Question about DNP DS40 5x7" Dyesub Printer Paper, 460 Glossy Prints
DNP ds40 life counter reset - DNP DS40 5x7" Dyesub Printer Paper, 460 Glossy Prints
Ho do I reset my MFC8480DN after replacing the fuser unit?
This is the fuser reset procedure from page 563 of the service manual:
5.1 Resetting the Periodical Maintenance Parts Life
? Resetting the Life Counter of the Fuser Unit
<Function>
This function allows you to reset the page counter of the fuser unit and increase the number
of replacement times by one.
<Operating Procedure>
(1) Press the [3] and [9] keys at the same time in the ready state.
The "Reset Menu" will appear on the LCD.
(2) Press the [ ] button a few times to select "Fuser".
(3) Press the [OK] button.
The "1. Reset / 2. Exit" will appear on the LCD.
(4) Press the [1] key when resetting the life counter of the fuser unit. Press the [2] key if not
resetting.
(5) The "Accepted" will appear on the LCD if pressing the [1] key. The page counter of the
fuser unit is reset, and the number of replacement times is increased by one. Then, the
machine returns to the ready state. If pressing the [2] key, the machine do not reset the
page counter and the "Fuser" will appear on the LCD.
Feb 10, 2015 | Office Equipment & Supplies
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Reset xerox phaser 5550
To reset the maintenance counter (assuming it is the maintenance kit you need to reset)
1. From the Main menu, select Information, then press the OK button.
2. Select Supplies Info, then press the OK button.
3. Select Reset Fuser Life, then press the OK button.
4. Select Reset Fuser Life NOW, then press the OK button to reset the fuser life.
Aug 01, 2014 | Xerox Phaser Office Equipment & Supplies
Always go back in and double check the PC life counter after the reset before F8. More than once the PC Life did not reset on the 1st attempt (other counters do reset 1st time) Take a quick look see.
Apr 11, 2014 | Konica Minolta Bizhub 222 Black and White...
Reset counter taskalfa 2550ci
there are many counters that count "page counts" for keeping up with PM, roller life, etc... if you are referring to the total counters they cannot be reset.
Nov 28, 2013 | Kyocera TASKalfa 180 Copier
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
DOOR JAMMED ON DNP RX1
DNP RX1 Door wont open. Unplug it, plug it back in and turn the power on, then see if the door will open!
Jan 13, 2013 | DNP RX1 Compact Digital Color Photo...
How do i reset fuser kit for brother DCP 9040 CN
Press 3 and 9 at the same time. This gets you to a hidden counter reset menu. Brother support was not able to give me this information said I had to take the printer to a service shop. Fortunately, one of the shops told me this information. Ooooo. Big secret. What B.S. !!!
Apr 07, 2010 | Brother MFC-8460N Laser Printer
How do I reset drum counter on brother printer HL5250dn
Hello. if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Regards, Joe PS: kindly rate my answer. Thank you.
Jan 28, 2010 | Computers & Internet
DNP DS40 5x7" Dyesub Printer Paper, 460 Glossy Prints Logo
83 people viewed this question
Top DNP Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a DNP Office Equipment and Supply Expert? Answer questions, earn points and help others
