Question about Video Cameras
Eurotag dv.60q9e - Video Cameras
My machine doesn't open and I have lost my manual
http://www.manualsdrive.com/results.php?lang=en&search=EUROTAG%20XQG60%20A208TE#.VZYc81JHaJI Sorry but this is all I could find on it we don't have one here
Jul 03, 2015 | Washing Machines
Where do I find a user manual for a Eurotag dryer model DV-60Q9E?
Google up the dryer type and you will possibly find this information on one or more of the web pages
May 12, 2014 | Dryers
Eurotag bottle cooler runs continiously
Is it in a warm room with windows closed ?Is the hot element at the back clean and clear?
Jan 10, 2014 | Samsung RS2630SH Side by Side Refrigerator
DVD to mini DV tranfer
Only way is Play burned DVD in dvd player and provide Audio- Video out (yellow-red-white) to mini DV camera that has AV Line Input recording facility. Or find any Mini DV recorder and record tape.
In that way you can record video again on Mini DV tape.
Apr 24, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
Cam Corder Connection To PC
Your PC must have DV port for DV signal.
You can connect your camera with PC through USB port only.
Try to find DV card for PC in local computer market.
May 27, 2008 | Sony Handycam DCR-TRV250 Digital Camcorder
Mini DV Tapes Won't Play
Please give the model and the make
Apr 16, 2008 | Sony DSR-11 DV / Mini DV VCR
Help
If you need a copy of the DV-150 manual, here's the link: http://www.jazzcameras.com/Support/Manuals/DV-150_Manual.pdf Regards, CharlesHanna www.globaltechpromos.com
Aug 01, 2007 | Jazz DV-150 Digital Media Player
How to connect dv camcorder to pc?
Hello, please check this link: http://support.sony-europe.com/dime/camcorders/DV/DV.aspx?l=en&m=DCR-HC21E If you need more info please advice. Arpi
Jul 13, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Connection using Firewire
Use a DV cable to connect the camcorder to the computer. Determine whether your computer has a 4-pin or a 6-pin DV terminal. Use an appropriate, commercially available DV cable for your computer's DV terminal. When making this connection, the use of the compact power adapter is recommended. How to connect ? 1. Turn the camcorder's POWER switch to . ? 2. Move the TAPE/CARD switch to . ? 3. Connect the computer's DV terminal and the camcorder's DV terminal with the DV cable as shown in the image below. The location of DV terminals differs between computers. For more information, please refer to the documentation that came with your computer. Important: 1. Operation may not work correctly depending on the software and the specifications/settings of your computer. 2. If the computer freezes while the camcorder is connected, disconnect and reconnect the DV cable. If the problem persists, do as follows. (1) Disconnect the DV cable, and then turn off the camcorder and the computer. (2) Turn the camcorder and the computer back on and reconnect them with the DV cable. 3. The image files saved on the hard disk drive of your computer are original data files. If you wish to edit these image files on your computer, make copies of them first, and use the copied file, retaining the original.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
Connection
Only DV connections (IEEE1394 connections) are possible when connecting your camcorder to a computer. DV connections (IEEE1394 connections) Your camcorder can be connected to a computer equipped with an IEEE1394 (DV) terminal or OHCI-compliant IEEE1394 capture board. You can transfer taped recordings (digital video signals) to the computer by connecting the camcorder to the computer. Use the editing software supplied with your computer/capture board to transfer video recordings from tape to the computer. If you are using a computer running Windows XP, you can also record the video simultaneously on your computer's hard disk and on the tape using DV-PC Recorder Software. You can download the DV-PC Recorder Software from Canon's DV-PC Recorder Web site. Making the connection Connect the camcorder to the computer as shown in the figure below. The computer's IEEE1394 (DV) terminal is either a 4-pin or a 6-pin type, depending on the computer used. Use either the CV-150F (4-pin - 4-pin) or the CV-250F (4-pin - 6-pin) DV cable (sold separately), whichever fits your computer's terminal. Precautions (1) There are cases where the connection may not work correctly, depending on your system specifications/settings. (2) If the computer freezes while you have the camcorder connected to it , disconnect and reconnect the DV cable. If the problem persists, take the following actions. (2-1) Disconnect the DV cable from the camcorder and the computer, and then turn off the camcorder and the computer. (2-2) Turn the camcorder and the computer back on and then reconnect them with the DV cable. (3) Your camera cannot be used with DV NETWORK SOFTWARE (DV Messenger).
Sep 04, 2005 | Canon XL2 Mini DV Digital Camcorder
Video Cameras Logo
18 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
