Question about Kyocera Mita KMR-1810P Laser Printer
Kyocera KM 1525 C710 - Kyocera Mita KMR-1810P Laser Printer
3 Suggested Answers
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
shawn38
  • 200 Answers
SOURCE: We have a Kyocera Mita KM 1510 and I am getting an
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
Posted on Apr 15, 2011
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Kyocera Mita Photocopier KM-1530 Error code AP flashes at start up then C710
When AP flashes the toner is being replenished inside the copier. Wait a few minutes. You need to refill the toner.
Jun 09, 2011 | Office Equipment & Supplies
We have a Kyocera Mita KM 1510 and I am getting an error code C710 and the add toner light is on. I put in a new toner cartridge but the error message and the light are still on. Any suggestions?
Apr 07, 2011 | Kyocera Mita KM 1510 Laser Printer
What is C 710 error codes?
You machine toner is empty insert toner
Jun 14, 2009 | Kyocera KM-1505 Copier
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Error c710
Your problem could be one of several things:
1) The Carrier (iron filings) inside the imaging unit is deteriorated and needs to be replaced.
2) The Toner sensor inside the imaging unit may be giving an incoorect reading, due to be faulty or because of old toner/carrier mix blockage close to sensor. Give the imaging unit a good service and replace the carrier.
3) The wires behind the black cover of the imaging unit have been picnhed and is shorting on the metal plate
4) The main PCB of the machine could be faulty
May 27, 2008 | Office Equipment & Supplies
What is c710 flashing
Problem with toner concentration in developer unit .Try to replace developer,after that run U130. If not,replace Developer.
Nov 08, 2007 | Kyocera KM-1505 Copier
Kyocera Mita KMR-1810P Laser Printer Logo
1,156 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
