Tried to connect Philips Blu Ray player to the TV via HDMI port. Get no picture. Is this a compatibility problem or is the TV/Blu ray player faulty. If compatibility issue, which blu ray player, if any, is compatible?
SOURCE: Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
SOURCE: Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
SOURCE: when i try to connect
That message is indicating that the resolution of the blue ray is too high to the TV to display.
Can you try this player with the same HDMI cable with another TV.
Other HDMI ports on the TV work OK?
Please read your TV and Player user manual on how to set them up.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
SOURCE: My Sharp Aquos LC-40E67UN is plugged into a Sony
Wow it seems as though you've pretty much done all of the applicable troubleshooting for this issue. The only other thing I can advise in this case is to consider purchasing a SD card. Some Blu Ray players require a little extra memory to function properly so they come with an SD card slot. Of course no one tells you this when you buy the player but it may be the solution to your problem.
