Question about Xerox Solid Ink Printers 8570/DN ColorQube 8570DN - Printer - Color -
Why am i getting the error code 93,599.00:4051 on my Xerox Colorqube printer?
It occurs after start up between 8% and 25% during warming up status. Any help gratefully received
  • 6 Answers
SOURCE: Xerox 8400 dp
It means the printhead is stuck in the tilt position by the tilt arms. If the process motor gearbox is out of sync, it'll cause this error. Steps to resolve: Reboot the printer. Verify the lock arms rotate correctly. Check for spilled ink around the printhead (did you move it without waiting for it to cool down?) Check the process motor gears for damage. Make sure they're aligned and homed correctly. Repeat for process gear box, process shaft, and drive module shaft. Verify the headtilt gear will engage. From there, run the Tilt Axis Drive test, Process Motor test, Head Maintenance Clutch test (replace clutch if failed), and Wiper drive test (replace wiper drive system if failed)
Posted on Sep 29, 2007
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: Xerox 8500 Error 07,101.43:20955
That has to do with the process drive gear box. May be mis timed or a gear broken.
Posted on Apr 11, 2008
  • 2072 Answers
SOURCE: Xerox 8550 printer has error or fault code 37,018:45:24719
Oh yuck. That is a source voltage fault.
The electronics module has most likely failed. Umm very expensive also. See if your insurance will cover repairing it. That way you can have Xerox come in fix it and insurance reimburse you. I have had to do calls like this several times and have had insurance pick it up. You may need an estimate to repair from the insurance company.
Posted on Jan 22, 2009
  • 129 Answers
SOURCE: What causes error code 091-720 on a xerox colorqube 8900x printer?
That error signifies a printhead tilt fault. You need to replace the process drive camshaft kit, part number 8900-Z1.
http://www.iteminconline.com/8900-z1_8900-z1-xerox-8900-process-drive-camshaft-kit.htm
Posted on Feb 29, 2016
Feb 29, 2016 | Xerox ColorQube 8900X Multifunction Color...
What does error code 093-556 indicate on my xerox coloqube
Get in touch with Xerox as a problem with one of the print heads and tubing has a problem. It's not an easy problem to fix without parts.
Good Luck.
Aug 27, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
What does error code 093-547 on a Xerox ColorQube 9301 mean?
Interesting. Recommend reading and trying the software from Microsoft. http://www.saetechnologies.com/colorqube-error-code-093-547/
Jul 17, 2014 | Xerox Office Equipment & Supplies
Our Colorqueb 9303 have the error 093-545, how can we solve it? Thank you
I think you better get in touch with Xerox ASAP.
Sorry this problem is beyond the scope of questions and answers like these.
Good Luck.
Mar 12, 2014 | Xerox Corporation ColorQube CQ9303 9303/P...
Xerox error codes
error code 377.123.02 for Xerox 6700
Jan 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Getting error code 093-516
I looked at the Xerox 8900 support page: http://www.support.xerox.com/support/colorqube-8900/support/enus.html
The answer I found for Error Code 093-516 was problems with Yellow Ink Stick. Our printer had been switched of for quite some time which probably caused the ink stick/sticks to get stuck (or something). I opened the ink bay and pushed slightly on all the sticks to make sure they were "all the way in", added some more ink behind them and it started to work again.
I had to do a few cleaning jobs for smudges and now it's fully operational.
Jan 03, 2014 | Xerox ColorQube 8900X Solid Ink...
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
Apr 11, 2008 | Xerox Phaser 8500/DN Printer
Xerox Solid Ink Printers 8570/DN ColorQube 8570DN - Printer - Color - Logo
108 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
