Question about Refrigerators
Can i get replacement drawers for model rf 008 eurolec freezer
Freezer drawers are all cracked and need replacing any available?
SolutionGuy
  • 331 Answers
SOURCE: I have a ge french door refrigerator with two
Hi Laura,
The repair guy did what any repair guy would have done under a warranty situation such as yours... door gaskets. I presume he explained why he was doing what did ("why's" are important, ya know...). If he didn't, let me run through it real quick, OK?
Warm air holds moisture and cold air doesn't... that it in a nutshell. But what's important to note is that if there is an air leak inside your freezer you'll notice it just as you have, with condensation forming. This tells the repair guy that cold air is escaping and warm air is entering the freezer. The first place to look is the door gasket and that's why he replaced it. But now you know it wasn't the gasket, right?
So the repair guy didn't find the source of the air leak. It happens. The reason is that most "factory" tech's are trained on the fly and have the habit of not looking too deep into a problem 'cause they're warranty guys. They get paid whether or NOT a problem was fixed. See? Independent repair guys like me only get paid WHEN the job is fixed. So there's a GREAT incentive for me to get it right the first time, right? (I'm not "bashing" them. I'm just clarifying that warranty repairs are hit and miss at best.)
The thing you gotta think about is "How many places are there for cold air to escape and warm air to enter?" The answer to that question is "4". Yep. FOUR places that this can happen and each of them have to be inspected for evidence of moisture. They are;
1.) Behind the fridge where the ice maker water tube is inserted through the cabinet and into the freezer.
2.) Behind the fridge where the wire bundle enters the freezer compartment.
3.) Behind the fridge in the compresser compartment where the evaporator drain comes OUT of the freezer compartment.
4.) The door gasket.
Since your unit is still under warranty I certainly wouldn't expect you to chase these down for yourself. You should call GE again and have the repair guy come do this for you (print this out so you will have the above checklist). This is to protect your warranty, by the way. If you (or an appliance repair company NOT authorized to work on it) work on it, you run the risk of voiding the warranty altogether.
There's a product on the market called "PermaGum" (here's a link). It's used to seal air leaks such as this. When you talk to GE, try to insist that the tech have some on his truck when he arrives... I have the feeling that he'll need it because I suspect a leak is occurring in one of the top 3 areas I mentioned above (either that, or he didn't install the door gasket correctly in the first place).
As an aside? Just a tip/hint... I know that your fridge is new and all, but to KEEP the door gaskets like new for (almost) ever, use Vaseline on them. Yep, Vaseline. Open the fridge door, dab your finger into the Vaseline and smear a light (light) coat of it on the door gaskets all the way around. This will do 2 things;
1.) It'll keep the door gaskets from ever drying out.
2.) It'll provide a very good and air-tight seal when the door is closed. (air leak, Laura?)
There ya go! I hope this has helped you in your quest to rid you freezer of pesky condensation. If so, please remember to rate this as "It fixed my problem", OK? After that, you can mix up a Mojito and bask in the knowledge that you are a completely informed consumer when the GE guy gets there to finally fix your fridge.
Take care,
SG
Posted on May 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: i cracked my crispier drawer in my kenmore
repairclinic.com
Posted on Oct 28, 2009
  • 101 Answers
SOURCE: Marvel, Model 61 RF ww-F made in 7-19-2000
Dear John,
Contact the factory directly at 800-223-3900 8:00am to 5:00 pm EST. I believe the bar pn is 42241938 (for the 2nd and third bar) and the top bar pn is 42241937. (I am going by memory so have them verify it). They also have a kit that has both side hinges and new springs for the freezer door. If you can't get through via phone contact Tim Malloy using tmalloy@northlandnka.com. He's a little overloaded but should get back to you within a day or two.
Posted on Nov 02, 2009
  • 973 Answers
SOURCE: I accidently pulled my freezer drawer out and it
You can contact the Company at this link for Service and Parts;
http://www.liebherr.us/HG/en-GB/96685.wfw
Posted on Jul 18, 2010
bobicehouse
  • 1524 Answers
SOURCE: Lunch meat drawer plastic has
Call Bi Coastal Appliance Parts @ 1-800-673-1262
Posted on Jan 13, 2011
How do you replace a freezer drawer front?
The freezer drawer front is held onto the glide-out rails with screws on either side. These will be 10mm. Once the screws are removed you can lift the drawer front up and off the rails.Be careful when replacing to keep both left and right rails the same distance out from the cabinet so that they close evenly.
Sep 28, 2016 | Samsung 28 Cu Ft Black French Door Bottom...
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
I have an LFRD25850SW Fridge. The bottom shelf above the crisper drawers has cracked at the left front and is causing the drawer to stick. I need to replace the shelf frame (glass is OK). Can you give a...
The shelf frame is cracked . It can be purchased if the part is still available from LG . I wouldn't hold out hope though because LG is notorious for discontinuing parts after 3 years. Find a parts supplier who has contact with LG parts to see if it's still available . I was able to order one for my customer back in the spring.
Oct 22, 2017 | LG LRFD22850 Bottom Freezer Refrigerator...
Dear John,
Nov 01, 2009 | Marvel 61RFxx 24-inch Refrigerator/Freezer
Freezer making grinding noise ice maker not working
Sounds like the icemaker may need to be replaced. When you open the freezer drawer it cuts power to the icemaker.
Jun 18, 2009 | Maytag MBL2256KES Stainless Steel Bottom...
Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Nov 28, 2008 | Zanussi ZTX520W Top Freezer Refrigerator
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
