Question about Refrigerators
Drawers for eurolec freezer model RF008 - Refrigerators
How do you replace a freezer drawer front?
The freezer drawer front is held onto the glide-out rails with screws on either side. These will be 10mm. Once the screws are removed you can lift the drawer front up and off the rails.Be careful when replacing to keep both left and right rails the same distance out from the cabinet so that they close evenly.
Sep 28, 2016 | Samsung 28 Cu Ft Black French Door Bottom...
Where can I obtain an Instruction manual for a Eurolec built under oven with grille?
Looks like the support is overseas. However they do have email support. If I knew the make and model I might be able to obtain more information. Otherwise here is the email link for support:
Reception@Eurolec-Services.co.uk
Jul 02, 2015 | Ovens
Samsung bottom drawer freezer is leaking and ice is forming along both sides of the drawer?
Is there a drain at the rear for when it defrosts that has become blocked? Defrost fully and clear drain hole
May 20, 2012 | GE Profile Arctica Stainless Steel Top...
See previous answer re drain blockages. Also check condenser clean and all fans working ok.
May 20, 2012 | Samsung Refrigerators
Bottom freezer drawer doesn't slide out easily, frost builds up
3M spray silicone lubricant in 24 oz cans is good down to -23 degrees and FDA approved for being around food. Works a treat.
Jun 27, 2010 | Sub-Zero 650 / O Bottom Freezer...
Excessive fosting in the freezer compartment
may have a bad drain line heater or a bad defrost heater, thermostat, or timer.
Oct 09, 2009 | Freezers
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Open Questions:
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
