Question about Ricoh Aficio 1515MF All-In-One Laser Printer
Follow the instruction from right cover to remove
5 Suggested Answers
SOURCE: ricoh 2015 printer
The B is saying there is a jam in the right hand side of the machine. You may have fuser stripper fingers popped out of place causing it to jam or you may have a torn off piece of paper stuck between the registration rollers. Try spinning the black and silver rollers by hand and see if any paper comes out.
Posted on Oct 09, 2007
NALDZ
  • 38 Answers
SOURCE: A follow instructions in right cover to remove
U JUST FOLLOW THAT INSTRUCTION TO REMOVE THE MISSFEED
Posted on May 17, 2009
  • 46 Answers
SOURCE: Follow instructions in right cover to remove
1. Make sure that the end fence is properly set.
a. Pull tray and remove paper
b. Unlock the side guides
c. open side guides all the way out
d. place about 30 sheets of paper in tray
e. use side guides to align paper properly
f. push paper all the way to the right so that it's flush with the right edge of the tray.
g. move end fence against the paper.
h. load the rest of the paper making sure it does not surpass the upper limit which is indicated on the side guide.
i. adjust paper size dial to match size and orientation
Posted on Aug 28, 2009
joel_baleta
  • 155 Answers
SOURCE: keeps on giving the following message
pls look again. i also experience it turn the lower knob downward to push the paper several times located om the tray on the right side. hope this help.
Posted on Jan 26, 2010
How to install transferbelt
  1. Remove or slightly pull out Tray 2 (RM1-1916-000CN).
  2. Remove three (3) screws, two (2) from the right cover assembly and one (1) from the left cover
    assembly.
  3. Open the front door
  4. Remove the right cover (RM1-1858-000CN), carefully twisting the front edges of the side covers
    outward to remove.
    NOTE :
    To make the removal of the right cover assembly easier, release the tab on the inside of the cover.
  5. Remove the left cover.
  6. Squeeze the white link lever on the left side.
  7. Remove the screw on the right white plastic catch, and then remove the plastic catch.
  8. Close the ETB.
  9. Remove the small black cable cover (RC1-5147-000CN) on the left side of the printer by carefully snapping it out of place.
  10. Remove one (1) grounding screw from the ETB harness.
  11. Pull out the white wire holder by pushing it up.
  12. Pull out the ETB connector.
  13. Remove one (1) screw from each hinge cam on both sides.
  14. Using needle-nose pliers, remove the hinge left cam (RC1-4249-000CN) and the right hinge cam (RC1-5311-000CN).
Remove the ETB. Use the following procedure to replace the ETB.
  1. Align each foot of the ETB with the respective holes, securing the right side first, and then the left side.
  2. Complete replacement by following steps 1 through 14 above in reverse order.
NOTE :
When replacing the right cover, align the tabs on the upper edge of the right cover and lower edge of the face-down cover with their respective slots.
Nov 19, 2013 | HP Color LaserJet 2600n Printer
How to remove casing
To make sure there is a clear understanding here's a complete diagram
Overall Parts Diagram
To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer
1) Remove Right-front cover and control-panel assembly
a) Open the front door and the right door.
b) Remove two screws (callout 1).
c) Release 3 tabs (callout 1) on the right side of the assembly.
d) While holding the assembly up, pull the cable holder (callout1)
disconnect one connector (callout 2).
2) Remove Left cover
a) Remove Tray 2 from the product.
b) Open the front door.
c) Remove three screws (callout 1). Starting from the left side
tabs (callout 2),and then remove the cover from the product.
TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover.
Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis.
3) Remove Rear cover
a) Remove six screws (callout 1), and then remove the cover
from the product.
4) Remove Toner collection unit access door
a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg
b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door.
CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg
c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door.
5) Remove Right-rear cover
a) Remove the rear cover. See Rear cover on page 93.
b) Open the right-door assembly.
c) Remove two screws (callout 1), release one tab (callout 2),
and then remove the cover.
CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it.
6) Remove Top cover
a) Remove four screws (callout 1).
b) Open the toner-collection door.
c) Release two tabs (callout 1), and then remove the cover.
