId=1&docTypeID=DT_KNOWLEDGEARTICLES_1_1&dialogID=194692373&stateId=1 0 194696415
You can use the Article ID if the Link didn't work in the Esupport.sony.com webpage C1002214.
Nov 24, 2010 | Sony VAIO VGN-FW235J Notebook
My USB Ports of Sony Vaio VGN FW235 stopped working
first remove all the USB Devices connected to the Computer, go to Device Manager, uninstall all the USB Drivers and restart the Computer. after the restart, the Operating System should reinstall the USB Drivers automatically as the USB Drivers are Operating System generic.
If this does not work, go to Device Manager, right click on the USB Device having Yellow Exclamatory mark and click on Update Device/Driver and select search for the best driver in these location and in the location type C:\Windows\inf and click next.
This should resolve the issue.
If this does not work, you can try performing the System restore where the USB ports are working normally.
May 26, 2010 | Sony VAIO VGN-FW235J Notebook
Can vgn-fw235j support windows xp
Ahmad, The Computer VGN-FW235J does not support Windows XP Operating System as Drivers for the Windows XP are not available.
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFW235J
However, if you want to install the Windows XP Operating System in the Computer then you can install it in the Computer but you have to search a lot to get proper Driver for the Computer.
Good Luck!!!!!!!!!!
Jan 16, 2010 | Sony VAIO VGN-FW235J Notebook
Ii want to know how to download sony's vaio vgn-fw235j operating system
you cannnot download this OS, you need a license Operating System say Vista or Windows XP.
operating systems need to be installed correctly
Jul 28, 2009 | Sony VAIO VGN-FW235J Notebook
Vista to XP
ok install windows xp but callcet the driver
Apr 01, 2009 | Sony VAIO VGN-FW235J Notebook
Software not booting up
any light on the laptop try remove battery and power cable and hold the power button for 10 sec and then connect the battery and power cable and turn on the laptop
Mar 13, 2009 | Sony VAIO VGN-FW235J Notebook
I've sony vaio fw23l/w with Vista Home Premeium Korean than i installed english version, now one don't install other unknown device
Dear
You wont have any problem with this unknown device. Unknown device is problem if this unknown device is VGA, sound, LAN etc There are many devices in comuter which are not as essentailly required. So enjoy :)
Jan 30, 2009 | Sony VAIO VGN-FW235J Notebook
Sony VAIO VGN-FZ230 FZ Series Notebook Logo
240 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
