Question about HP Compaq Presario SR1053WM PC Desktop
Light flashing on back of power supply. - HP Compaq Presario SR1053WM PC Desktop
  • Dwayne Dennis
    Dwayne Dennis May 11, 2010
    Thats called a beep code its letting you know that something has gone bad in your system, could be the onboard video card, the ethernet card or the modem youll have to google beep codes from the maker of your computer and find out what that codes is and replace what ever it is that went bad
    Champion:
  • 239 Answers
Verify the fuses inside the PC
Posted on Aug 29, 2009
How do I know if the power supply is bad on gateway gt5676 computer? I push power button and nothing happens. I unplug it and the green light flashes on the power supply( Bestec ATX 300 12 EB3). Plug it...
u can buy power supply testers, just a device you plug the power supply into, or try a new power supply. but if nothing is happening no fans etc theres a good chance its just the power supply.
Jun 17, 2012 | Computers & Internet
Red light flashes on tv but wont turn on
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jun 07, 2012 | RCA Televison & Video
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
Green light is flashing in back of computer but it will not turn on
if the green light you're mentioning came from the power supply, you need to replace it. green light flashes from the LED at the back of the power supple serves as an indicator if you have a good or a faulty power supply.
Aug 07, 2010 | Compaq Presario 5000 PC Desktop
Three red lights flashing
Three red lights flashing means that there is a hardware fault.
Check your power supply light 1. Turn on your Xbox 360 console. 2. Take a look at the light on the power supply.
The power supply light is located on the end of the rectangular box in the middle of your power cord. If your power supply light is green
Solution 1: Check your power supply cables
Unplug and reconnect your power supply. Here’s how:
Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and from the power supply unit
Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
Make sure that all three power supply connections are firmly secured.
Turn on your console.
Before you perform solution 2, I would suggest you to go through following links.
http://support.xbox.com/support/en/us/nxe/kb.aspx?ID=907534&lcid=1033&category=hardware
and
Following link is an interactive troubleshooting link.
http://support.xbox.com/support/en/us/xbox360/hardware/console/troubleshootingconsoleproblems/flashinglights.aspx
Solution 2: Submit a console repair request
Your console needs to be repaired. There are no additional troubleshooting steps. To begin the online repair process, click one of the following links: I am a U.S. customerI am a customer outside the U.S.
This solution is absolutely FREE, so please rate and give positive feedback.
Thank :)
May 09, 2010 | Microsoft Xbox 360 Console
Maxtor personal storage 3200 - flashing green light.
Solution:
First, disconnect the power cable from the back of the external hard drive:
If the power supply LED continues to blink:
  1. Connect the power supply to a different outlet (or instead of connecting to a power strip, connect directly to an outlet in the wall).
  2. If the power supply continues to blink after changing outlets, this indicates that the power supply is defective and needs to be replaced.
  3. If the power supply stays solid, then reconnect to the external hard drive and see if the drive spins.
Jul 01, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
FLASHING RED LIGHT ON 360
Make sure that the power supply is cool loadTOCNode(2, 'whattotry'); The red light may indicate that the power supply is too hot or it has already overheated. If that is the case, you should let the power supply cool for several hours in a well-ventilated space. Turn off the Xbox 360 console and don't turn it back on while the power supply is cooling. This will allow the power supply sufficient time to cool. As soon as the power supply has cooled off, the power supply light will change from red to orange, and you can turn the console back on.
If the power supply light is still red after you have let the power supply unit cool in a well-ventilated space, the power supply unit may require replacement. You can contact Xbox Customer Support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) for information about how to replace the power supply.
Make sure that the power supply is plugged in correctlyFor further details go to this link
http://support.microsoft.com/kb/906101/
Jan 03, 2009 | Microsoft Xbox 360 Console
Three red lights on my xbox 360
SYMPTOMS loadTOCNode(1, 'symptoms'); Three lights flash red on the Ring of Light (RoL) on the front of your Xbox 360 console. The upper-right quadrant light is the only light that does not flash red. uparrow.gifBack to the top
CAUSE loadTOCNode(1, 'cause'); The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. uparrow.gifBack to the top
MORE INFORMATION loadTOCNode(1, 'moreinformation'); If you are experiencing this problem, you can submit a console-repair request online. However, before you submit your request, first try the following two steps to verify the problem: 1. When you turn on the console, look at the light on the power supply. The power supply light should illuminate green even if the three lights on the Ring of Light flash red. If the power supply light is not green, please follow the steps in one of the following Microsoft Knowledge Base articles: 906101 (http://support.microsoft.com/kb/906101/) Troubleshooting your Xbox 360 Power Supply when the light is red 906102 (http://support.microsoft.com/kb/906102/) Troubleshooting your Xbox 360 Power Supply when the light is orange 906103 (http://support.microsoft.com/kb/906103/) Troubleshooting your Xbox 360 Power Supply when the light is not illuminated 2. Turn off the console. Wait 10 seconds, and then turn on the console again to see whether the problem re-occurs.If your console continues to display three flashing red lights, your console may have to be repaired. If none of these help, pease contact Xbox support at http://xbox.agent.asahost.com/ to talk to a live agent.
Sep 05, 2008 | Video Game Consoles & Games
HP Compaq Presario SR1053WM  PC Desktop Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
