Question about Whirlpool Washing Machines
Service light on model awo/D 4306..what can i do..have cleaned filter..
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Problem with Whirlpool washing machine - AWO/D 4705
The first thing to check is the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the small metal screens inside the opening on the water inlet valve and make sure they are clear of rust or debris. Check the solenoids using a multimeter or ohmmeter. Test for continuity. A lack of continuity will mean a bad solenoid and the valve will need replaced.
If the inlet valve checks out alright, then the next place to look would be a malfunctioning water level/pressure switch. It is a diaphragm like device with a small plastic tube attached between the switch and the bottom of the washer's outer tub. Make sure there are no obstructions in or damage to the plastic tube. The switch can be tested for continuity in the same manner as the water inlet valve solenoids. Really sorry for your trouble and I hope this helped. Best wishes.
Posted on Oct 15, 2009
SOURCE: Whirlpool washing machine AWO/D 5556 washing machine service light showing ?
The warning light comes on because the machine "thinks" that something is wrong. Since it stops on and off something is wrong.
Why not phone the Whirlpool service in your area and tell him aboout this and ask what you can do??
give it a try
Kolbrun
Posted on Feb 22, 2012
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
Service light on awo/r5206 washing machine
Resetting the washing machine: Follow these tips, click on: Reset
Jan 20, 2013 | Washing Machines
How to replace belt on Whirlpool AWO/R4205
Please find tips from the link below on how to replace belt.
click on Washing machine belt replacement
Nov 11, 2011 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
I need to clen the pump on a whirlpool washing machine awo/d 4505
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Sep 22, 2009 | Washing Machines
Washing machine
whilpool awo/d 4305 light onclean pump can i do this myself
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
49 people viewed this question
Dan Webster
Dan Webster
Sal De
