Canon IR C2880i wrinkling paper
Hi. We have a Canon IR C2880i color copier/scaner/printer. This week this machine started to wrinkling the paper. Paper is printed and just before it suppose to came out, it stops and get wrinkled.I have to remove the paper, than it restarts the job. Usualy, et second or third attempt, the paper came out OK. Thanks, Simon
  • 430 Answers
The printer gears with pull and move paper forward are not working properly.The gears are worn out or either dried out.See if minor gear oiling is helping.
Posted on Apr 19, 2013
  • SimonK Apr 19, 2013
    Sorry, but it didn't help. It looks like, that the heater's gear doesn't tuch other gears. The gap is more than 1mm big.
SOURCE: Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Posted on Nov 04, 2007
SOURCE: wrinkled paper
Try checking the fuser unit inside the back of the printer. Open the door and pull the paper path tray down. You should see an orange vinyl looking roller. If is has wrinkles it probably needs replacing. I have replaced two on my printers and that corrected the wrinkling problem. You can get them on ebay.
Posted on Mar 03, 2009
frankzjm
  • 191 Answers
SOURCE: PRINTER CRUNCHES AND WRINKLES PAPER WHEN TRYING TO PRINT
ok, in this case you need do:
1) check the roller before the fuser and after it some roller old not enough firction and pressure balance
2) check the fuser press roller it could not has good tough to fuser surface, it should be no gap at all and good pressure balance on the fuser surface
3) check the fuser cleaner which maybe too dirty, or change new one if you have the parts.
4) fuser unit maybe too old if printing pagers over its life cycle
hope this help you and please ask me any time.
Posted on May 16, 2009
  • 10 Answers
SOURCE: HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Posted on Jan 29, 2010
  • 1751 Answers
SOURCE: Printer gets a feeding error when paper is exiting
check if your are using different paper from the one that you have told to the printer that has
Posted on May 01, 2010
How can i fix paper jam, close left cover or drawer cover ir 2016 canon
hi . be sure there is no paper jam inside the machine . turn off and on if problem persist maybe some of the flag sensors maybe stuck.
Mar 23, 2016 | Canon iR 2016i Black and White Copier
Clearing error e000067 canon irc2880i
Error Code Canon IR C2880i E-067-102 - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Feb 6, 2013 - 10 posts - ‎5 authors
I have a Canon C2880i that has been giving strange messages. It started with the ... Had to clear dc-con for the drum lifes to regulate. Problem I ...
Canon ImageRunner Error Code Reset - Question Defense
https://www.question-defense.com/.../canon-imagerunner-error-code-res...
Nov 10, 2008 - These are the steps to resetting error codes on the iR5570/iR6570 and other ImageRunner printers. This also refers to eCopy, so follow the ...
How to give code for Normal ERROR in canon IR 3300 ...
? 2:28
https://www.youtube.com/watch?v=WyVgSjP_xms
May 19, 2014 - Uploaded by Prince tv
How to give code for Normal ERROR in canon IR 3300 ... thank you sir my canon ir2870 err no E000002-0000 ...
Jan 18, 2016 | Canon Office Equipment & Supplies
Hi Sir , I have a ir3300 machine the print is very dull (whitish); replaced drum. but still remaining.
Hey, if it was a compatible toner or toners you installed, the i would recommend that you take it back to your supplier to replace the toner or toners. the dull print may be cause of incompatiblity between fuser unit and laser scaner.
Dec 05, 2014 | Canon IR 3300 Digital Copier
Canon ir3300 scaner online waiting
Dear friends,
I have canon ir 3300i (with starter). when i on the machine in the morning, the machine is waiting to print. All the starter and delivery sensors were changed. but problem is continuing... please tell me the solutions..
Oct 13, 2010 | Canon Office Equipment & Supplies
White paper out put
does it occure when you print or when you copy?
First check transfer roller in left sideway door ( long black roller ) maybe it felt down at one side.
Check laser unit shutter.
when making copies does the scaner flash?If not there is your problem.
While making copie aprox. when paper comes on drum open the leftsideway door and check if the "image is on the drum surface.If yes that means that you have transfer issues.
Maybe its stupid but do you have toner inside?
Aug 15, 2010 | Canon iR 2016i Black and White Copier
Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Jun 09, 2009 | Canon Pixma MP480 All-In-One InkJet...
How to rectify error E007
"E007" Fixing film has become displaced
Check the fuser the film ( usually brown ) that heats up and melts the toner to the paper is either torn or has moved to one side. this is a pain in the neck to fix, it use to take me 2-3 hrs to replace the film and on top of that most of the time you end up wrinkling the film or tearing it or it moves to one side and gets damaged!!!! that was my personal experience, well after doing that 3-4 times I just ordered the whole fuser and replaced it ( company was not too happy, but, when they see you going out 2-3 times for one machine for the same problem not much they can say !!
Dec 23, 2008 | Canon iR 2016i Black and White Copier
Canon iR c3220 problem code E00000 0211 HELP!
problem w/fuser unit.
either it's not turning on or the temperature is not correct.
check thermistor, thermofuse, lamp
Oct 09, 2008 | Canon imageRUNNER C3220 Color Copier
137 people viewed this question
jasbo
jasbo