7) To Reassemble Follow Instructions in Reverse
Jul 08, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
How do u remove the printer cartridge when its finish from the hp laserjet p2035
Follow these steps to remove the toner cartridge.
1. Push the front cover button on the top right side of the printer.
2. Open the cover towards the front of the printer.
3. Grasp the black/grey cartridge by the middle handle and pull it up and out of the printer.
Instruction should also be provided with the new cartridge.
Aug 09, 2010 | HP Office Equipment & Supplies
I need to install a heater core for a 2001 Pontiac bonneville I need instructions on how to remove and install it.
prev.gif next.gif HEATER CORE REMOVAL AND INSTALLATION 1997–01 Models BONNEVILLE AND LESABRE
  1. Disconnect the negative battery cable.
  2. Drain the cooling system into a clean container for reuse.
  3. Remove or disconnect the following:
    • Heater hoses from the heater core
    • Right sound insulator
    • All necessary electrical connectors and remove the instrument panel compartment
    • Temperature valve actuator
    • Electrical connector and remove the HVAC programmer
    • Heater core cover-to-heater assembly screws and the cover
    • Heater core-to-heater assembly screws and the heater core Fig. 1: View of the heater hoses and clamp positions — 1997–01 Bonneville and LeSabre 93111g71.gif
      Fig. 2: View of the heater core cover — 1997–01 Bonneville and LeSabre 93111g72.gif
    To install:
  4. Install or connect the following:
    • Heater core and the heater core-to-heater assembly screws, then, tighten the screws to 12 inch lbs. (1.4 Nm)
    • Heater core cover and the cover-to-heater assembly screws, then, tighten the screws to 12 inch lbs. (1.4 Nm)
    • HVAC programmer and connect the electrical connector
    • Instrument panel compartment and connect any necessary electrical connectors
    • Heater hoses to the heater core
  5. Refill the cooling system.
  6. Connect the negative battery cable.
  7. Operate the engine to normal operating temperatures; then, check the climate control operation and check for leaks.
Jul 01, 2010 | 2001 Pontiac Bonneville
Follow instrctns in right cover to remove
is it a miss feed problem? open the cover on the right cover of the machine then remove the jammed paper. then close the covers
May 26, 2010 | Ricoh Aficio 2015 Copier
How to exchange the ETB unit (belt) on a HP Colorlaserjet 2600n?
To replace the ETB Belt.. follow this step..but it would be easier if I can show u the diagram.. I will figure a way to upload. but let see if u understand here...
ETB removal and replacement
Use the following procedure to remove the ETB (RM1–1881–000CN).
1. Remove or slightly pull out Tray 2 (RM1–1916–000CN).
assembly.
3. Open the front door.
4. Remove the right cover (RM1–1858–000CN), carefully twisting the front edges of the side covers
outward to remove.
NOTE : To make the removal of the right cover assembly easier, release the tab on the
8. Close the ETB.
9. Remove the small black cable cover (RC1–5147–000CN) on the left side of the printer by
14. Using needle-nose pliers, remove the hinge left cam (RC1–4249–000CN) and the right hinge
cam (RC1–5311–000CN).
15. Remove the ETB.
side.
NOTE : When replacing the right cover, align the tabs on the upper edge of the right cover
May 23, 2010 | HP Color LaserJet 2600n Printer
MACHINE DO NOT COPY AND GIVE THE FOLLOWING MESSAGE: (A ZIGZAG SYMBOL) WITH "FOLLOW THE INSTRUCTION"
Sounds like the 'Clear misfeed' symbol. Open the front cover and follow the pictorial diagram instructions to check your paper feed path for jammed paper. Remove misfeed, and close covers. This should reset your machine.
Jan 30, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Keeps on giving the following message "Read instructions in right cover to remove" There no paper there at all but this keeps coming up.
Jan 23, 2010 | Ricoh Aficio 450 Copier
Aficio MP1500 displays'' follow instruction in cover to remove''
WHAT SAYING IN DISPLAYING FOLLOW INTRUCTION? COMPLETE THE SENTENCES...OK...SOME MISSING SENTENCES.
Nov 21, 2008 | Office Equipment & Supplies
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
48 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
