Question about Garden
Transmission wont go foward or backward - Garden
5 Suggested Answers
wadembly
  • 513 Answers
SOURCE: engage problems
it could be in the drive belt take a floor jack jack it up try it in the air & see if it goes into gear e-mail me back at wadembly@aol.com
Posted on Jun 07, 2009
decenamarcar
  • 31 Answers
SOURCE: my rc fastlane hawk4 wont fly foward
hi..
i want to suggest to you is to kindly open the remote control and and see all the buttons... the f the button for forward is in sticky key.... replace it and buy a new button key... or go to the nearest electronics shop to you... i hope it will help... thank u and god bless
Posted on Mar 13, 2012
emissionwiz
  • 79865 Answers
SOURCE: ford 555 backhole won't go foward or backward
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
Posted on Sep 03, 2012
ercupa190
  • 12223 Answers
SOURCE: pedals are locked won't spin foward but will spin backward
see the following steps, and fix it. God bless you
Pedal Arms
Use a flat screwdriver to unseat the tabs that hold the front top cover in place. This will expose the flywheel and pedal arm connection points. Rotate the flywheel by hand and determine whether lubrication will accomplish the repairs. If the bearings are exposed, use a grease gun with an extension nozzle and lubricate both bearings with lithium grease. If the bearings are damaged or sealed, proceed to the next step.
Remove the front and side covers on the main frame. Hold the flywheel with one hand and use a box wrench to loosen the bolts that secure the pedal arms at each side of the flywheel. Pull the arms away from the flywheel and remove the bearings from each side.
Test the bearings as before. Lubricate exposed bearings with lithium grease and reinstall them. Sealed bearings must be replaced. Reattach the pedal arms to the flywheel. Replace the main frame covers and front top cover to complete the repairs.
Posted on Nov 28, 2012
My mower runs but will not go foward or backward. What happened?
some riding lawn mowers have a lever on transmission to disengage drive system . i am not talking about the shifting lever . i am talking the transmission it self. then check tension on the drive belt
Apr 29, 2017 | Garden
I have a 2005 pt cruiser it wont move foward or backward it just let engine run up in drive or reverce help
Check the fluid first. Those transmission like to leak. A common fail on those are the solenoid pack.
Jul 09, 2016 | Cars & Trucks
1997 ford expedition wont engage in foward or backward
That happened to my old truck, an 04 dodge, and I said to myself " chancery, old chap, this must mean a new transmission" , I was mistaken. The solenoid pack in the tranny was bad. I had that replaced for a fraction of the cost of a new tranny and never once had another transmission problem.
Jan 19, 2013 | 1997 Ford Expedition
Mower will not move foward or backwards belt ok and turning fan and pully.
then the hydrostatic transmission is shot, look around for a new one or a used one. good luck as a new transmission will cost as much as another mower.
Apr 14, 2011 | Husqvarna Yard Tractor
My jeep goes foward and backward but someone told me that 3rd gear is out... could this be something simple?
Doubtful. You could try changing the transmission fluid and filter. no garantee though. more than likely you will need a new transmission
Jan 20, 2011 | Jeep Grand Cherokee Cars & Trucks
Mazda wont go foward or reverse.
If you are lucky, you are just out of transmission fluid. Add fluid to refill the transmission to the mark on the dip stick. Afterward, you need to determine where the old transmission fluid leaked out and fix the leak. If refilling the transmission does not fix the problem, you then need to look at fixing the transmission. Are you sure the shift linkage is ok?
Jul 31, 2010 | 2006 Mazda 6
Engage problems
Jun 07, 2009 | Garden
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
